Question about Sub-Zero 632 / S
Sub-zero 650, build up of ice in refrigerator on left side only
The temp goes down and says vacuum condensor. we turn it off for a few minuets and temp goes up The build up of ice is a big block on the back side left.
  • tamieb956 Jun 30, 2009
    sub-zero dual refrigeration 650, Vacuum condensor and Ice build up on left side in the back of refrigerator. What might the problem be?
  • 183 Answers
SOURCE: sub-zero 650 / bottom freezer
Clean fluff from condensor, turn off overnight and defrost, turn back on following day should start to work ok within 24hrs. Regards Advisor
Posted on Aug 23, 2007
Rotu
  • 175 Answers
SOURCE: sub zero side by side
yuor sub zero is low on freon in the fridge side. if you call sub zero they will cover the repair, even if its not under warranty, as long as you use anathorized servicer. they had some failures of the evaporater in the fridge that caused the freon leak. Don't let the repair person who comes out tell yu it needs a compressor, that will only fix it temporarily. Good luck!
Posted on Oct 11, 2007
22yooper
  • 828 Answers
SOURCE: Sub-zero Fridge not cooling and ice forming
The leak in the system can be located by a number of methods. First I would look for a slight sign of oil at the point of the leak. 10% of the compressor oil circulates with the refrigerant. Although the refrigerant will leak out as a colorless, odorless gas and be invisible to sight it will leave an oil trace. Electronic leak detectors can detect leaks as small as .5 ounce per year. If the leak is large enough it can be detected with simple soap and water which will form bubbles at the leak point.
Posted on Jun 01, 2008
  • 1462 Answers
SOURCE: Correct temperature for freezer & fridge
fridge should be about +4degC and freezer about -18degC
Posted on Sep 25, 2008
Krazytech
  • 725 Answers
SOURCE: Ice is forming inside the refrigerator
You have a freon leak in you evapator. Call an authorized Sub Zero service company it will be coverd by you sealed system warranty..
Posted on Oct 12, 2008
The ice-cube maker on our Sub-Zero 650 has stopped making ice.
try replace the cheapest part first.( vater valve). you only need 2 components to make ice. water valve and ice maker.is simple and easy water valve located in the bottom part of the unit. remove the kick plate. left side. and color blue. ice maker inside the freezer. (DISCONECT POWER BEFORE SERVICE. ALSO TURN WATER SUPPLY OFF.) try main box , garage. and water meter outside your house. good luck
Apr 02, 2010 | Sub-Zero 650 / O Bottom Freezer...
My vaccume condensor light is flashing and my refrigerator is 55 degrees. I vaccumed the coils on the side of the fan What could be the problem ?
You may need to unplug the fridge for a few hours and let it reset itself. Also make sure coils are clean and there is plenty of air flow to the condensor..
Jul 09, 2009 | Sub-Zero 690 Side by Side Refrigerator
650 sub zero fridge on 54 says needs service... everything warm f
Hi!! looks like you have a seal system problem..First make sure that the condensor motor is on and the compressor and indoor evaporator fan if yes..You have a seal system problem..
Jan 04, 2009 | Sub-Zero 650 / O Bottom Freezer...
Subzero model 650 refrigerator
If the light keeps coming back on and temps are rising in the refer section, then you most likely have an evaporator leak. Check to see if you see either a moist spot or ice on the back wall on the left side of the back wall of the refer. If you do, it's definetly a leak. Call a authorized Servicer.
Jun 08, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub Zero 550 Frost Build up in Refrigerator
This means you are low on freon. You will get an ice ball on the bottom left side in the back of refer.
dartmanc
May 27, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub-zero 650 / bottom freezer
Aug 09, 2007 | Sub-Zero 650 / O Bottom Freezer...
Sub zero frig
First check the condenser up top behind the grille and on the right side. If it is clogged with dirt, shut it down and use a vacuum to remove the dust. If tis clean then look at the display. Does it read "service" or "vacuum condenser" Also, whhat temp does the freezer read on the display? Lastly is it saying anything like "EC40"? These may be clues as to the problem. Let me know about this and I can give you more help if necessary. Good luck!
Jul 05, 2007 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 632 / S Logo
74 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
