Question about Sony Playstation 3 (PS3) Console
I cant play online on my ps3. DNS problem.
I cant play online on my ps3. my ip address is accepted but i always get a dns error i have tried everything please someone help. i have time warner.
  • martinbaldil Jun 30, 2009
    I am not exactly sure what a router is but i have time warner and the gave me a box that i think is a router. but i have tried every piece of advice people have posted on the site and none of it works. i have my ip adress which is accepted but i get the dns error. i have tried multiple dns numbers and none of them work. im using the same ethernet cable on my ps3 that im using for my computer which allows me access to the internet so i dont no if that has n e thang to do with it but i have tried everything and i really want to play online hope u can help
    Martin Baldillez
  • Richard Tirado May 11, 2010
    Is a router involved?
  • 38 Answers
Try restarting the router and then try it . then see if u can update ur system by the computer.
Posted on Jun 30, 2009
On ps3 coming up as dns error
The settings on the ps3 are wrong by the sound of it. You should have the dns set as the address for your router, that in turn should use the dns from your isp.
so say you router is 192.168.1.1
then your ps3 settings should be something like:
ip address: 192.168.1.2
gateway: 192.168.1.1
dns: 192.168.1.1
subnet mask: 255.255.255.0
Replace 192.168.1.1 with your routers actual IP address.
The ip address can be any unused address from 192.168.1.1 to 192.168.1.254, unless you've restricted the address range,.
Gateway just means your router.
Subnet mask tells the computer what network to send data on, always the same unless you're using more than one network connected together.
Hope this helped.
Nov 26, 2010 | Computers & Internet
PS3 DNS error (80710102)
see i hav the same prob try putting this in
primary dns 208.67.222.222
secondary dns 208.67.220.220
ip address 192.168.1.45
if that dont work people say u should unplug your router 4 a couple of minutes then plug it back in
Aug 22, 2009 | Sony Playstation 3 (PS3) Console
PS3 says DNS error (80710102) when i try to connect to the internet with a wired connection
Goto the command prompt bar in the start menu type ' cmd ' then click o.k . A black dos screen will appear type in ' ipconfig/all ' and it will the the two servers you need under dns servers but if your doing a wired connection to your ps3 then you need to manually configure your dns on the custom method of setting up your internet connection on your ps3 as if this is auto config that will give you a dns error. Hope that helps ,I can go into more detail and guide you through it if need to .
Jun 02, 2009 | Sony Playstation 3 (PS3) Console
Dns error when connecting how do I fix this
Unstable connection. if you have wireless connection that could be a problem depending on your environment. Try turning off your firewall too by calling your internet server(Comcast,DSL,etc.)
Jul 31, 2008 | Sony Playstation 3 (PS3) Console
Cant get internet connection on my ps
first check wether you received a valid ip address for your local network. usually, this should be something like 192.168.x.y. if so, then you might indeed face a dns issue. dns is used to resolve web site names to ip address. usually, your ip service provider will broadcast the external dns servers for your router to recognize.
try to connect with a computer first. if it works, check the ip settings. if your computer also cannot connect without explicit dns server settings you can do one of the following:
- explicit dns server address in ps3. go to "advanced internet connection settings", and then to "dns settings" and set the dns server address
- purchase a 30$ network router and hook it between your internet and the ps3. in the router settings, set the dns server address to be broadcasted to the clients. you can use 168.126.63.1 and 2 which are dns servers in korea (i live in korea), but you might want to find the server near to your location or promoted by your isp
Jul 28, 2008 | Sony Playstation 3 (PS3) Console
Cant get internet on ps3
make sure that the ip address that you are getting is a valid one and you are connected to the correct wireless network. for example, if your router's ip address id 192.168.1.1, your computer should have an ip address of 192.168.1.x. if you are getting a valid ip address and you're still getting the dns error, the thing that you can do is set a static ip address and dns to your ps3.
if you don't know the dns to use, go to the command prompt and type ipconfig/all and it'll give you a list that'll contain the dns servers. copy the dns and enter it on the ip settings of your ps3 together with the default gateway (ip address of the router), subnet mask (it's usually 255.255.255.0) and your ip address (make sure that the ip address that you'll set on the ps3 is not being used by any of your computers)
hope this'll help you and just ask me if your still having any problem
ciao!
Jul 05, 2008 | Blitzz Technology BWA711 (B3WL000900)...
80710092
dns error, try entering the following in your ps3. Settings - Network Settings - internet connection settings - custom - wired or wireless depending on your internet - manual settings - IP address manual - enter your ip address and your router address and change your dns primary 208.67.222.222 and secondry 208.67.220.220 this will enable you to go online as for the error code 80710092 i have no idea, im experiancing the same problem. its so frustrating. as soon as i find the answer i will let you know.
Apr 14, 2008 | Sony Playstation 3 (PS3) Console
What dns numbers work
You'll need the IP address of your DNS server. Which would be either your router or the IP address of the DNS Server from you ISP.
You should make sure everything is connected properly. Set all settings to automatic.
Let me know if this helps.
Greetings,
DarkNeogen.
Feb 05, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
318 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
