Question about Lexmark X2600 InkJet Printer
Power supply the power supply is gone bad. I opened it to see what the problem was amd as a result the transformer was not working. How can i get a new power supply????
    President:
  • 3,085 Answers
Look on eBay
Posted on Jun 30, 2009
I rebuilt computer with new parts, now won't start up. No POST. Power LED lights up, no cpu fans spin, no beeps. Psu works with paper clip test. New mobo, ram, psu, cpu.
Check display without cabinet maybe motherboard getting short with cabinet and try new Power supply check all the power supply connectors connected or not .
Nov 14, 2016 | Computers & Internet
X2gen 19" monitor
I would recommend geting a new transformer, althought its possible that there is a connection loss somewhere in the middle or then it would require replacement parts, does the transformer have a power light on it?
Shouldnt cost alot, checking.
Apr 04, 2008 | X2Gen MG19MY 19" LCD Monitor
There is no power supply passing into the device. the green led is not at all lit. the volume controller does not show green light. i feel that the power supply is not getting into the device pls help
Get a multimeter and check its output voltage. it must give 11.5V AC as output. The current output in the multimeter must be 1.6 A .If it is not giving the output, your AC Adaptor has gone bad. there are 4 screws on the adaptor which you can open and inside you will find a single step down transformer. of rating 11.5V AC 111600mA(That is 1.6A) Aand 18.4VA rating. You can try to repair it at a transformer rewinding shop(IF HE DOES IT PROPERLY). or, try to get a new AC ADAPTOR OF THE SAME RATING.
Oct 28, 2013 | Creative Labs SBS 370 Computer Speakers
K1136780
Sounds like something went bad in the power supply. I would check all the capacitors to make sure none are raised on top or leaking. If all the caps look good then it could be a bad transformer. A new power supply board should fix it if you don't want to desolder, test and replace components.
Jul 13, 2013 | Televison & Video
My SONY STR-DE835 receiver amplifier is showing PROTECTOR on the digital readout.Anybody know what that means.
These models are known for this issue.
I've had my share in the shop here.
Disconnect all speakers,turn speakers off, try headphones only
If it still persists then there is either :
1. power supply capacitors gone bad or 2. The thermal fuse in the transformer is open.
A tech can very easily find out if the thermal fuse is open by checking the primary of the transformer
if the plastic is shrinking away from the power supply capacitors then they've gone bad
Jul 27, 2010 | Sony STR-DE835 Receiver
I now have several Hanns G 174A monitors that have gone dark, power light on, and a quiet, but distinct "clicking" sound from the monitor about every second or so. Any ideas? (no video source plugged in,...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 09, 2010 | Hannspree HW191D LCD Monitor
No picture will appear on my Eview 15 monitor . Have verified condition of power supply as OK.
I assume that you get the same result with another PC and already try new VGA cable, just want to narrow down the problem before trying to take the monitor apart.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, falied inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 29, 2010 | E-Machines eMachines Monitor E15T4
My hard drive has stopped working! I checked power supply and it is working fine, when plugged into drive and turned on, the blue light flashes briefly on the drive then goes off again as does the light on...
Could be a bad transformer on the power supply or a bad drive. You could check the voltage coming from the transformer and verify that it is the proper voltage using a fluke meter. You could also dis-assemble the hard drive housing and try installing it in the computer and check if it is working. If you install it in the computer and the drive is not found then the drive is probably bad. If the drive works in the computer then get a new transformer.
Sep 24, 2009 | Western Digital Computers & Internet
Scott ZXP8 Eclipse cd mini hifi system
Was the fuse Blown?? check with an ohm meteracross the two prongs that you plug into the wall of course you gotta unplug it for this. It should read around 4 to 10 ohms depending on the type of power transformer is in the unit.. If it reads open then theres a fuse open or a bad power transformer. If its not open check the power supply for the proper voltage from the diagram. Good luck
Apr 16, 2006 | Scott HH SJ510 Freestanding CD/Cassette...
Lexmark X2600 InkJet Printer Logo
35 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
