Question about Peg Perego Vespa Scooter
2006 lx50....spark plug doesnt fire...is it the spark plug??? Randall
  • Peg Perego Master
  • 706 Answers
It can also be the coded key (blue or brown keys only) sends no signal to open up the antitheft lock - there is a small red indicator on the instrument panel (see owner manual) 2006 lx50....spark plug doesnt fire...is it the - cff7b72a-c6fb-4662-aad3-40dbf63c25fb.jpg
Posted on Sep 28, 2014
  • 174 Answers
Hello randall,
It may be the plug. It is an easy test because plugs are only about $5. It could also be the plug wire or the coil. Is it a new problem or has it been getting worse?
Posted on Jun 30, 2009
Replaced the CDI unit, new spark plugs, but still one spark plugs will not function, only the three spark plugs is running. why?
Mark the one not firing. Now swap it out with one that fire. Does it fire now. If No then you will need a new CDI.If it doesnt then you have a wire issue. also check spark plug wires.
Apr 21, 2011 | 1996 Toyota Corolla
What is the firing order for spark plugs on a 2006 Pontiac Vibe?
1.8L (LNK)Firing Order
1-3-4-2
Spark Plug Torque
18 N·m
13 lb ft
Spark Plug Gap
1.0-1.3 mm
0.040-0.051 in
Spark Plug Type
SK20R11 DENSO
1.8L (LV6)
Firing Order
1-3-4-2
Spark Plug Torque
25 N·m
18 lb ft
Spark Plug Gap
1.0-1.2 mm
0.040-0.048 in
Spark Plug Type
SR16R11 DENSO
Thank you and enjoy,
Lee
Sep 27, 2010 | 2006 Pontiac Vibe
Firing Order diagram for 2006 Ford Explorer
Hope this helps. The ignition coil:
  • changes low-voltage pulses from the PCM to high-voltage pulses.
  • fires 2 spark plugs simultaneously.
  • has 3 transformers.
    • One transformer fires the spark plugs for cylinders 1 and 5
    • One transformer fires the spark plugs for cylinders 2 and 6
    • One transformer fires the spark plugs for cylinders 3 and 4
Spark plug wires:
  • carry high-voltage pulses from the ignition coil to the spark plugs.
The spark plugs:
  • change high-voltage pulses to spark at the gap, which ignites the fuel and air mixture.
The firing order is 1-4-2-5-3-6.
Jun 06, 2010 | 2006 Ford Explorer
2006 f150 firing order
For the 4.2L:
Firing Order:
1-4-2-5-3-6
Cylinders:
3----------6
2----------5
1----------4
(Front of Vehicle)
Let me know if this helped, or if you have additional information or questions. Feel free to contact me at FixYa.com!
Feb 20, 2010 | 2006 Ford F-150
Hi i have a good spark on all cylinders and carbs are all set correctly but as you sit on bike and look down left hand cylinder is not fireing and keeps flooding
Just because a spark plug fires outside the motor doesnt mean its firing under compression. Start by making sure you have new spark plugs. If that doesnt help then do a compression test on all cylinders and compare.
Nov 23, 2009 | 1970 kawasaki Mach III H 1A
2006 lx50 still won't start. Changed the plug and still no spark. Should I just go ahead and replace the wire and coil? Anybody?
put your finger on lead and turn her over-that should answer if magneto is cranking any power to your plug-ps wear rubber boots and hang on to your best mate!lol
Jul 04, 2009 | Peg Perego Vespa Scooter
Peg Perego Vespa Scooter Logo
536 people viewed this question
Top Peg Perego Toys Experts
Adam Fjeld
Adam Fjeld
Gary
Gary
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
