Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Mitsubishi WD-62525 Picture with overall red tint and artifacts
Periodically when TV is powered on the overall picture will be reddish - this may last for 30 min. and then correct itself or may last over the course of a couple of days and then correct itself.
I have hesitated to change the lamp - any advice
    Genius:
  • 1,153 Answers
Do self diagnosis test first
Posted on Dec 16, 2007
I have a mitsubishi wd-62525 the power light keeps blinking, and i can't get picture. i unpluge it than want 2min than it stop blinking and i can turn to tv on and get a picture than after 30-40mi
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 06, 2012 | Mitsubishi WD-62525 62" Rear Projection...
I have a Mitsubishi TV Model# wd-62528, the red light comes on on the lamp light
Need to replace a new lamp. Or if you still see picture, go to menue and reset lamp. I f no picture, need to replace a lamp.
May 09, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Where does new bulb for picture go inside the TV?
The bulb is in the front of the TV. Remove the front lower cover by pulling oneside at a time. There will be a lable next to the cover for the light housing.
Feb 09, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Seeing double picture red and blue tint what to do
Howdy,
Uneven colors with multicolored lines in the center of the picture and/or flashing, may also shutdown with a red lamp LED. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if low or missing check C9A37 and C9A38 both 3300 UFD 10 V part # 181P732040 on the Power PCB (part # 930B921002
Good Luck, big IRISH.
Jan 02, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Scrolling lines
problem with the Picture tube.set graphics properties to check.
Jul 06, 2009 | Mitsubishi WD-62525 62" Rear Projection...
I have Mitsubishi WD-62525. Last week I turned TV on and there was no picture, on green horizontal lines across the screen. The picture then went black and I only have sound. The lamp indicator lite turned...
that is a common problem with that model you will need the v26 power pwb repair kit and the V26 FMT pwb repair kit. You can get both kits at the following link which includes the replacement capacitors and instructions on where the capacitors are located. Heres the link.
http://servicemanuals.vstore.ca/
Sep 26, 2008 | Mitsubishi Televison & Video
Mitsubishi WD-62525 DLP has no picture
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Feb 03, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mits 62525
take the lamp back out and reset the lamp
Dec 27, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
106 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
