Weslo Cadence G 5.9 Treadmill Logo
G
Gene Lucas Posted on Jul 26, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Replaced motor and motherboard board through warranty but belt still won't work. Not even the power noise will turn on.
Never used the product. The light on the diagram blinks quickly and according to the voltage diagram this means the controller has received a speed signal from the console greater than 0.0 MPH. It is now sending DC voltage to the drive motor.
Tim Hofstetter
Level 3:
Genius:
  • Master 1,406 Answers
  • Posted on Jul 26, 2014
Tim Hofstetter
Master
Level 3:
Genius:
Answers
1406
Questions
0
Helped
378809
Points
4295
The motor, or a connector to the motor, or the controller is faulty. If you can measure DC voltage at the motor (up to 90VDC), but the motor won't turn, and if you can manually move the treadmill belt with your hand or rotate the motor pulley (POWER OFF) with your hand, then the motor's dead. Even IF it was replaced under warranty.
If you can't measure any DC voltage to the motor under any conditions, then the problem is in the controller or a connector. Try measuring directly at the controller board.
1helpful
I have a Bosch Nexxt Dryer 800 series when you try to turn it on, it just makes a click sound, but won't turn on. Any ideas about what's wrong. Thanks Marge
see this causes and fix it. God bless you
Timer The timer is normally not at fault when the dryer won't start. In many situations where timers are replaced they end up being returned. First, check all of the more common components in this troubleshooting guide before replacing the timer. If the dryer won't start, the cause is much more likely to be a thermal fuse or switch. The timer can not be tested, it must be replaced if it is defective.
Main Control Board The main control board is normally not at fault when the dryer won't start. First, check all of the other components in this troubleshooting guide before replacing the main control board. The main control board can not be tested and must be replaced if it is defective. If there are obvious signs of burning or a shorted out component on the board, it should be replaced.
Belt Switch If the dryer won't start, there might be a belt switch that has failed. This is not a common problem and most dryers do not have this switch. If the dryer has a belt switch, the switch shuts off power to the entire dryer if the belt breaks. It is possible that this switch has failed, even if the belt is not broken. It can be checked with an ohm meter or continuity checker. If the dryer works at all, even if all it does is hum, this is not the problem.
Incoming Power Problem If the dryer won't start, check to certain there is electricity to the dryer. For a gas dryer, unplug the dryer from the wall and plug something else into the outlet to see if it's working. For an electric dryer, check the home circuit breaker or fuses. If they are working, check the outlet where the dryer plugs in with a volt meter. There should be between 208 and 240 volts. If there is power to the dryer, check the more common items in this troubleshooting guide.
Thermal Cut Out Fuse Kit Most dryers have several temperature control devices such as a thermal fuse, thermal cut out, high limit fuse or high limit thermostat. Some manufacturers sell the thermal fuse and thermal cut out in a kit. These kits normally solve no-heat problems rather than when the dryer won't start. However, in some models, this kit will solve both problems. Even though this is not the most common part to fail if the dryer won't start, both can be checked using an ohm meter or continuity checker. If they have continuity they are good. If not, they should be replaced.
Drive Belt On most dryers, if the drive belt breaks the motor can still be heard and it will still be blowing air out the exhaust tube, but the drum will not spin. However, in some dryers when the drive belt breaks the tension pulley arm trips a switch which shuts off power to the entire dryer. If the dryer won't start, check to see if the belt is broken. If it is, replace the belt and the dryer should be fine. If the belt is not broken, check the other components that can fail when the dryer won't start.
Drive Motor The dryer drive motor turns the drum and the blower wheel to exhaust the air. If the dryer won't start the motor might be defective. Before replacing the motor, check the thermal fuse, start switch and door switch because all three are more likely the cause. If the dryer won't start and the dryer motor makes a humming noise there might be something caught in the blower wheel, or the drum might be binding. Try removing the belt from the motor and checking the blower wheel for obstructions. The dryer motor can't be tested easily. If the more common components have been checked and it seems the motor itself is defective, it will need to be replaced. It is not serviceable.
Door Switch The door switch is located near the dryer door and is activated when the door is closed. If the door switch fails, the dryer won't start at all. Many types of door switch will make an audible click when they are activated. If the door switch makes a clicking sound when activated it is probably not defective. If it doesn't make a click, it can be checked with an ohm meter or continuity checker. The door switch is relatively easy to replace and is usually not very expensive.
Start Switch The start switch is on the dryer control panel. Depending on the model, either press a button or turn a dial to start the dryer. If the start switch fails the dryer won't start or make any noise. Test the switch with an ohm meter or continuity checker. If the dryer hums when the start switch is activated, or if the motor runs only while activating the start switch, the motor might be defective or something might be binding the drum preventing it from turning freely. If the dryer start switch does not have continuity when it is activated, it will need to be replaced.
Thermal Fuse The thermal fuse helps to prevent a dryer fire by shutting off power to the dryer if it overheats. If the dryer won't start check this fuse first. Test the thermal fuse with an ohm meter or continuity checker. This is the most common part to fail when the dryer won't start. Once the thermal fuse has blown, it has to be replaced. It can not be reset.
6answers
Neptune MAH3000AWW Problems
It is most lickely a foreign object stuck in the tub.
Frigidaire affinity Dryer wont turn on
see this causes and fix it.God bless you
I have an amana dryer,,,it says drying but it won't start,,no sound or nothing....I tried the fuse wires at the bottom direct and still nothing...so I don't think its the fuse...thanks
Sep 28, 2012 • Dryers
My Epic 425 Mx motor won't run even though power is on and display works
try to RUN the software calibration for diagnose, troubleshooting, fix it.
2) LUBE THE deck belt , this happen because the lack of maintenance schedule, maybe the deck is worn and need replace it. see the video and picture
3) lube the rollers bearing too very well.
4) test the input voltage motor, if there are the motor NEED repair,tight any wires connector for loose
5)measure the output voltage board, for input voltage motor, if there are NOT the board is faulty. use the DVOM OR VOM in both cases.
see the block d, tight any wires connector or wires looses
God bless you
Tecra r840 wont start (Won't even go to boot menu)
Try reseating the RAM module/s. If it still does not boot up then then RAM could be faulty, remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you.
Have a Bocsh WTMC 3321US/03 drier making noise. i have replaced motor, same noise. with drum not turning and belt disengaged, making same noise. What do i look for next??
If a noise is heard or even a HUM you can use a small tube to probe with one side kept to your ear. Trace the noise to the actual unit , if this is the motor humming check the capacitor as a faulty capacitor will not start the motor.
Also check for free movement of the motor drive as if there is tightness in the drive the motor will not work.
Olevia 537-b11, blue light won't come, even when power cord is replaced. Please help!!!!
Since you've already replaced the power cord and still the led light won't came on, this is an indication that the power supply board of your unit is dead. If it is not under warranty period(if so, avail it because the manufacturer will fix it for free) open the back cover and check the continuity of the fuse using the multimeter, if you found it open replaced it with the same current(ampere) ratings and then try to turn on the TV. If the replacement fuse blew again, this is an indication of more serious problem on that board. If the replacement fuse didn't resolve the issue, other parts on that board gone to malfunction as well. If this is the case, I would advice you to replaced the entire board for your convenient. The cost will almost the same rather than troubleshoot it. Check the actual part no of your board and check this LINK.
Hope I helped you.
Have a nice day!
Thanks for using fixya.
3answers
MY 2001 Elantra was making a horrible screeching noise whenever i turned the car on and whenever i turned the steering wheel. i thought it was the power steering pump so i replaced the pump but i didnt...
Hi, it sounds more like you have a improperly tensioned drive belt. If you didn't get all the trapped air out of the power steering system this maybe the cause of your stiffer steering problem now. Try loosening the P/S belt all the way and starting the car if you still hear the noise you know its in one of the other drive belts. good luck
Sportsart 3200 Treadmill Belt motor problem
5v DC equals .5 mph every 10v equates to 1 mph try increasing the speed if the DC voltage increases that means the motor control is working properly, then go back to the drive motor and check the motor brushes even though you have used a DC power source. They sometimes will not seat correctly and cause no belt movement, use a commutator stone a clean up the commutator arm.
Top Weslo Exercise & Fitness Experts
ZJ Limited
ZJ Limited
Paul Carew
NOEL
NOEL
Are you a Weslo Exercise and Fitnes Expert? Answer questions, earn points and help others
