Question about Napoleon Auburn Pellet Stove Heater
Auger not turning
The auger is not turning. Is there a reset on the motor?
  • Anonymous Mar 16, 2014
    Auger not working when stove is lit
    President:
  • 1,723 Answers
The auger motor is fed through a high temp. limit thermostat. It has a manual reset on the back of it that you have to press on firmly to reset it. Open the side panel on the stove and find the wiring. You will see the thermostat on the back side of the combustion chamber. Look very closely and reset it.
good luck!
Posted on Jul 01, 2009
    Problem Solver:
  • 10 Answers
If u can hear auger motor coming on every few seconds but auger is not moving take side panel on left side and u will see auger motor shaft and there is a bushing with a set screw in it tighten this set screw
Posted on Sep 28, 2009
3 Suggested Answers
protek480
  • 1723 Answers
SOURCE: AUGER IN PELLET STOVE NOT CONSISTANTLY TURNING
The auger motor is fed through a high temp limit thermostat. It has to be manually reset if it activates but it could be causing your problem with a bad connection or intermittently bad. It deserves a look...
protek480
  • 1723 Answers
SOURCE: auger on pellet stove doesn't turn
The thermostat inside on the back of the combustion chamber has a manual rest that needs to be pushed and reset.
Posted on Jul 08, 2009
Hopper auger will not stop
How to Repair a Pellet Stove Auger That Won't Turn ' Home ...
homeguides.sfgate.com > Outdoors > General Repair
Cleaning the hopper, removing and replacing the auger and installing a new motor and ... Most pellet stoves do not have a removable auger cover, but you can see a ... youcan hear the motor attempting to spin the auger, turn off the auger and ...
Why wont my Auger feed pellets? ' Hearth.com Forums Home
www.hearth.com > ... > The Pellet Mill - Pellet and Multifuel Stoves
Jan 6, 2008 - Two #1 reason auger motor will not operate is: PRESSURE ..... Hopperlid trip switches now used on some stove will stop the auger and on the ... Harman Auger will not stop.
Oct 11, 2015
auger won't turn on Lopi Leyden
Oct 14, 2013
harman accentra will not turn off
Dec 31, 2011
Harmon Accentra feeding continually but no ignite
Jan 14, 2008
More results from www.hearth.com
Whitfield pellet stove repair, pellet stove repair, auger re
Jan 10, 2016 | Pool & Spa
Frigidaire frs6lf7fm. Ice maker dispenser, the auger won't turn (tested with ttay out). It makes ice and dumps it into the bin no problem. And the water side is fine.
[FIXED] Icemaker auger motor won't turn - ApplianceBlog
www.applianceblog.com/.../18196-FIXED-Icemaker-auger-motor-won-t...
Apr 16, 2010 - 9 posts - ‎2 authors Does the auger motor need to be re-set or something? I wonder if it shut itself down to prevent burnout (because it had been unable to turn the ... FIXED Auger won't turn to dispense ice.
Jun 1, 2014
Ice maker auger will not turn
Mar 17, 2013
FIXED Ice Auger won't turn
Sep 3, 2012
GE Icemaker: Makes Ice, Doesn't Dispense In Door?
Apr 19, 2005
More results from www.applianceblog.com
Oct 01, 2015 | Frigidaire Refrigerators
How do i fix ager on my pellet stove?
Hello Ethan, First I would uncouple and remove the auger motor from the auger shaft. Next turn the stove on to see if the auger motor turns. If it does turn, try to hold the motor shaft with your hand to determine if the motor has sufficient torque to turn the auger. If motor seems to be strong enough , use a pair of pliers or a vise grips and try to rotate the auger shaft. If the auger will not turn, it might be clogged up with pellets or pellet dust. The clog will have to be removed. If that is the case, I think the gears in the motor are stripped and a new motor is in order. Note: Damp pellets swell up and turn hard as concrete when they dry out.
Dec 06, 2013 | Home
The ice maker will not dispense any ice. When the dispenser lever on front panel is pushed the dispenser door opens but the auger motor does not operate. If I thaw the freezer the auger motor will...
It sounds like your auger motor has an issue in my opinion. How i check them is: remove ice bin, open freezer door, hold door switch down, depress the freezer ice dispenser button on the door and see if the auger motor has the torque when it turns, if the motor has power and turns but cant turn w/ torque or has power and dosen't turn. you need a new auger motor. lmk if u need more help!
Aug 04, 2013 | Frigidaire FPUS2686LF Professional 26 Cu....
Whirlpool side by side ref auger froze up. will not turn.is there a reset button?
The auger motor is not very powerful, so if you have ice build up in the bin, it can hold the auger motor immobile. Suggest you take the ice bin out and completely defrost and dry before putting back in.
Feb 06, 2012 | Whirlpool ED2FHEXN Side by Side...
Icemaker is making ice but the ice dispenser is not working
Check the ice storage container. The ice dispenser will not dispense ice until the first supply ice has dropped into the ice storage container.Remove excess ice from the back of the ice container. Make sure ice cubes are not jammed between the ice maker and the back of the ice container.
The auger won't engage or turn to dispense ice.Remove the ice bucket and with a hair dryer warm up the inside where the fork is that turns the auger in the bucket and try it and if this does not help then you will have to replace the auger motor ,, chances are the motor is just froze up .--------
If there is nothing jammed then try this./Remove the ice bin out.And then clean the ice bin.
Rotate the auger with your hand.If its hard then there is problem with auger motor.If the auger is not rotating fine then its faulty auger motor or the auger motor is frozen,if you notice ice getting collected there.
Take a hair dryer and blow hot air on the auger motor for few minutes.Take care you dont blow hot air continuously.
But if that is not helping then disconnect auger motor connecting wire wait for 2 minutes clean the connector and reconnect the connector back and see.If that is not helping at all.Then,replace the auger motor.
To see how auger motor looks.Please click the link below:---
http://www.appliancepartspros.com/part_details_lgimg.aspx?part_id=3965455&image=0
You can get required parts from sears part direct online site or from repairclinic.com site.
This will help. Thanks. Helpmech.
Feb 21, 2011 | Frigidaire FRS26H5AS Side by Side...
GE refrigerator model GSS22 WGMD ice maker motor
If you cant manually turn your auger motor, it may be bad. Does it dispense solid ice or no ice at all? Another thing may be your control panel. That could be bad too, it's the one sending juice to both your solenoid and auger motor.
Jul 09, 2009 | GE Profile PSW26P Stainless Steel Side by...
Jan 16, 2009 | Napoleon Auburn Pellet Stove Heater
Ice dispenser not working
Pull out auger & try With Out auger in place with door open and see if auger motor will spin with out auger and tray IN.. you with have to push door switch in to get auger to work .. with door open
Sep 12, 2007 | KitchenAid Architect ® Series II KSRX25FT
Napoleon Auburn Pellet Stove Heater Logo
1,236 people viewed this question
Top Napoleon Pool & Spa Experts
John Rodgers
John Rodgers
Craig Butler
Craig Butler
Paul Carew
Are you a Napoleon Pool and Spa Expert? Answer questions, earn points and help others
