While trying to program a replacement key for my 02 chevy venture the secerity light dose not shut off after 10 min. Could it take longer than 10 min to program? Iv tryed to program it 3 times now with no luck.
Do you have a key faub security type black keyholder that came with it, and numbe 2 do you have a cmmand start, the batteries could be bad in the faub which might do that.
I lost my only key to my 2002 Chevy Venture Mini Van. I replaced the ignition switch. I followed the directions on how to program the new keys that came with the new switch and it didn't work. Does anyone have any suggestions on what to do. Cant afford to take it to a dealership.
PUT KEY IN SWITCH IN ON POSITION FOR 10 MINUTES WITH LED ILLUMINATE.WHEN LED LIGHT TURN OFF YOU TURN OFF IGNITION SWITCH FOR 5 SECS THEN TRY CRANKING IF DONT START TRY THE SAME PROCEDURE TWICE MORE.IF STILL DONT WORK.DEALERSHIP HAS TO DIAGNOSTIC SCANNER TO REPROGRAM IT.
I had that exact code a couple weeks ago. Mine needed new oxygen sensors. They(there are 2, only one was throwing a code, but I had both replaced) cost a little over $100 to have replaced.
check to make sure the security light is not on if it is the van will have spark but no injecter pulse the best way to solve this issue is to have the original igniton key and put it in the igniton in the run position and leave it on for 10 minutes then the light will flash then try to start the van
Take the original key, if you have it. Start the car, kill the car then start it with the new key. This will work for adding a key. If you are replacing a lost key then you will have to learn it to the theft system.Place the key in the ignition, turn it to run for 10 min. Cycle it off then back to run for 10 min. Cycle it off then back to run for 10 moer minutes. When the 30 minutes is up turn it off then try to start it. Thai should work. I have had to do it more than once. Good Luck
i just put a remote start alarm system on my 2002 chevy impala now when i turn the car off the parking lights come on after i turn the ignition off and stay on for like 10-15 min before the goes off but before they goes off they blink 3 times and then shut off .
