Question about Homelite Mighty Lite Lawn Trimmer
It starts but will not run. fairly new - Homelite Mighty Lite Lawn Trimmer
  • 1,041 Answers
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris. (Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If you need further assistance, just let me know.
Jim
Posted on Jul 03, 2009
  • Jim Parker
    Jim Parker Jul 06, 2009
    Did this solution solve the problem?
    Jim
  • Jim Parker
    Jim Parker Nov 26, 2009
    Thanks for the rating.
    If you should have any questions about
    "Drywall Finishing/Patching", or know someone who does, put your
    questions to Category:"Tools- Building & Power- HAND TOOLS" at
    FixYa.com
    Thanks Again,
    Jim
My audi a5 wont run it starts and cuts out since i fitted a new serpentine belt
How long does it run? Sure you only changed the serpentine belt? The car would actual even run without the serpentine (or also called accessory belt) since the belt only drives fairly non essential components (AC compressor, alternator, fan, power steering pump. etc).
Mar 27, 2016 | 2010 Audi A5
Moffat washer (mcch6110hww GE?) trips breaker shortly after start of cycle. Can this be repaired?
Sounds like your drum brake is engaging. Fixing it is fairly cheap. YouTube it and watch a few videos on how to do it if your fairly handy.
Feb 01, 2013 | Washing Machines
2002 VW Passat running fine. Stopped for errand
try resetting the alarm system first.if you dont have the book,leave feedback.
Apr 22, 2010 | 2003 Volkswagen Passat
Will a 1993 ignition switch housing kit fit an 1986 liberty flhtc?Only difference i can see visually is in the type of key used. not sure of the wiring harness on bike yet,and will it line up?
As long as both switches have the same number of connections, they should work. I think they should have six connections on the switches. Earlier switches had only five and latter switches were electronic with a plug on them.
Apr 10, 2010 | Harley Davidson FLHTC Electra Glide...
DRYER STARTS BUT IMMEDIATELY SHUTS OFF
If you are having the same problem I had, the motor gets hot and shuts off. My motor was making a fairly loud noise when I cut it on. It would run for a minute or two and then shut off. I had to replace the motor. Motors are fairly cheap and not that hard to install. I paid $50 for a new one on ebay including shipping.
Jul 18, 2009 | Kenmore 63942 Dryer
Fairly new Husqvarna 142 only runs at high throttle. 150 Pressure test.
what type of fuel are you using.never put premiun it a saw.make sure that there is no alchohalin the fuel ........it make the fuel burn too hot so it looks like a lack of oil in the fuel mixture.......also make sure that the spark plug is correct.......wrong plug will fire too early and either burn a hole in top of piston or show up as a lack of oil........
Sep 28, 2008 | Garden
Air conditioning
You will need a new blower motor, sorry.
Jul 31, 2008 | Heating & Cooling
GE Dryer won't stay running
The door latch could be defective. The dryer will not start unless it senses that the door is latched (not just closed).
Feb 01, 2018 | Dryers
Homelite Mighty Lite Lawn Trimmer  Logo
356 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
