Question about HP Pavilion F1703 17" LCD Monitor
How do I get my monitor out of sleep mode and my keyboard and mouse to work again?
  • ky_troschuk7 Jun 30, 2009
    Ive had the computer for a long time and its been fine, my pc is running, my monitor has an amber light on it and doesnt turn to blue, my keyboard and mouse dont light up at all. I fixed it for about 15 mins just by unplugging the monitor and pc but now that won't work I need help please!
  • 4 Answers
You may not have enough RAM installed on pc to run that monitor. Please check specs.
Posted on Jun 30, 2009
5 Suggested Answers
  • 11 Answers
SOURCE: Monitor goes into sleep mode
Just to check, do you have any power settings enabled? If you right click the desktop and go to properties, then screensaver, then power settings, look for hibernation and options to turn off the monitor after a certain amount of time. Maybe one of these settings got checked.
Posted on Dec 17, 2007
Sunil Panem
  • 80 Answers
SOURCE: Cannot get me monitor out of sleep mode, please help?
Hi
Pls check the power management properties in device manager to check if the option to wake the computer from sleep for the keyboard and mouse are enabled.
You may also try to change the power plan or create a new power plan and check if you are able to wake the computer from sleep.
If this problem started a few days back, then you may try to do a system restore.
Posted on Feb 27, 2008
  • 1684 Answers
SOURCE: Samsung SyncMaster 710N Monitor SLEEP MODE
The monitor is not going to sleep the power supply board is shutting down. If you can solder you should be able to repair the monitor yourself. The problem is caused by blown capacitors on the power board. Go to our web site at : www.ccl-la.com/badcaps.htm We have pictures of what to look for. Open your monitor and look at the power supply board for any blown capacitors, replace all that you find. The replacement parts can be ordered from several places on the internet or we can supply them for you. The replacement parts will need to be high temp and will be marked 105c. The values you need to get will be marked on the sides of the ones you take out but will be something like 220uf, 470uf, or 1000uf etc. and then a voltage rating. When you install the new ones be sure to insert them with the polarity stripe going the same direction as the old ones come out. If you don't want to do the repair yourself we do offer a repair service for $35 plus return shipping. If you have any questions just let us know
I hope this helps if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Posted on Oct 24, 2009
  • 257 Answers
SOURCE: my monitor keep going into sleep mode, the cpu
not a expert just trying to help,,sound like you have a hard issue ,, need to have check,, going by the problem i had once,, hope this help you
Posted on Feb 25, 2010
Keyboard and mouse not working and monitor going to sleep
HP Pavilion Slimline S3400f Desktop.
dont worry ALL PC end up like this,, all do.. sooner or later..
NO OS stated, XP"? never post without OS stated, or answer get 10x more harder, See? make it easy for the helper and get more help.....
no Monitor stated. (maker, CRT, LCD what?)
The monitor is not fibbing to you BTW, the PC did go dead or to sleep. seems its monitor monitor of some kind with DVI.
if the monitor works on other PCs then the monitor is not bad.
i Bet it works (old ones 2002, have a hidden deep internal sleep mode. and is not yours IM sure now) DVI IS THE ONLY CLUE THERE.
So PC is dead. this PC came with only VISTA new,
is it still VISTA?????????
HP has support on it still
here (carbon dated by me 2008, IIRC)
https://support.hp.com/us-en/drivers/selfservice/hp-pavilion-slimline-s3400-desktop-pc-series/3688715/model/3688723
this year,? get all those files and books there backed up
when HP support ends after 10 year rule, (be savvy?)
what keyboard USB or wireless keyboard mouse
use wired USB keyboards if wireless the battery is dead. easy no?
now in VISTA, go to Control panel, click power
turn off all sleep modes and all hibernate modes
the turn off screen savers, if turned on , disktop . RC right click
in display settings or personalize, turn off , need login to come out of sleep or screen saver.
try a real keyboard, that has USB cable yet? be first thing to do.
always keep a real keyboard, handy,,,
batteries fail. in all wireless devices like this (inside them)
luck you desktops have lies DIM fails. there are many.
http://www.pcdied.com/sleep-or-dim.html
one other way , and common is PC overheated.
all do that.
ever one not cleaned out every year,.
#1 all time cause of overheat and PC shuts down.
http://www.pcdied.com/overheated.html
Aug 11, 2017 | HP Pavilion Slimline S3400f Pc PC Desktop
WF1907 Monitor is in sleep mode - how can i get it to stay on?
If understand your issue correctly , your system and monitor is fine . The only problem is that the monitor switches off after some time.
If after moving the mouse or taping on the keyboard the monitor comes back . Then we can solve the problem buy adjusting the power settings in the OS .
If the monitor doesn't come back on if you strike the keyboard or click the mouse. Then the problem could be with the monitor.
Depending on the OS you have you can disable sleep by going to the following link
http://www.wikihow.com/Disable-Sleep-Mode
Jun 17, 2010 | HP Compaq WF1907 Monitor
My monitor will not stay on, it goes on sleep mode
Your problem may be due to the sleep button in your keyboard may got struct into when you cleaned your keyboard.
Try to resolve the struct in the keys, if any.
Restart your system and if still your problem persists, then remove your keyboard and restart your computer and try with some other keyboard if possible. Once if you find out that the problem is with your keyboard, then replace the keyboard / service the existing one.'
I hope this is helpful to you. Please provide your ratings.
Thanks
Apr 05, 2010 | E-Machines eMachines Monitor E15T4
HP Pavillion won't bring monitor back from sleep mode
hi...if u can read " no input signal" from ur screen, this means that ur monitor is ok..
Look if u have power buttons on ur keyboard.. try to wake it from there.. some pc may have shortcut keys to bring back the pc... look @ ur pc docs on the internet for more info...
However if it's a hardware issue, it may be that ur RAM memory needs to be cleaned
Feb 01, 2010 | HP Computers & Internet
How do I wake up the monitor when it goes to sleep when not used for a short time.
slapping it around usually works. "just a joke!"
tapping a few keys on your keyboard and moving the mouse will usually wake the monitor from sleep mode.
Nov 11, 2009 | Office Equipment & Supplies
My keyboard mouse and monitor arent working and my computer is in sleep mode, any suggestions please.
Please try pressing the power button once. this should bring it out of sleep mode.
Jun 30, 2009 | HP Pavilion F1703 17" LCD Monitor
Microsoft Multimedia Keyboard 1.1
my microsoft wireless multimedia keyboard 1.1 does not function at all
Sep 02, 2008 | Microsoft Multimedia Optical...
Snooze button on my acer keyboard
To disable the sleep button on the acer keyboard Do the following (Vista home)
Go to control panel (classic view) double click Power options.
left hand margin select Choose what the power buttons do.
This opens a systems settings page
You will see an option :
When I press the sleep button: (Don't worry that the picture of the button is different than the keyboard's Zz)
Select Do Nothing from the dropdown box.
Click the Save changes button at the bottom of the screen.
This will disable the button on the keyboard...
May 28, 2008 | Acer NSK8458AN Keyboard
Hi
Feb 26, 2008 | Dell E151FPp 15" TFT LCD Flat Panel...
HP Pavilion F1703 17" LCD Monitor Logo
431 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
