Question about Apple iPod touch
My ipod touch is not being recognised as a device on screen and is locked just showing me the connect to itunes on the screen what do I do it was working perfectly well today and I have downloaded the latest version of itunes
  • mishmitch Jun 30, 2009
    I have already tried to connect to itunes but it shows on the screen the itunes logo and the usb cable and doesn't do anything from then on because I can't access the keys to put in the password, therefore it can't restore.......
    Sergeant:
    Champion:
  • 233 Answers
Your ipod may have just crashed for an unknown reason, but the only solution to this problem is to follow what the ipod says on the screen in order to gain access to your ipod again.
Note: you will loose anything, itunes will erase all contents from the ipod.
Open Itunes and connect the ipod touch to your computer, itunes will atomically recognize the ipod like it always does and will download system software from apple and restore your ipod. this process will take a little bit longer but wait till it finishes.
after restoring your ipod, you can configure your ipd like you did the first time.
Posted on Jun 30, 2009
  • Raymond Owusu-Gyawu Jul 02, 2009
    Which ipod are you currently using.
I Pod Touch showing USB cable and an arrow for iTunes. I tried to Charge it or put it into DFU mode Hold the lock/power button for 15 seconds Then hold the lock/power button and the home button without...
sorry, that is the incorrect way to enter dfu mode. here is the correct way.
Step 1. Plug your ipod into your computer.
Step 2. Power off your ipod.
Step 3. hold the power button down for 3 seconds.
Step 4. while holding the power button, press and hold the home button for 10 seconds.
Step 5. While still holding the home button, release the power button AND CONTINUE HOLDING THE HOME BUTTON for 15 seconds.
your computer should recognize the device as in dfu mode, install the driver needed, and from then on, you should be able to restore.
Sources- i have had an ipod since the very first one, and i have extensive knowledge of jailbreaking and restoring troubles.
Sep 02, 2013 | Apple iPod Touch iTouch 16GB WiFi MP3...
Tip
Resetting an iPod if you forget your password
<p>The iPod is a security measure to prevent unauthorized access to your personal media player. Apple included an option to set a password to be used to unlock the device at startup. If you draw a blank password, you can still have the ability to unlock the device, but the process depends on the model of the iPod. IPod Touch owners to restore the device to a password reset code. Other iPod owners need only plug it into iTunes to lock the screen around. <br /> <p><br /> <p>Lock the iPod <br /> <p>1. Connect your iPod to your computer you normally sync your device. <br /> <p>2. ITunes load. <br /> <p><br /> <p>3. Click the "Eject" on the right to offer your iPod under "Devices" in the left column of iTunes. The iPod will be unlocked. <br /> <p><br /> <p>4. Select the "Extras" on the iPod. <br /> <p><br /> <p>5. Select "Lock screen". <br /> <p><br /> <p>6. Select 'Turn Off Screen Lock. " <br /> <p><br /> <p>Unlock iPod Touch <br /> <p>1. Connect your iPod Touch to your computer. <br /> <p><br /> <p>2. Open iTunes. <br /> <p><br /> <p>3. Click on the iPod Touch icon on the left "Devices" section column. <br /> <p><br /> <p>4. Select the "Summary" tab. <br /> <p><br /> <p>5. Click "Restore" and confirm the prompt action in the resulting pop-up. Follow the wizard prompts for the restore process to complete. <br />
on Jul 21, 2011 | Computers & Internet
My ipod is disabled and says connect to itunes but it also says itunes could not... so what do i do?
Step 1:
Apple's iPod Touch comes with a screen lock feature that allows you to set a four-digit security code to prevent others from using your iPod. Every time the iPod locks, you must enter this code to unlock the screen and access the user interface. Entering the wrong code too many times, or simply forgetting your security code, can cause you to be completely locked out. When this happens, you can quickly unlock your iPod Touch.
Connect your iPod Touch to the computer you usually sync it with. When you disconnect your iPod, it should now be unlocked. If Step 1 does not work, you have to restore your iPod Touch. Be advised that restoring your iPod Touch returns it to the original factory settings. This means that all your songs and files will be deleted and lost. You can resync your files to your iPod from iTunes once you have finished restoration. Connect your iPod to your computer and open iTunes. Make sure you have the latest version of iTunes before proceeding. In the left navigation panel in iTunes, select your iPod under the "Devices" section. Click the "Summary" tab and select "Restore." When iTunes prompts you about backing up your data, click "Back Up." In the following window, click "Restore." After the restore process completes, you will see the Apple logo on the screen of your iPod. Leave your iPod connected to your computer until it shows up again on the iTunes navigation panel. Your iPod touch is now unlocked. In iTunes you will be able to setup your iPod. Select the backup you made in the drop-down menu to restore your data files. Click "Continue" to finish the restoration. iTunes: Restoring iOS software
http://support.apple.com/kb/HT1414
Mar 01, 2013 | Apple iPod touch Original
Got locked out i pod touch
How to Unlock a 16GB iPod Touch
Instructions
1Connect your iPod Touch to the computer you usually sync it with. When you disconnect your iPod, it should now be unlocked.
2 If Step 1 does not work, you have to restore your iPod Touch. Be advised that restoring your iPod Touch returns it to the original factory settings. This means that all your songs and files will be deleted and lost. You can resync your files to your iPod from iTunes once you have finished restoration. Connect your iPod to your computer and open iTunes. Make sure you have the latest version of iTunes before proceeding.
3 In the left navigation panel in iTunes, select your iPod under the "Devices" section. Click the "Summary" tab and select "Restore."
4 When iTunes prompts you about backing up your data, click "Back Up." In the following window, click "Restore."
5 After the restore process completes, you will see the Apple logo on the screen of your iPod. Leave your iPod connected to your computer until it shows up again on the iTunes navigation panel.
6 Your iPod touch is now unlocked. In iTunes you will be able to setup your iPod. Select the backup you made in the drop-down menu to restore your data files. Click "Continue" to finish the restoration.
Tips & Warnings
Apple notes that the company will not be able to help you unlock your iPod if you forget the security combination. Your only choice is to restore the device to the original factory settings.
Dec 05, 2011 | Apple iPod nano
Trying to sync my i pod touch to my computer , Did download itunes, device option not showing to sync, information on my ipod shows an adaptor and arrows opointing to itiunes also showing locked .
when I connect my ipod touch to my computer it only recognises it as a camera and dosent recognise it in itunes at all. Any ideas why?
Dec 26, 2010 | Apple iPod touch
Locked ipod won't connect to itunes
put your iPod to DFU mode, that way, your iTunes will recognize our iPod.
see instructions here: http://www.fixya.com/support/r4083816-put_iphone_dfu_mode_restore_3_1_2
Feb 10, 2010 | Apple iPod touch
Apple Ipod Is disabled
  1. Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPod touch to turn off.
  2. Press and hold the Home button while reconnecting the USB cable to iPod. When you reconnect the USB to iPod, the device should then power on.
  3. Continue holding the Home button while iPod starts up. While starting up, you will see the Apple logo.
  4. When you see "Connect to iTunes" on the screen, you can release the Home button and iTunes will display the recovery mode message:
  5. Restore and it'll download ~240mb firmware and you're done
Warning: you will lose all your data
Sep 15, 2009 | Apple iPod touch
My ipod is so screwed up PLEASE HELP
you can reset its password....but you'll lose all your data. Here's how...
  1. Verify you have iTunes 7.5 or later. Apple recommends using the latest version of iTunes.
  2. Disconnect the USB cable from the iPhone or iPod touch, but leave the other end of the cable connected to your computer's USB port.
  3. Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPhone or iPod touch to turn off.
  4. Press and hold the Home button while reconnecting the USB cable to iPhone. When you reconnect the USB to iPhone, the device should then power on.
    Note: If you see the message "Charging... Please Wait" or you see the screen pictured below, let the device charge for at least 10 minutes to ensure the battery has some charge and then start with step 2 again.
  5. Continue holding the Home button while iPhone starts up. While starting up, you will see the Apple logo.
  6. When you see "Connect to iTunes" on the screen, you can release the Home button and iTunes will display the recovery mode message:
    If you don't see the "Connect to iTunes" screen, then disconnect the USB cable from iPhone and repeat steps 3-6.
Sep 03, 2009 | Apple iPod touch
Ipod touch is locked with connect to itunes screen showing unable to put in code to unlock
Plug the device into itunes and do a factory reset and restore from backup.
Jun 08, 2009 | Apple iPod touch
Apple iPod touch Logo
176 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
