Question about Dishwashers
Where does the jet dry go? - Dishwashers
  • rusgabi Jun 30, 2009
    thanks, did that. it didn't take as much as i thought it would but that's ok. just didn't want to put it in the wrong place and cause problems.
  • 224 Answers
Usually in a small port on the door of the dishwasher next to the detergent cup. It should say "JetDry" on it. If not, look for a (usually) gray cap, unthread it, and put the jet dry there. Replace the cap.
Posted on Jun 30, 2009
How to Clear out dish soap from the jet dry resevoir?
Use a shop vac and suck it all out. Then, spray some Pam-type cooking spray grease into the jet dry reservoir and then, A) start a normal wash cycle and stop it a few minutes after it starts the spray action. Then, open the door and look for suds. B) If you see suds, spray them with Pam spray to knock them down and then C) cancel the wash to drain it out. Repeat ABC until all the suds are gone.
Then, whatever you do, DON'T put dish soap in the jet dry reservoir again!
Good luck
Oct 21, 2014 | KitchenAid Dishwashers
Dishwasher does not dispense jet dry. Is full all the time
If the jet dry dispenser is full, it will last you about 3 or 4 months depending on how often you use the dishwasher
Nov 09, 2011 | Maytag Dishwasher
In my GE dishwasher, the jet-dry in the dispenser turned brown. I emptied it all out and refilled it with clean jet-dry, but a few weeks later it was brown again. I guess somehow dirty water is getting...
Had the same problem, opened up the dishwasher, pulled out the jet dry container and found some kind of nasty growth in it. I honestly have no idea what it is, so of course I took a picture, and then threw the whole thing away._1813.jpg
Jul 17, 2011 | Maytag Dishwasher
Cycle isn't using Jet Dry
Open up the dispenser and there should be numbers inside[use a flashlite] change the setting to a higher number and try that!!
Jun 17, 2010 | Hotpoint 24 in. HDA3400G Built-in...
White film on dishes and interior
White streaking is caused by too much rinse agent. (jet dry) Most all dishwashers now have adjustable rinse agent dispensers, so you can set them to a lower setting when you have soft water, and a higher setting if you have harder water. The adjustment is generally right where you add the jet dry. Other possiblilities would be a leaking jet dry cap, or a defective jet dry dispenser.
Apr 16, 2010 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Film on glasses and dishes.using cascade complete and jet dry.Dishwasher is a kenmore elite.
make sure when you fill the jet dry that you make sure it is completely filled. you must add jet dry,close door,lower and raise the door 3 times and then check normally you could add more jet dry because the air is now pushed out by this process. and finally b4 you turn on your machine make sure tolet your faucet run until it hot and then start machine. that should handle the problem. let me know if this helps by sending me a 4 thumbs up post . thanks
Feb 28, 2010 | Dishwashers
Bosch dishwasher leaves water at the end of its cycle cleaned filter and the impeller seams free and not blocked
check for over sudzing. dont use a cascade with jet dry in it. use regular dishwashing liquid and fill jet dry compartment. you can even jet dry level by turning the knob in dispenser.
Nov 12, 2009 | Bosch 24 in. SGS43C12 Classixx...
WHERE DOES JET DRY GO
the turn nob is a cap that you screw out and pour your jet dry liquid in then replace the nob/cap the jet dry will be dispensed automatically.
Sep 29, 2009 | LG Dishwashers
I have suds in my dishwasher. We used cascade and not liquid detergent. I have the Nautilus dishwasher.
sounds like the jet-dri dispencer is leaking and repair is req unless you start to purchase the hanging basket type of jet-dri it will disolve through the normal process don't add anymore liquid jet-dri unit one or the other is done
Aug 23, 2009 | Dishwashers
Beaumark jet dry dispenser
Hi puretonedoug,
I'm Harvey the Master Plumber.
Your question is: Beaumark Whisper Wash IV dishwasher jet dry dispenser does not appear to be working ( not using any jet dry) do they plug up or malfunction, if so how do you get it to repair or unplug?
The liquid jet dry dispencer only dispences a few drops in the last rinse. It is not uncommon for it to go a few months before needing refilling so it may not "appear" to be working. Are there spots on your glasses? That's the real test. If there are then just buy the jet dry that comes in a little basket that you hang from the top rack. Replace when it's empty and forget about the auto dispencer. If the glasses are clear then it's working and don't do anything..
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Oct 13, 2008 | Dishwashers
Dishwashers Logo
154 people viewed this question
Top Dishwashers Experts
