Question about Palm Treo 600 Handheld
My touchscreen wont work on my 655 I believe - Palm Treo 600 Handheld
    Novelist:
  • 166 Answers
Did you try calibrating the screen.if it doesn't work when you try to calibrate it then it looks like the touch screen is bad and you will have to replace it.even if the touch is bad the video should still come through.go to pref= use the directional keys to to the top. you should see a blue rectangle are the date and time.click the center button and go to touch screen to calibrate it.if it won't let you touch it then the screen is bad. if you have any more questions please email me at gaecmrazy944@yahoo.com
Posted on Jun 30, 2009
My touch screen is all wonky its not responding to anything I'm trying to do with it and its doing things that I'm not doing it's basically made my phone useless at this point
Tf810c Touch screen wont work ' TabletPCReview.com - Tablet PC ...
forum.tabletpcreview.com > Forums > Windows Tablet PCs > Asus
Feb 24, 2013 - 10 posts - ‎4 authors
If it's greyed out, there is no data to reset, and it's not that causing the issue. ... wentall wonky, swipe for charms wont work, can select anything ... I tried the hard reset and low and behold my touchscreen started working again.
Nexus 7 (2013) erratic touchscreen & keyboard - Google Product Forums
productforums.google.com/d/topic/nexus/W0Hfkq8hf-c
GoogleJul 30, 2013 - I've used some touchscreen test apps and "ghost" touches would ... Myoriginal Nexus 7 (2012) didn't do this, nor did my Gnex or any of ... If it's software, I don't mind hanging onto it until a fix is released. ...... I can't believe no one has saidanything about the touchscreen not responding at all to touches I've ...
XPS 9530 touch screen stops responding (how to fix) - General ...
en.community.dell.com/support-forums/laptop/f/3518/t/19534511
Dell
Dec 1, 2013 - 15 posts - ‎7 authors
Dec 16, 2015 | Cell Phones
I jailbreaked using blackra1n and firmware 3.1.2, after 1week i am unable to use the touch screen to slide to unlock
jailbreaking wont break the touchscreen, your touchscreen has malfunctioned for a different reason, try restoring the ipod/iphone to official firmware and see if the touch screen works. If it doesnt you need a new touchscreen
Apr 09, 2011 | Computers & Internet
How do i access the NAT settings for my D-Link DIR-655 Router. i believe the strict setting is affecting the WiFi i need to connect to the internet through my computer.
NAT STRICT
Step 1 : Connect Router - Computer ( Wired )
Step 2 : Open Router setup by typing http://192.168.0.1 on the address bar of the internet explorer
Step 3 : The Default Password is admin
Step 4 : At the top Click Advanced
Step 5 : On the left Click Firewall Settings
Step 6 : Enable DMZ
Step 7 : give the IP Address of the Xbox/PS3/Wii in it
Step 8 : Uncheck the option Enable SPI
Step 9 : Click Save Settings
Step 10 : Test the connection
let me know if this works
Regards
TOM
Oct 24, 2010 | D-Link DIR-655 Wireless Router
My touchscreen does not work on my Samsung PIXON
try giving the top right corner of the phone a squeeze, i had the same problems with mine. I believe it could be a lose connection.
Jan 29, 2010 | Samsung M8800 Pixon - Unlocked QuadBand...
One of my LAN and wireless network computers has no Internet
look this happens if go to your internet explorer and check if you have your internet working offline if you have it checked uncheck it
Sep 02, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Touch screen wont work on my Samsung pixon.
I had the same symptons with my samsung m8800 and all i did was squeeze the top right corner of the phone and hey presto it worked agin. I believe it could be a lose connection. hope this helps
Jul 27, 2009 | Samsung M8800 Pixon - Unlocked QuadBand...
My DIR-655 won't work!
It would be helpful if you could be a bit more specific regarding the way you hooked up the dir 655 to your network and your specifc DSL modem. If the modem you are using is the Actiontec M1000 DSL modem you will not be able to obtain internet access because the DIR 655 is trying to route an already routed IP, the M1000 has a built in router / DHCP that by default is enabled. You can use option 1, access the configuration settings of your M1000 and change the WAN configuration to act as a transparent bridge. After doing so and rebooting the modem you will have to enter your DSL login information like a PPPoE username and password for example into your DIR 655 network settings. With this configuration the modem simply acts as a bridge to relay data directly to the DIR 655 and the 655 itself provides login credentials to obtain internet from your DSL provider as well as hand out IP addresses to the local network. Option 2 is to continue to use the M1000 as a router by default and disable DHCP on your DIR 655 so that it essentially acts as nothing more than a switch or wireless access point while the M1000 hands out local IP addresses. I personally would recommend using the DIR 655 to route IP's as it's got far more configuration utilities than the M1000 does as a router, and really what's the point of getting the 655 if you're only going to use it as a switch or access point when there are other simpler and cheaper devices that could do that for you.
Jul 20, 2009 | D-Link Xtreme N DIR-655 Wireless Router
My MC70 work symbol wont respond to my touch screen pen
Does it respond to keyboard entry? If not, check to see if the "lock" icon on the screen is in the locked position. It's real easy to accidentially lock the device. If it is, just click on the lock and confirm that you want to unlock.
The next few can be a problem if the screen is not responding, so you'll need to figure out the keyboard equivalent:
You may also want to check the system settings. I believe there is a setting that will enable you to "turn off" the touch screen function.
Finally, try a touchscreen alignment in the system settings.
Jan 17, 2009 | Symbol MC70
Palm Treo 600 Handheld Logo
119 people viewed this question
Top Palm Computers & Internet Experts
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
