Question about GE 35840GC3 2-Way Radio
Regulated dc power supply
I need to know what size (amps) regulated power supply to use the raido has a fused 10 amp dc powed cord
  • 752 Answers
If it is fused at 10 amps, then any power supply 8 amps or greater should be adequate.
Posted on Nov 08, 2007
Schematic diagram example of AC DC regulated power supply 1.5volt to 35volt
You will need to add transformer and rectifier diodes before this circuit to be able to get the voltage you need.
See the link below of the regulated part of the circuit
http://simpleelectronic.com/2010/06/11/simple-adjustable-regulated-power-supply-circuit-diagram/
If you need more help let me know.
Sep 29, 2011 | Computers & Internet
MTD yard Machine lawnmower,17hp Briggs And Stratton engine. Runs for about 15 or 20 minutes and stalls. It will not start again until I recharge the battery over night. Then only runs again for 15 or 20...
yes it could be
check your battery 1st , then check the stator a/c output
• 10 or 16 Amps DC regulated for charging
battery
• Two black leads (C) from stator
• Yellow connector (D) with two pin
terminals
• Two yellow leads (E) to regulator-rectifier
(F)
• One red lead (B) from regulator-rectifier
to red connector output lead (A)
• 10 and 16 Amp systems use the same
stator, color coding and regulator-rectifier
• Alternator output is determined by the
flywheel alternator magnet size
The stator and regulator-rectifier are the same
for the 10 and 16 Amp systems. The system
output is determined by the flywheel magnet
size.
Test Alternator Output
1. Temporarily disconnect stator wire
harness from the regulator-rectifier.
2. Insert RED test lead (A, Figure 28) into the
V ω receptacle in the meter.
3. Insert BLACK test lead (B) into COM
receptacle.
4. Rotate selector to AC Volts position.
5. Insert RED (A) and BLACK (B) test lead
probes into output terminals (D & E) in
YELLOW connector (C). (Test clip leads
may be attached to either terminal).
6. With the engine running at 3600 rpm, the
output should be no less than:
• 20 volts - 10 Amp System
• 30 volts - 16 Amp System
7. If No or Low output is found, check for
bare wires or other defects. If wiring
defects are not found, replace the stator.
voltage depending on alternator type and magnet size
then check the regulator / rectifier , make sure it is grounded properly
make sure battery earth lead is good
i suspect loss of bat voltage is letting the afterfire solenoid close off the main jet
let me know model and type codes off engine & i will try help further
cheers
Aug 29, 2010 | Briggs & Stratton Garden
Have a flat screen viewsonic with no adapter cord. Takes a 12 v 3.3 amp. What would happen if I hook up a 12 volt supply with more than 3.3 amps? Thanks, Tom
Higher current is OK and better than not having enough and it does not do any damage, voltage cannot be higher.
Just think of it like a AAA and AA batteries, both have the same voltage but AAA has less current capacity.
The power supply must be regulated 12vdc though, which will be switch power supply type and also observe the DC plug' polarity (center positive).
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Aug 19, 2010 | ViewSonic VA720 17" LCD Flat Panel Monitor
I have a pioneer car stereo-12V DC, a sony xplod amplifer(2 chanel)-12V DC and I want to use them in my home, what kind of power supply will I need?
You want to use a 12 Volt power supply. This takes your 110V power and converts it to 12V power. Which size you need completely depends on how powerful your amplifier is. Your stereo needs about 10amps of power and looking at the fuse size on your amp, you need to add thses to the 10 amps for the stereo and this will tell you what kind of power supply you are looking at.
Aug 09, 2010 | Pioneer Car Audio & Video
Samsung LCD monitor DC voltage
The internal DC power supply consists of 2 REGULATED power supply circuits, one is 5VDC (about 1A) for logic circuits, another is 12~18vdc (about 3~4A) for the backlight circuits.
Here are the service manuals: http://elektrotanya.com/?q=showresult&megnev=SAMSUNG%20&megnev2=943&kategoria=&kat2=all
It may not be practical to build two external power supply, and you have to know the points where to tap into on the PCB.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
Jun 21, 2010 | Computers & Internet
Need to know wether there is a regulated 5v dc supply coming from a taurus x p430-pfc-taurusx-j atx power supply that i have
Write your question in brief so we can answer you very easy and we understand your problem
Nov 27, 2009 | Computers & Internet
What voltage is the dc adapter?
You will need at least a 4 amp rated regulated 12 Volt power supply.
These are commercialy available from most electronics parts suppliers.
They come on a circuit board. You can mount it in your own case and
use the original Viewsonic wire end. If you do a google search for 12
volt reglated power supplies you should find many of these.
However, with a second-hand Sprint AC adapter with 3A,
12v adapter, the screen blinks on and off
intermittently. Obviously there is some difference here between a class
2 adapter and a power supply box.
Oct 03, 2008 | ViewSonic VA520 15" Flat Panel LCD Monitor
Amp voltage
Well this is interesting, Let me start by saying if you have a 2 ohm load and your system is set for 4 ohms you are going to overdrive your load and burn up your amplifier, maybe not right away, but sooner or later it will fail due to electrical and thermal stress bought on by power dissipation issues.
Yes you can get 2000 watts out of your amps, but the correct way is to bridge your amplifiers if you can, and terminate them into the proper load.
Thank you,
Shuttle83
Apr 21, 2008 | Jl Audio 1000/1 Car Audio Amplifier
Galaxy Dx-88 HL
anything over 10 amps should be sufficient i would assume. if it calls for a 10 amp fuse anything less than that would be under powering the unit
Nov 07, 2007 | Galaxy Radios DX- 88HL Base CB Radio
GE 35840GC3 2-Way Radio Logo
101 people viewed this question
Top GE Radio Communications Experts
eradiostore
eradiostore
J.D. Browning
J.D. Browning
Van Allen II
Van Allen II
Are you a GE Radio Communication Expert? Answer questions, earn points and help others
