Question about General Electric WSSH300G Front Load Washer
Water pumping out at a trickle. stops in mid cycle
Washer seems to stop just after the wash cycle. wont pump out the wash water. hose not clogged or kinked. wont go into spin cycle.
  • Anonymous Mar 30, 2014
    water will drain and spin on spin cycle
    Sergeant:
    Champion:
  • 235 Answers
The timer seems to have gone out on you. Try to manually set it on spin and if that works then the timer is out.
Posted on Jun 30, 2009
Washing machine wont complete drainage at end of wash cycle
Look under the washer tub where the drain hose comes out and attaches to the pump. Your pump impeller is either clogged or worn out. Try removing the pump and checking from there.
Jan 07, 2008 | Fisher Paykel EcoSmart GWL15
Washer stops between wash and rinse, and stays full of water. ld code
see this steps and fix it. God bless you
Lid Switch Assembly
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Enter your model number to see parts for your washing machine.
Help me find my model number
Door Lock Motor and Switch Assembly
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve
If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board
If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Jul 21, 2013 | Kenmore Washing Machines
Stop mid cycle
Hello Nick - Based on the symptoms you are describing, you may either have a communication error from the main control board or the timer itself may not be operating correctly. If you noticed a humming noise, it could either be a clogged drainage hose or pump that needs to be cleaned, or it could possibly have another issue with the door lock assembly. I would personally contact a professional to accurately diagnose the washer to determine the root cause to reduce the risk of unnecessary parts.
Jun 07, 2013 | Frigidaire FAFW3801LW Washer
I have a Frigidaire washer model FWX833AS. I washed a bath mat with rubber backing which basically disintegrated. Now the washer wont drain the water. It seems to be spinning as far as I can tell and...
You have to take apart all the drain hoses all the way back to the tub. Pay close attention to the hose from the pump to the tub. STOP RUNNING THE MACHINE!! You WILL destroy the pump if you don't get all that garbage out first. You may have to disconnect the pump hose and with the machine in it's usual position, place a pan, bucket etc, under it and dump several buckets of water through the machine to flush it out. A shop vac comes in handy on this job also. DO NOT run the machine until you are pretty sure you have most of it cleared out. Then run it 3 or 4 more cycles empty, if you don't, expect there to be that garbage on your clean laundry! Oh, one last thing: Don't do that again....lol
Oct 24, 2017 | Washing Machines
Our washer will stop mid cycle and not finish or will finish but not spin all the water out...
You have a clogged drain pump. The best way to access the pump is to remove the back panel and take of drain hose. Clear out the pump and test, everything should be ok. Any questions feel free to ask.
Nov 30, 2010 | Frigidaire ATF6000ES Front Load Washer
Stop in mid cycle
HD= No drain.
HI, check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
**The most common issue will be an obstructed hose or, line
Jul 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Atlantis 7700 - Noisy agitation/wash cycle from motor
Your drive motor may be fine. Check the water pump that is located in the back behind the small metal door on the left bottom corner and see if thats where your noise/water is coming from. These extraction pumps have bearings casing that gets mangled and locked up. Look right above the flywheel that the belt rides on in the W-pump.
May 09, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Washer stopping mid-cycle with no error
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you have drained, unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out. F-21 filter blocked.
How abt a nice rating for the free help?
Jan 04, 2009 | Whirlpool GHW9300 Duet Washer
Whirlpool front loader washing machine (AWO3361) WONT DRAIN
Remove drain hose from where it connects to the plumbing under the sink/tub. Inspect the spigot. If clogged, clean. If clean, then tilt machine back and remove drum to pump hose from pump. Check hose and also drain pump. Clear any obstructions.
Nov 03, 2007 | Washing Machines
General Electric WSSH300G Front Load Washer Logo
248 people viewed this question
Top General Electric Washing Machines Experts
Marvin
Marvin
Sal De
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
