SOURCE: Paper Jam
No still jammed will contact the shop I purchased it from or ask the IT people I deal with at work if they have solution. Thanks
SOURCE: not grabbing paper
Try cleaning the rollers again and fan the paper. When you clean the rollers, use alcohol and a lint free cloth. Don't put too many sheets in the feed tray.
SOURCE: my print keeps jamming paper in it the paper jams
unplug it and look for and thing in it like crumbs, flower petals, sticker, glue from stickers and the like. Purchase a can of compressed air and blow it out really well. If it is not too large of a printer turn it upside down and see what shakes (gently) out.
With a damp cloth wash off the rollers looking for debris or sticky build up from over spray of ink. something is tripping the pressure switch to the paper jam control.
Now if none of that does you any good...uninstall and reinstall the printer drivers.
Hope this works well for you, please leave a rating, thank you kindly
SOURCE: paper pulls to the right, jams, won't print, tried different paper still won't print
Remove the jammed
paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for
tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers
and make sure they are dry.
Keep printer unplugged for about 2 minutes and
replug and try a test print.
Also make sure that you have waited long enough
for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper
sensor. If this is the case, you will probably have to take the printer in for
servicing..
Hope that helps!
PREM
SOURCE: printing 4x6 glossy paper photos on Canon MX700
I have a Canon Pixma MX700. I have printed many great photos but not it prints a faint image in the background but the rest of the photo is covered with black ink spots, what can I do to correct this problem?
