It is charging the battery but the battery is not holding the charge probably from a faulty batter in the pack.so the charge is going in and out at the same time. Take the pack to a battery shop that specialises in replacement batteries to have it checked out . Take the charger also for tests.
Batteries sometimes get like yours, after a full charge they last only a couple minutes on the tool. It's usually because of a bad cell in the battery. The only fix is to replace the battery. If you just bought it, take it back for an exchange of the battery or whole tool kit. If the retailer you bought it from won't exchange it contact the company it came from to find out how to get the battery replaced under their warranty.
you might think im crazy but I just did this and it works so far anyway, I cut open my charger for my dremel 7300 model ,my green charging light stop working aswell , I felt naked without my dremel, so after the fourth day I cut it open and tinkered with it, I unwrapped some of that blue tape that\'s covering the copper spool , forgive my terms I don\'t know the correct name anyway I found a lil clear device connecting two silver wires, I twisted them together by grabbing the clear thing and twist until wires are connected put back together , put a batt in and green light came on and is charging, my charger looks like frankenstien but it works, how long will it last NO IDEA but if it stops ill post it, if you try this I hope it works, I should have videoed myself maybe nextime
Mine does the same thing, after years of freezing heating and thawing in the car the batteries just won't hold a charge anymore.Getting a replacement battery would cost about $24 plus shipping.
Any battery left in a charger is still hooked up to a circuit. Depending on the charger this can mean a slow discharge is possible. Ryobi's Maintenance Charge Mode means the charger will 'refresh' the battery at regular intervals, usually every 30 days. A battery's lifespan is determined by how many times it is discharged/recharged so to get 'the longest possible battery life' it is desirable to reduce the number of times a battery is recharged. One way is to use the battery until it is dead or near so another is to remove the battery from the charger when it's fully charged to reduce the number of times the charger refreshes the battery.
sounds like u are using the wrong collet in the end of dremel the normally have a couple of different collets try changing it for a tighter one also make sure its in the right way
