Question about Minn Kota Maxxum 70 Freshwater Bow Mount Trolling Motor
The foot control speed slide is erratic it will stop sometimes
When speed is increased, speed will vary even at the same setting. batteries are good.
The potentiometer that varies the speed is probably dirty. Try spraying some "electrical cleaning solvent" into the pot as you move the control. If this doesn't help, you will probably have to replace the pot if you can find one or replace the speed control.
Good luck.
Posted on Jun 30, 2009
How do I slow the speed of the machine down in order to quilt
use a smaller stitch. DO NOT PUT YOUR FOOT ON THE PEDAL SO HARD
Jun 28, 2015 | Sewing Machines
Stalls sometimes when stopped at lights engine misses at stop
Engine stalling and rough run issue at low speeds
This problem is commonly caused by a dirty automatic idle speed control valve and throttle valve. Buy a can of throttle valve cleaner (do not use carburetor spray cleaner!) from NAPA or Carquest (made by CRC chemicals) and spray it into the air intake while the engine is running, use up about 1/2 the can, engine will try to stall hold the speed up, shut it down and let it soak for 30 minutes, restart and blow out the remaining fluid, shut it down and disconnect the negative battery cable for 5 Min's to reset the base idle control
Sep 04, 2012 | Cars & Trucks
BMW Z3 3.0 year 2000 erratic tickover problems
You can in most cases repair this by cleaning the engine throttle valve and the idle speed control valve using a product called CRC Spray Throttle valve cleaner. Spray the cleaner into the air intake of the engine with the hose removed from the throttle body, the engine will try to stall so hold up the idle speed manually. Once you have used up about 1/2 can of the cleaner stall the engine out while spraying and turn the key off, disconnect the negative battery cable for 5 minutes and then reconnect and drive the car for a about 25 miles of varied driving modes. If this doesn't cure the problem you may need the fuel injectors professionally cleaned by the dealer service dept.
May 05, 2017 | Cars & Trucks
Beginner sewing leather. Need to slow down machine
Hi lesimpson...
If you need to slow your sewing machine down I would recommend that you purchase a foot controlled rheostat.
You can vary the speed of the machine by pushing down on the foot pedal and it will increase your speed from slow to fast the farther you push down.
I will include a webpage to see one.
Please take time to rate me
http://www.nextag.com/sewing-machine-foot-control/shop-html
Aug 13, 2011 | Garden
Machine wont stop once started.
your foot pedal is just like an accelerator , lifting and pressing the foot increases and decreases the speed ,but if this does not happen ,,change your foot pedal
Mar 18, 2010 | Singer Sewing Machines
I need to know how to thread a bobbin?
TRY THIS, itma not be your model, but should help Title:
ac093.jpg Pre-tension disk ac094.jpg Bobbin winder shaft ac095.jpg Bobbin
1. Pull up the spool pin as far as possible, and then put a spool of thread on this pin. windingbobbin_a0991.jpg
2. Pass the thread around the pre-tension disk. Make sure that the thread passes under the pre- tension disk.
windingbobbin_a0992.jpg ac098.jpg Pre-tension disk c_b4.jpg Pulling it in as far as possible
Caution If the spool of thread is not in the right place, the thread may tangle on the spool pin.
3. Pass the end of the thread through the hole on the bobbin from the inside of the bobbin. windingbobbin_a0993.jpg
4. Put the bobbin onto the bobbin winder shaft and slide the bobbin winder shaft to the right. windingbobbin_a0994.jpg
5. Turn the bobbin clockwise, by hand, until the spring on the shaft slides into the groove of the bobbin. windingbobbin_a0995.jpg ac099.jpg Spring on the shaft ac0991.jpg Groove of the bobbin
7. While holding the end of the thread, gently press the foot controller or press start/ stop button (for models equipped with the start/stop button) to wind the thread around the bobbin a few times. Then stop the machine. windingbobbin_a0997.jpg
Note
  • If the sewing machine is to be operated using the foot controller, connect the foot controller before turning on the machine.
  • When the foot controller is plugged in, the start/stop button cannot be used to start sewing (only for models equipped with the start/stop button).
Caution Make sure you follow the instructions carefully.
If you do not cut the thread completely, and the bobbin is wound, when the thread runs low it may tangle around the bobbin and cause the needle to break.
9. Slide the sewing speed controller to the right (to set the speed to fast).
(For models equipped with the sewing speed controller.) windingbobbin_a0999.jpg ac0992.jpg Sewing speed controller
10. Press the foot controller or press start/stop button (for models equipped with the start/stop button) to start. windingbobbin_a18.jpg
11. When the bobbin seems full and begins spinning slowly, take your foot off the foot controller or press start/stop button (for models equipped with the start/stop button). windingbobbin_a19.jpg
12. Cut the thread, slide the bobbin winder shaft to the left and remove the bobbin. windingbobbin_a191.jpg
13. Slide the sewing speed controller back to its original position (for models equipped with the sewing speed controller). windingbobbin_a192.jpg
Caution Not winding the bobbin properly may cause the thread tension to loosen, and may break the needle.
woundbobbin3.jpg ac0993.jpg Wound evenly ac0994.jpg Wound poorly
Note
  • When the sewing machine is started or the handwheel is turned after winding the thread around the bobbin, the machine will make a clicking sound; this is not a malfunction.
  • The needle bar does not move when you slide the bobbin winding shaft to the right.
Sep 02, 2009 | Brother LS-2125 Mechanical Sewing Machine
Erratic Flickering of all electric devices (headlights, dashlights, AC)
Did you use a Delco rebuilt Alternator? The ones you get from so called discount auto parts stores are junk and they may be the cause of this problem, monitor the output of the system with a DVOM meter, does the voltage fluctuate? Have you check all the chassis grounds? They are the biggest source of this type of issue when the Alt. is ruled out.
Apr 21, 2017 | 2000 Chevrolet Lumina
Engine rpm varies erratically
try fuel injector cleaner in your next fuel fill. sounds lke your injectors are dirty
Feb 28, 2009 | 1995 Toyota Corolla
The cruise control on my 1993 Honda Accord LX, automatic 4 cylinder works sometimes and sometimes not. It worked three days ago. It wouldn't work the next day. The following day it would. Now it won't...
Sounds like possibly a safety switch associated with the brake or shifter is engaging intermittently. There is definitely one behind the brake because when you apply the brake the cruise kicks out. Try looking for this switch and check it out.
Nov 21, 2008 | 1993 Honda Accord
Minn Kota Maxxum 70 Freshwater Bow Mount Trolling Motor Logo
237 people viewed this question
Top Minn Kota Boating Experts
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Colin Stickland
Colin Stickland
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
