Question about Cub Cadet Street Sign- tractor lawn riding mower parts
My cub cadet won't start the info panel says pto engaged.I hear it switch when turning on and off but engine will not try and start.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 109 Answers
Disengage the pto switch...
Posted on Jun 30, 2009
2 Suggested Answers
  • 146 Answers
SOURCE: cub cadet pto won,t stay engaged
Sounds more like a PTO clutch failure, rather than the switch. The clutch is mounted on the engine shaft, between the hydrostatic drive pulley (nearest the chassis) and the mower deck belt pulley (farther from the chassis).
Since it's an expensive part, make sure the problem isn't in the switch or wiring first. You could do that by probing the wires to the PTO clutch with an automotive test light - they are inexpensive and handy. Clip the ground wire of the test light to the chassis, and probe the hot wire to the clutch (it's the one that doesn't connect to ground) when the engine is running and the PTO switch is engaged. Obviously a helper has to be in the seat, and you should be careful doing this. If the light glows brightly, and the clutch doesn't engage, you definitely have a bad clutch. Good luck! Please rate my answer if helpful, thanks.
Posted on Jul 07, 2010
How can i fix the pto on my cub cadet lawn tractor?
if the engine didn't shut off as well when you bounced out of seat , you 4 sure have a fault in the seat switch , im under the suspicion that seat switch has two contacts one is 4 engine and one is 4 pto
Aug 24, 2015 | Cub Cadet Garden
I have a 1999 cub 2135 with a kohler engine. the mower deck wont kick in . i ran a hot wire to the pto & it worked .do i have to replace the switch or the module. i also checked the seat switch &...
IF connecting that one hot wire to the pto made it engage then you either have a broken/cut/bad connection/wire to the pto or the switch is bad.
What you did by using the hotwire to the pto is bypass all the wiring and the switch for the pto.
You can determine if it's the switch real quick if it only has two connections/wires to the switch. Pull the switch, remove the wires and touch them together, after you have the mower in the condition under which the pto would engage. If the pto engages it's the switch for sure.
Take all the proper safety precautions. Don't let the wires touch anything else.
Sep 29, 2017 | Cub Cadet Lawn Mower PTO Clutch Replaces...
Cub cadet pto won,t stay engaged
Jul 06, 2010 | Cub Cadet Street Sign- tractor lawn riding...
CubCadet 1554 - won't start!
If you hear the PTO click when you turn the ignition on, sounds like the PTO button is pulled out like you were engaging the blades. The engine will not start if the PTO button is pulled out....
May 07, 2010 | Oregon Scientific Electric PTO Clutch for...
PTO clutch will not engage.
first start by turning ign on,then switch on the pto switch to on. you should hear a click in the clutch. if not use a twelve volt test light,hook aligator end to a good groundand the needle end,,,touch to the pto switchharness to see if you have power to the pto switch. if you don"t, you have to go checkfurther to your power source,(battery) if you do have power there check to see if you have power at the plugin at the end of your wire harness, just at the beginning of where your cluch connects up. you can test you clutch by conneting a test wire from positive on your battery to one of the terminals on your clutch and the other terminal to ground . It willengage if it is good .using either wire is ok as all it will be doing is completing a circuit. hope this helps.
Sep 24, 2009 | Oregon Scientific Electric PTO Clutch for...
Cub cadet Z Force 48 inch zero turn blades won't engage
I hope this will help you...under the side panels on each side of the mower, there are "reverse lockout safety switches", they are supposed to stop the blades when both handles are pulled back. If one or both of the switches are out, the deck will not engage. Also, under the right side panel (when sitting on seat) there should be 3 relay switches, the one closest to the motor controls the PTO., if this is out, the PTO will not engage.
Jun 25, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Electric PTO on 1500 series Cub Cadet won't engagewithengine hot
its the electric clutch on the engine that engages the belt to run blades check the centrifical clutch or electric clutch
Jun 21, 2009 | Garden
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
1,114 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
