Question about Presto HeatDish Compact Heater
Presto Heat Dish Blows Circuit
I have a Presto Heat Dish and it continues to blow a circuit in my fuse box, in fact, I cannot run it higher than medium. Any suggestions
  • 288 Answers
It sounds like the heater is drawing more amps than your fuse is capable of handling. look at the i.d. plate and see what the wattage is for the appliance.
Posted on Nov 10, 2007
BCM fuse keeps blowing
Sounds like you may have a pinched wiring in the circuit where the fuse supplies power to. Might want to remove all the components that this circuit operates and one by one connect them. Once the fuse pops, you have isolated the circuit and all you need to do is follow the specific wiring to that bad circuit and find the problem.
Dec 18, 2016 | Cars & Trucks
Pwr surge took out alt, windows guages blinkers, wipers,heat and ac
Hi S, It seems to me that the surge may have been caused by the alternator before blowing. A short circuit may has caused the diodes to blow, which in turn will probably have been caused by a short circuit created when the radio theft took place. The first thing to do is isolate all loose cables and make sure that there are no internal shorts inside any auxiliary equipment. After making repairs to the alternator, or fitting a replacement, disconnect all connectors to switches and other controlled units such as cabin heating and ventilation systems, music, TV and navigation systems. The fuse box is located in the engine compartment. Check all for continuity and replace burned fuses and at the same time, check for any damaged relays. Once are you satisfied everything is as it should be turn the ignition key to auxiliary and check all cables for overheating. Connect each unit one at a time until a fuse blows or all are connected. If a fuse blows while connecting, replace the fuse, but leave that circuit disconnected and continue until all are connected or another fuse blows. Once the dangerous circuits have been identified, trace the fault either into the wiring harness or the units. Repair if possible or replace. Once that has been done, crank and start the engine. Check all circuits with the engine running and the park brake fully engaged. If the engine fails to start check the electrics which operate the starter motor. Hope this info is at least a little helpful. Regards John
Apr 17, 2014 | 2004 Toyota Corolla
When i go to start my car i blow the #11 fuse located under the hood,what does #11 fuse go to?
Hi Aaron, I'm glad to help!
Aaron, see if the fuse blows when you turn the key to the on position without trying to start it. If it does then it could be anything on that circuit. NOTE: If in fact it only blows when you try to start the engine then your problem is in the "START-RUN-CIRCUIT" which mean you have a dead short in either the wiring or something on that circuit. If you find it is on the start run circuit then disconnect the starter and see if it still blows the fuse. CAUTION: When disconnecting the starter always unhook the negative battery cable first then rap the power wire with a rag or tape so it doesn't ground out on the engine and cause more problems. Now that you've disconnected and rapped the starter wires reconnect the negative battery cable and try to start the engine, if the fuse doesn't blow then replace the starter. If the fuse does blow then reconnect the starter remembering my caution. NEXT: Disconnect the Alternator using caution and try to start the engine if it blows the fuse replace the alternator, if it doesn't blow the fuse then you have a direct short in the wiring somewhere in that circuit. Start looking for frayed wiring that could be grounding out on the engine. Hope this help and have an awesome day Aaron.
Mar 28, 2013 | 2001 Lincoln LS V8
I have a Buick le sabre 1994 every time I put a blue 15 fuse in it, it blows right there in my hands so the interior light are out and the rear lights won't stay on unless using the brakes and when th
you have a short in this circuit, it must be repaired before you stick that fuse in. a wiring diagram is how you can trace that circuit, testing each wire for continuity, or a short, is the only way to find your problem.
Jan 18, 2013 | Cars & Trucks
No ac nd my fan stop working completely
Fuses blow because of higher than normal amperage in the circuit. Not sure what circuit the blown fuse is for but if it is for the fan the fan may be shorted therefore blowing the fuse. If you put fuse in while the ac was still on try shutting off the ac then putting the fuse in. See if it blows then if it doesn't then turn the ac on and if it blows you have at the very least isolated the system at fault.
Jun 16, 2012 | 2001 Chevrolet Impala
As soon as you put a fuse in wiper circuit it blows is there a module that runs these to or is it just switch and motor
Fuses are intended to protect the wiring in a circuit. If it blows there is an overload or a short circuit. It could be a faulty wiper motor, a faulty switch or a worn through wire that is grounded. try disconnecting the motor first to see if the fuse still blows. Next inspect the wiring harness as I feel a switch is an unlikely cause. Check around the fuse box as well as sometimes fuses over heat and terminals touch.
Feb 19, 2011 | 1998 Dodge Ram 1500 4WD
My dryer still runs but does not heat up (just blows cold air), any idea how to fix? Will it be a thermostat or the heater element itself?
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Jan 04, 2011 | Whirlpool AWZ7303 Electric Dryer
My whirlpool dryer keeps blowing the fuse for heating. The dryer will still tumble but once stopped, won't start until the fuse is replaced. We've cleaned the whole thing out and even set up a different...
I would check the outlet as it sounds like one of the wires is off/shorted. Here is a website that may assist you, Good Luck Tim:
Nov 01, 2010 | Kenmore 63932 Electric Dryer
My compressor stoppped running. i found a burned out fuse inside. i've replaced the fuse. the fuse was labeled 3a250v. thats what i replced it with. when i turn it on the fuse blows immediately. on some...
Every time I connect my Campbell & Hausfeld fp200300av Compressor and push the power on, the fuse blows. Even if I disconnect the motor from the circuit board the fuse continues to blow. Then I extracted the Rectifier-diode (the black and square with a hole electronic with four stands part).
This piece was the reason of the short circuit, I replace it with an equivalent one and I accomodate it to the right terminals in the circuit board. My compressor works flawlessly again!
Sep 24, 2009 | Campbell Hausfeld Air Tools & Compressors
Dryer continues to run but heat fuse blows when turned on.
You would need to check the amp draw to determine if it is the dryer or your house circuit. A dryer typically draws a steady 24 amps when it is heating.
Apr 07, 2009 | Whirlpool GEW9250 Electric Dryer
Presto HeatDish Compact Heater Logo
343 people viewed this question
Top Presto Heating & Cooling Experts
Mack Baxter
Starnley Johnwells
Starnley Johnwells
Paul Carew
Are you a Presto Heating and Cooling Expert? Answer questions, earn points and help others
