Question about Samsung Katalyst SGH-T739 Cellular Phone
Samsung katalyst lcd screen replacement directions
I have a new lcd screen for my samsung katalyst, where can I get directions on replacing it?
SOURCE: Samsung D900i LCD Replacement
http://www.scribd.com/doc/280355/samsung-SGHD900i-service-manual
Posted on Feb 14, 2008
SOURCE: fitting instuctions for replacing lcd screen on my samsung e250 mobile phone
ok...
1.take off battery cover, remove battery, memory card and sim card
2. remove the five screws on the back... two at the bottom, two in the middle and one on the mid top right and take off this cover, remember! keep the screws safe
3. slide the phone up and take out the two screws on the left and right paralel with the battery tabs then remove the two screws ether side of the camera...they might be covered by rubber coverings, these pop out easily
4.now you can prise the top of the screen off with a small flat headed screwdriver
THERE ARE TWO OPTIONS HERE, IF THE REPLACEMENT SCREEN HAS NO RIBBON CABBLE ATTACHED THEN FOLLOW FROM FIVE, IF IT HAS ONE CONNECTED THEN FOLLOW FROM
5. its conected to a ribbon cable, remove the tape and slide out the cabble from the screen.
6. now take out the screen PCB from the plastic casing and replace it with your new one and put the ribbon cable in and clip it back together, now reverse stages 3 to 1 to put it back together.
7. if the ribbon cable is attached now you must look at the PCB board on the back for a square copper line, on the left of this there is a big black square just smaller than the copper square, prise this off with your finger nails, keeping it to the side take the PCB up about 2mm and then fold the bottom of it to revele it is conected to a ribbon cable by a bigger version of the black square so prise this off and take the PCB and put it safely to one side.
8. look on the front of the phone under the top bit of the screen, there should be a semi circle in the plastic with a black circle in the top of it, use your nail or a flat headed screwdriver to pop it to the other side of the semi circle, now the slider should go past what it used to o you can slide it up to when you can see the ribbon cable go down through the phone, now push the black square end through and you should be able to slide the whole front off.
9. replace the screen by taking the screen PCB out and repacing it, then thread the ribbon cable back through and slide the front on while making sure the back circle goes into the semi circle and to the top side of it, then thread the black square through the phone to the front and clip the phone front back on.
10. snap the black square back on to the back Circuit then put the circuit back into the phone and snap the small black square back on then go from stages 3 to 1 to put it back together.
this should be fairly easy to do for most people.
Posted on Mar 04, 2009
soultrip
  • 103 Answers
SOURCE: samsung katalyst will not turn on or charge it
Sometimes its the charging port that breaks and won't allow it to charge, if that's the case, you'll either have to live without it for a few days, or buy a new phone.
But if its the battery, you can buy a new one online at many different stores, try searching around to find the best price.
Posted on Sep 22, 2009
  • 11 Answers
SOURCE: I need to replace the lcd screen in my Samsung Impression.
take it to the service
Posted on Jan 23, 2010
SOURCE: my samsung katalyst screen is reversed. it's fine
I'm told this can happen if your memory is too full or the cable between the computer and the screen is dying. I don't know how to fix it. You might have to take it to a cell phone repair place or T-mobile if you still have your warranty. My Katalyst had the same problem for a couple weeks. Today the screen went completely white and restarting it hasn't fixed the problem. Hopefully I'll be able to hold out another 3 months until I can get a deal on a new phone.
Posted on Jan 26, 2010
Unlock provider code for samsung katalyst t739
You will be able to unlock it here.. http://www.superunlockcodes.com/samsung-sgh-t739-katalyst/rs12wp9/
They will provide you the code once when you enter your imei number there. You need to just check your phone model and service provider.
Aug 02, 2010 | Samsung Katalyst SGH-T739 Cellular Phone
Need unlock code for sgh t739 samsung thanks
unlock codes are not free.. for Samsung phones you need to bring or send your phone to our shop for unlocking.. we use Special Gadget tools & cables
or Remote Unlocking by IMEI+operator
direct unlock, no downgrade, flashing or formatting. (100% safe/professional)
We Openline All kinds of Samsung phones
email: unlocker_ph@yahoo.com
+639393688886
Mar 12, 2010 | Samsung Katalyst SGH-T739 Cellular Phone
How do i master reset my samsung t739 phone
From the standby screen enter:
*2767*3855# You had better mean it. Once you enter the # there is no turning back. Your Katalyst will be returned to its factory condition.
Feb 07, 2010 | Samsung Katalyst myFaves Cellular Phone
My samsung katalyst screen is reversed. it's fine
IM not seeing an answer here but am having the same problem,
any suggestions anyone
Oct 14, 2009 | Samsung Katalyst SGH-T739 Cellular Phone
Samsung katalyst will not turn on or charge it just brings up the katalyst screen and turns off
Sep 22, 2009 | Samsung Katalyst SGH-T739 Cellular Phone
LCD Screen is will only display a white screen.
The inner screen cable contact would have got loose. You can carefully open the casing to reconnect the cable, or you can take it to a service center to get it fixed.
Aug 06, 2009 | Samsung Katalyst SGH-T739 Cellular Phone
My screen is white and i can only see white.
Hopefully the screen connection might have loosened. If your confident with hardware, just open the screen connection and refit it. If it works, fine! else screen will have to be replaced.
Apr 10, 2009 | Samsung Katalyst SGH-T739 Cellular Phone
Reset katalyst sgh-t739
I did additional research and found the appropriate code which worked immediately.
Dec 02, 2008 | Samsung Katalyst myFaves Cellular Phone
Samsung Katalyst SGH-T739 Cellular Phone Logo
312 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
