Question about Canon CD-4050 Path-Through Scanner
Canon CD-4050 I just acquired one of these scanners but I have no manuals, etc. It powers up and the display is visual. However, there is a sign on password box and I have no idea how to get around this. Have no idea who the previous owner was, got it at a yard sale for $10.00.
Google search for the password... its a standard thing =)
Posted on Apr 25, 2008
Try plugging in a key board and hitting the escape key, works for me every time.
Once in you can goto the Tools > Admin and adjust the domain settings.
Jason
Brandon, FL
Posted on Dec 11, 2007
How to canon np 4050 scanner lamp continuously on
It would be in service mode, why would you want to turn it On continuously??? Does the lamp turn ON with warm up? If so, the lamp and fuse is good. When you make a copy, will the lamp turn OFF and ON when it is scanning the original? If it dose, you will need to replace the scanner power cable. This copier is very, very, old.... I was trained on it over 20 years ago... Parts may be hard to find.... Good Luck
Dec 08, 2012 | Canon Copier Toner Cartridge Npg 4 For Np...
I want you people to teach me how to install and to use a network scanner on canon IR2520.
Install the scanner driver (Canon Network ScanGear) found on the bundled CD. I assume you already assigned an IP address on your copier. Run the Network ScanGear software, the one you installed earlier. Click Discover or you can manually type the IP address of your copier. If your copier is discovered, click Test Connection. Remark is displayed that your scanner is ready to use. Click OK to save the settings.
Now, run 3rd party software (eg Photoshop). In File > Acquire > (Select Canon Network ScanGear). A window will pop up and you are ready for scanning. Note: If error "Scanner is offline" occurs, go to your copier and press Scan > Remote Scan > Online.
Jul 06, 2011 | Canon iR 2016i Black and White Copier
Error message no-5010 displays at the time of printing
E42 22 = Scanner error
E4 = No ink
E2-2 = No paper (ASF)
please check this eror
Sep 04, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Canon Scanner 5000F fails when adjusting lamp before scan.
Have the same problem. Suspect a lamp problem but cannot find any info/help to check lamp or to replace it
May 27, 2009 | Canon CanoScan 5000F Flatbed Scanner
Scanner won't feed
Fan the documents and check if they are loose. Stapled documents can be 'sticky' even after removing pins. Clena the pick-& ****** up rollers. Switch off the scanner and rotate them by hand so that all areas canbe cleaned (In power-on position, they are locked), If worhout replace them. Normally they last about 250,000 scans. Using a damp cloth is generally enough, dont use solvents.
S. Mohan, India
May 20, 2009 | Canon CD-4050 Path-Through Scanner
Canon NP 4050
I use this one
precisionroller.com
Oct 19, 2008 | Canon NP 6050 Copier
CD-4050 Scanner
First scan a single page and note the file size. Then scan two pages and check if the file size is changed. If the file size is changed, then you have problem with your viewing software. If the file size is same, then check your setting in the scaniing software.
S. Moha, India
Nov 29, 2007 | Canon CD-4050 Path-Through Scanner
335 people viewed this question
old marine
old marine
