Question about Honda Karcher G2400HH-R Pressure Washer
Won't start, small engine guy said carburator needed to be flushe
Get no response to starting, replaced spark plug.
  • 174 Answers
Hi lackeyapda:
Fire Air Fuel
Remove the spark plug, plug it back into its wire. Hold it close to the metal frame WITH INSULATED PLIERS. Pull the cord and see if you get a spark. If no it is the coil, plug wire or a safety switch. If yes
put it back together. Take the air filter off. Spray some "easy start" or "carb cleaner " into the carburetor. Try starting. If it starts for a moment then dies, you do need to clean your carb.
Posted on Jul 02, 2009
Got spark iused starting fluid still wont fire
Posted on Mar 17, 2011
MTD Snow Blower will NOT start up!
fuel float stuck --- need carburator repair -- to check it has spark then pull spark plug --- if wet blow off spark plug and check spark on plug then squirt a small fuel out of oil can into plug hole and put plug back in -- if engine fires on first pull carburator needs fixing -- check by squirting fuel in carburator with oil can and see if you can keep it running
Feb 23, 2014 | Garden
I have replaced the battery and ignition unit on my 1985 suzuki 700 es, the bike really sounds like it wants to run but wont start. Starter turns but engine won't kick over. Any Ideas?
Is it getting gas properly? Has it been sitting around for a while? The carburators on motorcycles need to cleaned after sitting around. The jet could be full of varnish. Are you getting spark for sure? Pull out a spark plug and put it in the wire, crank it over and see if the spark plug sparks. When you pulled the plug was it wet at all with gas? Then it probably isn't getting gas right. Just some of the things you could try.
Feb 12, 2012 | 1985 Suzuki GS 700 ES
Will not start
THE BLOWERVAC COULD HAVE GAS PROBLEM OR A NO SPARK TO SPARK PLUG PROBLEM. TO DETERMINE THE SPARK PROBLEM FIRST, REMOVE THE SPARK PLUG, LOOK AT THE END OF THE SPARK PLUG (ENGINE END) TO SEE IF IT IS DRY OR WET WITH GAS, THEN RE-ATTACH THE SPARK WIRE WHILE THE SPARK PLUG IS LAYING LOOSE AND PULL THE ROPE TO TURN THE ENGINE AND LOOK TO SEE IF THERE IS SPARK OCCURING AT THE SPARK PLUG. IF THERE IS SPARK PRESENT, YOU HAVE NO PROBLEM WITH SPARK. REPLACE THE PLUG AND WIRE. IF NO SPARK CHECK YOUR WIRE LEADING TO THE SPARK PLUG TO MAKE SURE IT HAS AN ELECTRICAL CONNECTION AT BOTH ENDS, SPARK PLUG END AND ENGINE END. IF LOOSE FIX THE CONNECTION THEN RE-TRY THE SPARK/ENGINE TURN OVER BY ROPE METHOD AGAIN TO SEE THEN IF YOU HAVE SPARK. IF THEN YOU DO HAVE SPARK, RE-ATTACH SPARK PLUG TO THE ENGINE AND RE-ATTACH SPARK PLUG WIRE TO THE SPARK PLUG AND TRY THEN TO START THE ENGINE.
IF THERE WAS A WET PLUG WHEN YOU FIRST REMOVED THE SPARK PLUG AND YOU NOW HAVE SPARK AT THE SPARK PLUG, YOUR ENGINE SHOULD START.
IF IT STILL WILL NOT START AFTER THE SPARK CHECK, I WOULD REPLACE THE SPARK PLUG WITH A NEW ONE.
IF THEN IT WILL NOT START, THEN REMOVE THE SPARK PLUG AGAIN AND POUR A SMALL AMOUNT OF GAS INTO THE ENGINE SPARK PLUG HOLE. A PINT PLASTIC OIL CAP FULL OF GAS IS ENOUGH, DO NOT OVER USE MORE THEN THAT.
THE RE-ATTACH YOUR SPARK PLUG AND SPARK PLUG WIRE AND TRY STARTING THE ENGINE AGAIN. IT MAY TAKE SEVERAL PULLS TO GET THE EXTRA GAS IN THE SPARK HOLE TO BE USED UP BEFORE YOU START TO HEAR IT RUN ALITTLE AND FIRE NOW AND THEN.
IT SHOULD START THEN.
IF THEN IT DOES NOT START, YU HAVE USED UP THE GAS YOU PUT INTO THE ENGINE BY THE CAP FULL METHOD AND IT IS NOT GETTING GAS BY THE GAS TANK SUPPLY.
THIS MEANS THEN YOU HAVE AN IN LINE GAS LINE FILTER THAT IS PLUGGED UP OR YOUR GAS MAY BE OLD IN THE GAS TANK. IF GAS IS NOT OLD AND FILTER IS NOT PLUGGED, THEN YOU NEED TO REMOVE THE GAS LINE LEADING TO THE ENGINE CARBURATOR TO SEE IF IT WILL FLOW FROM THE GAS TANK OUT THE GAS LINE SUPPLY HOSE. IF IT DOES FLOW FREELY, THEN YOU DO NOT HAVE A GAS SUPPLY PROBLEM,
AS LONG AS YOUR GAS IS NOT OLD GAS. OLD GAS WILL GO BAD IN TIME. I'D REPLACE THE GAS WITH NEW AND TRY AGAIN.
IF THIS DOES NOT WORK, THEN ITS CARBURATION CLEAN UP TIME.
IT WILL NEED TO BE REMOVED FROM THE ENGINE BY A FEW BOLTS, HOSE'S REMOVED AND TAKEN APART AND CLEANED. TARNISH FROM GAS AND OIL WILL BLOCK THE CARBURATOR JETS AND VACCUM PUMP FROM WORKING PROPERLY. CLEAN AND REPLACE, TRY AGAIN TO START ENGINE.
MORE GAS IN SPARK PLUG HOLE TO GET GOING MAY BE ANOTHER ATEMPT AFTER CARBURATOR CLEAN UP.
Feb 20, 2011 | Homelite Mighty Lite Blowervac
The motor wont start it seems to just pour petrol in to the engine the spakk plug drips fuel , it has a good spark when the plug is dry
Your carburator float is probably sticking you should probably buy a carburator rebuild kit or take it to a small engines mechanic
Dec 05, 2010 | Husqvarna Garden
Tries to start but won't? Replaced plug and fuel lines.
hi
check the compression,ignition sistem ,carburator and fuel lines (is there any spark,is the spark bright blue,does the fuel reaches the sparkplug.try put some small amount of gas inside the cilinder to seee if the engine starts and run.
regards savumihai71
Oct 29, 2010 | Garden
I have a 94 cr 125 , that i just bought , it started at the guys house but now wont start for me , tried putting a new plug in , any ideas
Try a compression test first see what it is, next check for spark, remove plug from engine leave connected, ground the end of the plug to the engine and kick over, if you have good compression and spark, it is in the carburation, some bikes dont start well when cold due to bad carburation(air leaks, bad jets etc)you could try roll starting down hill and see if it starts.
Nov 07, 2009 | 2002 Honda CR 125 R
Will not start
It could be the plug, but more likely the problem lies with a diry, gummed up carburator, a clogged fuel filter, or deteriored fuel lines or diaphragm. These are some places that I'd start. Sitting inactive for that long is hard on small engines. Grab some carburator cleaner and start cleaning and troubleshooting the fuel delivery system. Another little trick is to put a couple of drops of transmission fluid into the spark plug hole and slowly pull the pull cord, then let it set for awhile. This sometimes help free up stubborn trimmers that have been stored for long periods. Hope this helped and best wishes.
Sep 04, 2009 | Homelite Mighty Lite Lawn Trimmer
Its a 80 and i go to kick start it and it wont tart so i push start it and it starts but when i twist the gas it dies
sound like your carburator is dirty have you cleaned the carburator out! and you must check the point and spark plug if spark is weak you will get the same response on the throtle this is a classic bike it will have problems!
Aug 29, 2009 | 1975 kawasaki Z1B
Wont start please help
It sounds like the Fuel Pump is Bad. I would replace it and see what you can get it too do. Please Rate My Response! Thanks!
Feb 03, 2009 | 1987 Suzuki Samurai
Honda Karcher G2400HH-R Pressure Washer Logo
698 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
