Question about Garmin nuvi 255W GPS Receiver
How to open unit?
How do i open it up to grt to batteries
  • SHARCNET-USA
    SHARCNET-USA May 11, 2010
    Please don't try to do this yourself. You risk damaging the LCD display. Do not follow any dissassembly video for a 7xx series Nuvi. They are NOT the same units, physically and you WILL damage your Nuvi 2xx(W). Many times, especially in the 2xx(W) series, the problem is a loose mini-USB jack and not the battery. If the mini-USB is loose, the battery will never charge, leading the owner to believe that the battery is defective. Don't turn a cheap repair into a costly one. Please see this link:http://www.sharc.net/gps_battery_repair....http://www.sharc.net/gps_charger_repair.... - Jim
    Brigadier General:
  • 4,090 Answers
Not adviusable, take it to a service center
Posted on Jun 30, 2009
Heat does not work shuts off after ten secounds
ClassicFlame 36EB220-GRT 36" Traditional Built-in Electric ...
www.amazon.com/ClassicFlame...GRT...Electric-Firep...
Amazon.com, Inc.Save Big On Open-Box & Preowned: Buy "ClassicFlame 36EB220-GRT 36" ... TheClassicFlame PRO 36" traditional built-in electric fireplace insert, 240 volt, ... Heatingyour entire home all day may not be the best economic choice for your utility ... Youcan shut off the heated air blown to different sections (or 'zones') of your ...
Amazon.com - ClassicFlame 36EB221-GRC 36 ...
www.amazon.com/ClassicFlame...Electric-Fireplace/.../...
Amazon.com, Inc.
Rating: 4.1 - ‎7 reviews
36\" Builder's Box Electric Fireplace Insert The ClassicFlame builder's box features... You can shut off the heated air blown to different sections (or 'zones') of your home... 36EB221-GRC 36 inch contemporary built-in electric fireplace insert will .... Wedid finally get the pieces after about a month, and the unit is working now, ...
ClassicFlame 36-Inch 120V Traditional Builders Box ...
Jan 18, 2016 | Classic Flame PRO 36EB110-GRT 36 Inch...
How do grt the pass code on dnx5120 dont remembercode happend after changing battery o n automobile
Look at the manual there should be a default passkode for login otherwise there should be a reset button om the device.
Jun 05, 2014 | GPS
Battery is fuy charged on 650 v star but I just grt a clicking sound when I try to start it
try jumper cables, silenoide may be bad but when it's clicking it's lack of power
Sep 13, 2012 | 2006 Yamaha V Star Classic
Hi, I have a 2006 Cadillac STS and the battery seems to be dead and I can't open the doors either because the fobs don't work. The spare key that I have is inside the car. Is there anyway I can get in to...
you can go to a cadillac with proof of ownership and a picture ID and yhey can grt the codes for your key and cut you a new key. after you get in the car start the car with the old key shut car off and immediately start car with new key this will activate the new key to your car
Aug 20, 2010 | Cadillac STS Cars & Trucks
2007 PT Cruiser basic RAD fan battery relay feed replacement
grt one at any parts store, it should be in the fuse or electrical box, look in the owners manual, pull out the the ole and plug in the new
May 08, 2010 | 2007 Chrysler PT Cruiser Touring Hatchback
When the phone is locked nokia 5310 how will to get ime num?
The imei number is usualy under the battery ... take of the battery cover and remove the battery and you should see imei ##############
Apr 23, 2009 | AT&T LG CU515 Cell Phone - Black
Acer 5315 pc notebook help with bios password
You are going to unplug your laptop and disconnect the battery.
Then you will have to open the case and find the little battery inside. This one is usually soldered, so you will have to unsold it.
Leave without power for have an hour, and the reinstall the batteries.
The password should be reset.
Check up the picture to help you locate the little battery.
Dec 12, 2008 | Acer Aspire 5315 Notebook
Do you know where you got your battery?
I have successfully changed the battery in two Quest II units. While it may not be for some who are intimidated by the inner workings of electronic devices2_bing.gif, it is not that hard either. You will need a small Phillips head screwdriver. Removed the back by removing the 6 small Phillips head screws on the back. Use caution with the two screws that hold the endcap for the antenna. It is not a problem if the endcap comes off, but there is a small spring holding tension on the antenna and if it pops out, it is easily lost. Handle the two parts of the GPS gently as there are wires that joining the two sections. The battery is held into the back section of the GPS with some glue but it is easily removed with gentle prying. Use a small flatbladed screwdriver to remove the plug from the battery to the circuit board. This should be all that is needed with the old battery. A new battery can be obtained from www.batteryship.com. They sell the direct replacement for the Quest and Quest II GPS units. When you go to their website, there is a list of various devices they sell batteries for. Click on GPS. This will bring up a page for various manufacturers. Select Garmin, and look for Quest. I think the battery runs around $25.
After plugging the new battery in, you may want to use a small dab of glue to secure it to the back side of the unit like the original battery. Reassemble the unit, reversing the process with the front and the back. The Quest units have a rubber sealing gasket between the two sections. Be sure you inspect that for kinks before tightening the 6 small screws. I would suggest the screws be tightened down gradually so uniform pressure will be applied to the gasket. I would tighten one screw down partially then move to the opposite side and criss-cross the unit until all screws are snug. Again, inspect the gasket for proper seating and you are done.
May 30, 2008 | Garmin Quest GPS Receiver
Garmin nuvi 255W GPS Receiver Logo
111 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
