when you say it seems to be using too much, that is just a feeling
what you have to do is fill it right up and press the trip meter on the speedo
then you drive/use the vehicle normally until you are around 1/4 tank on the gauge
fill it right up again and record the reading on the trip meter
reset the trip meter and use normally again
repeat the process say for 4 tank fills recording each trip distance
then you will see what the fuel consumption is for example 40 liters for 400 klms is 10 liters per 100 klms or 20 galls for 200 miles is 10 gallons per 100 miles
the requirement to record distance and fuel put in will give you an accurate consumption over traffic, driving and atmospheric conditions from there you can ask --is this consumption figure around right for the car?
hi yes that sounds about right, each car even the same model can have slightly different fuel milage but it all depends on which fuel you run, how hard you drive it ect, im pretty sure the offical fuel comsumption for this car is between 8 to 9km.l
not enough information???????,replace air filter,fuel filter infact replace all filters and run a fuel cleaner through system,you dont tell me how many miles on engine i would need all the information to tell you a full system check.adrian,,,,
