A electrician told me that the exchanger is cracked and is leaking water. This is why I can't get heat in my pool. However no one is taking the blame for this happening! Is this covered within my warranty? I purchased this unit brand new in 2008.
have a problem with a laars boiler Mini-Therm II, the pilot keeps going out. the unit is about 5...
(More)
have a problem with a laars boiler Mini-Therm II, the pilot keeps going out. the unit is about 5 years old and is used for radiant floor heat.
have a problem with a laars boiler the pilot keeps going out. the thermostats only work on max as...
(More)
have a problem with a laars boiler the pilot keeps going out. the thermostats only work on max as well. have serviced the boiler and replaced the thermal coupler. the unit is about 10 years old and is used for radiant floor heat
laars lite 2 pool heater heats and then stops I checked the temp sensor and it is fine. Is this the...
(More)
laars lite 2 pool heater heats and then stops I checked the temp sensor and it is fine. Is this the temp controller?
I am winterizing my Laars Lite2 pool heater and have what may seem to be easy questions but... What...
(More)
I am winterizing my Laars Lite2 pool heater and have what may seem to be easy questions but... What Do I grease the drain plugs with before I put them back after draining heater?. Should it be Silicone based? Also where do I blow the compressed air to dry out heat exchanger?.. Thru the drain plug holes? Thanks
