Question about Oregon Scientific Electric PTO Clutch for Cub Cadet, MTD and Warner
Cub Cadet PTO will not engage
The PTO on my LT1050 will not engage. I have jumped wires from the battery to the PTO and it works fine that way. I am assuming that it could be the PTO switch, the Reverse Overide, or a safety switch. I have checked all of the safety switches first and they seem to be fine, however, I only know of two. The seat switch, and the reverse switch.
1.) Are there more than two? If so, where are the others?
2.) The reverse Overide will not light up. Could that be a safety switch problem, or should it light up anyway regardless of the safety switch condition?
  • 218 Answers
Do you have a volt meter or a 12 volt test light?..if you do you can see where you are losing your voltage at..but i would suspect the PTO switch is bad..i hope this has helped.....Keith
Posted on Jun 30, 2009
Fuse keeps on blowing when I engage the cutter deck
Check that a wire has not been cut. Check the PTO clutch wires as well.
I’m happy to assist further over the phone at https://www.6ya.com/expert/christopher_722ea729aae6fd07
Sep 28, 2015 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Looking for the sensor schematics for a cub cadet series 1000, LT1050 hydrostatic lawn tractor. anyone help me?
Try looking at the directional lever at the Transmission. The PTO for the deck will shut off when shifting into reverse. You may have to simply disconnect or jumper the reverse switch depending on if it is normally closed or normally open. Try it both ways to see what works. Also check the engine oil level, The low oil level switch will shut the engine down if more than a quart low.
Feb 27, 2018 | Cub Cadet Lawn Mower Deck Drive Belt...
Pto wont engage when mower is hot
Hi
your PTO is built just like a wound up coil and becomes magnatized it gets real hot and it shorts out when it heats up make sure you have no frayed wires which will creat a large risistance and really heat up
Joe
Sep 09, 2012 | Cub Cadet Lawn Mower Blade Drive Belt CUB...
Pto will not engage on lt1042
check for power and ground going to the clutch if so look under the machine i have seen a few break the wires near the clutch
Jul 08, 2012 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
PTO will not engage onLt 1046
check the safety switches start with the one on the seat
Jun 04, 2012 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
My LT1045 blows the 20 amp fuse when the Electronic PTO is engaged.
you have to start with the switch and see if its faulty
see if you can replace it temp with a toggle switch
and check the wiring back to the pto as well it mite be grounding out
If not any of these then its in the pto its self
Jul 17, 2011 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
I have a 1999 cub 2135 with a kohler engine. the mower deck wont kick in . i ran a hot wire to the pto & it worked .do i have to replace the switch or the module. i also checked the seat switch &...
IF connecting that one hot wire to the pto made it engage then you either have a broken/cut/bad connection/wire to the pto or the switch is bad.
What you did by using the hotwire to the pto is bypass all the wiring and the switch for the pto.
You can determine if it's the switch real quick if it only has two connections/wires to the switch. Pull the switch, remove the wires and touch them together, after you have the mower in the condition under which the pto would engage. If the pto engages it's the switch for sure.
Take all the proper safety precautions. Don't let the wires touch anything else.
Sep 29, 2017 | Cub Cadet Lawn Mower PTO Clutch Replaces...
Oregon Scientific Electric PTO Clutch for Cub Cadet, MTD and Warner Logo
5,261 people viewed this question
Top Oregon Scientific Garden Experts
Dennis Key
Dennis Key
Colin Stickland
Colin Stickland
roeb
Are you an Oregon Scientific Garden Expert? Answer questions, earn points and help others
