Question about Whirlpool 3.2 cu. ft. Plus Washer
The model# is LXR7244JQ1...I PURCHASED A NEW switch-lid
The model# is LXR7244JQ1...I PURCHASED A NEW LID SWITCH, BUT I don't see how to get to it so I can replace it. Do you have step by step instructions for this model? Any visuals would help also.....thx
    Sergeant:
    Champion:
  • 235 Answers
Pop the lid open from the front or sides of the top panel. This should expose the switch. Pretty simple task. Just remember what you do. Don't forget to disconnect power cord before servicing.
Posted on Jun 30, 2009
Washer fills up with water but does not start to wash/agitate
if you don't hear the motor running you have a bad lid switch,if you do hear the motor but no agitation you have a broken motor coupling.
most likely you have a broken lid switch,close the lid,then open it around 6 inches,close it and open it a few times,as you do this if you don't hear a clicking sound the switch is bad,part number 8054980 and it's around 25 dollars.
http://www.youtube.com/watch?v=PZAbg9uftos&feature=BFa&list=PL946F2AC904989088
watch this video, when you click on it look down on the left side it will say replacing new style,click on it and it will show you your model.it will show you how to make sure it's the lid switch but if you don't hear any clicking when you open and close the lid the switch is bad,also if the lid is pushed in from putting the laundry basket on top of it open the lid and wack the center of the lid to pop it back up,i've done this before when the lid is dented in and this fixes the problem,the arm that's connected to the lid doesn't hit the switch correctly with the lid dented in but usually the switch is bad and needs to be replaced.
http://www.youtube.com/watch?v=MFsvLiuTniU
watch the first part of this video and it will show you how to open the top console,this is different from your lid switch this is just to get you into the top so you can change the switch.good luck,if you need anymore help let me know and i hope this helps you out
May 19, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
1.3 year old Frigidaire Stackable washer/dryer model FEX831FS won't drain. Checked pump and hoses. OK. Am in remote Alaska and we don't have service tech's here. Any suggestions.
What you want to check is the lid switch..remove the front panel..on the switch/lid lock asm.will be
the main switch which is part in the black body of the lock asm. the 2 terminals their will have contunuty with zero ohms when lid is closed
when lid closed the white switch will be open and closed when lid open
the one in the black body on the main lock asm. will be open when lid open
IF it does turn out that the lid lock is the problem the part number for it is 134101800
it could be purchased online at;
repairclinic.com
apdepot.com
apwagner.com
searspartsdirect.com
midwestapplianceparts.com
If the switch checks to be good test for power into the drain pump if no power the timer is what is wrong the washer (not dryer) timer is part# 131758600
Gene
Aug 24, 2011 | Frigidaire Washing Machines
Kenmore model 70 washer will not empty tub with lid closed.
This is a broken lid switch . You can replace the lid switch or if you need to get it working quickly you can bi pass the switch by unplugging the washer, removing the 2 lid latch screws, pulling out the switch cutting the 2 wires and twist them together with a wire nut.
This is assuming you do not have the self locking lid.But I don't think your model has that function.
May 14, 2011 | Kenmore Washing Machines
Replace lid switch assembly kaws850
The following link explains how to replace a lid switch:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
On the particular model you have listed, the lid switch should be located under the console near the right rear lid hinge.
You will need to use the steps in the link provided to remove the exterior case to access the switch to see how the actuator and lid hinge interface. You washer is manufactured by Whirlpool and uses Whirlpool parts, so these instructions will apply.
This is a very simple repair, but if you have any questions along the way, please let me know. I hope this is helpful to you.
NOTE: If you have not pruchased a new lid switch yet, the part number is 8054980. It can be purchased at appliancepartspros.com for about $18.
Oct 30, 2009 | KitchenAid KAWS850L Top Load Washer
My washer was purchased new in 1989. Are parts still available?
The problem is your lid switch. That "hole" you mention that you are putting a wedge in is where the lid switch is. It is activated by a small acuator on the washer lid that pushes down on the lid switch when the lid is closed.
If the washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug.
If the switch is not activated by a lid strike, it will activated by a hinge actuator located next to either the left or right lid hinge. You will need to remove the operator console in order to access this type of switch.
If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
A new lid switch (if needed) can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. All these sites offer competitive pricing, so shop all them for the best price.
If you have questions, or need additional assistance, please let me know. Please post back with a complete model number (located on a nameplate around the wash tub opening) with your questions, so that I may be able to provide you with better assistance. I hope this is helpful.
Sep 03, 2009 | Washing Machines
Washer filled with water and stoped workeing
This is commonly caused by a lid switch malfunction. If the washer fills and won't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain, this is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug.
If not activated by a lid strike, other models have the lid switch located under the washer casing next to one of the lid hinges. It is activated by a rod contacting an actuator. The mounting scews for this type are located under the operator console.
If you determine the switch to be defective, the following link explains how to access the washer interior and replace one:
If the switch requires replacement, a new one can be purchased on line at appliancepartspros.com, searspartsdirect.com, pcappliancerepair.com, or repairclinic.com. The average cost of a replacement is $25 to $35.
NOTE: Pounding on the lid or storing heavy items on the lid can contribute to premature failure of the lid switch.
If you have questions, please let me know. I hope this helps you.
Aug 22, 2009 | Washing Machines
KAWS750GQ1... washer fills, agitates, won't spin or drain.
I would recommend checking your lid switch. If the washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain, this is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug.
If the switch requires replacement, a new one can be purchased on line at appliancepartspros.com for about $23 (part number 3949247). If you need further assistance, please let me know. I hope this helps you.
Aug 14, 2009 | Washing Machines
Spin Cycle Not Working
the most common problem when this occurs is the lid switch has broken inspect it if not click when lid is closed replace the switch you see if you can get local it saves some shipping cost unless they are outragious then order on line
Aug 07, 2009 | Whirlpool 3.2 cu. ft. Plus Washer
ROPER MODEL RAX7245JQ0 WILL FILL AGITATO, DRAIN
Most of these spin related problems are attributed to a lid switch malfunction. A washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
Let me know if you have any questions. I hope this helps you.
Jun 29, 2009 | Roper RAS8445KQ Top Load Washer
WHIRLPOOL LXR7244JQ1 CLOTHES ARE STILL SOAKING WET
More than likely motor has lost a stage in it. I would replace it.
Jun 29, 2009 | Whirlpool 3.2 cu. ft. Plus Washer
Whirlpool 3.2 cu. ft. Plus Washer Logo
305 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
