Question about OKI MICROLINE 320 Turbo Matrix Printer
Oki ML 320 Turbo/D IBM - JetDirect 170x Print Server prolems
I connected the Oki 320 printer to the Jetdirect 170x print server and was able to send print jobs to it however, the printer will only print a portion of the job and then quits. While the p/s seems to be thinking (the activity light blinks) the printer never starts back up until the printer is shut off and turned back on. It is almost like it is running out of memory or something.
The print server seems to be working correctly and i am using the built in Windows driver through XP (Okidata ML 320 Turbo/D IBM) which is the same driver I am using for the printer when it is shared via an XP machine which works just fine.
Any suggestions?
  • 221 Answers
Re: Oki ML 320 Turbo/D IBM - JetDirect 170x Print Server...
I just had this exact same problem - same printer, same Jetdirect model. Mine turned out to be the parallel printer mode setting inside the JetDirect. I connected to the configuraiton page by IP, then changed the Parallel mode from "AUTO" to "Centronics", tested it, and it worked fine after that. Hope it helps.
Posted on May 11, 2009
Check the receive buffer on the Oki. I usually set it to the highest (88k or 128k). You might also check the print head gap if you are printing multi part invoices. If the print head is too close it may overheat and stop printing. If you have a different printer, swap it out and see if it prints correctly. It may be a problem with the JetDirect 170x, not the printer.
Posted on Jan 23, 2008
0 characters
3 Points
Can i make a hp2420d a network printer
You can purchase a jetdirect network card from Ebay. Any model will work, a 610 should not be too expensive these days. Or you can purchase a USB network print server and connect the printer to the USB port on the printer and then connect the print server to your network.
Aug 10, 2014 | HP Printers & Copiers
I have doubt purchasing HP CP3525n LaserJet printer. Can I connect this printer directly to my Linksys SR224 switch with its built-in jetdirect? Or I need to purchase a print server before it can be...
Hello You can connect yo printer with the router, because it has the capability to connect with network , no need to purchase print server,
if you have heavy load of printing over it then print server is necessary.
Good luck
do rate if helped
Dec 02, 2010 | HP CP3525N Color LaserJet Printer
HPLJ P3005x Error
The HP Jetdirect embedded print server has
encountered a critical error.
● Turn the device off and then on.
● If the problem persists, contact
HP Support.
Sounds like it's more than memory failure.
Sep 17, 2009 | Printers & Copiers
I have a HP OfficeJet K60 printer. I have a Linksys WRT54G V8 broadband router. I would like to set up printer so that I can print from my laptop without connecting the print cable to the laptop.
Do you have the jetdirect print server attached to the printer? If so, follow the instructions for the print server setup before connecting to the broadband router
Jun 07, 2009 | HP OfficeJet k60 All-In-One InkJet Printer
HP DesignJet 450c printer issues.
You can purchase a External JetDirect card from any reputable HP (or computer) agent. This will allow you to plug the 450 directly into the network. The problem with the large format printers not being supported is strange to me. I have never had a problem, simply load the drivers and away you go. If the 450 drivers dont work for you, you can select any of the older drivers (750c recomended) and they will work on the 450c
Feb 26, 2009 | HP DesignJet 450c InkJet Printer
HP J5780 - Using scanner with print server
yes. this printer can be use for wirelss connection, so it can be use with wired jetdirect. however, you are going to need the web jetadmin from hp in order to reconfigure the IP address for the jetdirect.
you can download a copy form
Jan 13, 2009 | HP Officejet J5780 All-In-One InkJet...
Only printing tasks from some computers
Print the Menu Setting out on printer and menu setting out on pc. Match sure emulation matcheds on both sides. If using serial make sure serial settings match on both sides. If parallel, check the bois on the PC, change parallel port type to EPP instead of ECP or SPP.
Feb 13, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Printer Stopped Printing
If you can get a test page this indicates that there is nothing wrong with your printer there should be a little button on the jetdirect box press that and that will give you the jetdirect settings and IP code. Check this with you computer system as your IP host license may of expired and change the jetdirect to suit.
If the network IP code is still the same the cheapest this is to fit a new jetdirect box if this still doesn't work then I'm affrayed that the machine formatter board has become faulty and would probberly out way the cost to repair it that buy a new machine.
I do hope this has helped you
Thanks J
Dec 18, 2007 | HP LaserJet 1300 Printer
OKI MICROLINE 320 Turbo Matrix Printer Logo
1,780 people viewed this question
Top OKI Printers & Copiers Experts
Level 1 Expert
Dominion Computer...
Are you an OKI Printer and Copier Expert? Answer questions, earn points and help others
