whirlpool caprio top load washing machine anket was washed and i need to find it before my wife gets mad.(she is the one that washed it) how can i take it apart and where might it be? please don't tell me the septic tank. thanks for the help
Comments:
Jun 30, 2009
- I got the cover off how do i get the plastic part on the bottom of the drum off?
Not sure of this model, but on 'most' top load washers the top piece of the agitator will unscrew, pull the agitator up, anklet should be under it if is too big to fit through the holes in the tub. If it isnt there, look for the screen in front of the water pump. Which means either pulling up the top, or removing the back. Good luck
Comments:
Jun 30, 2009
- If it is in the tub, it should pull straight up, but without seeing it, I can not be sure. There may be a schematic inside the back panel. May show the water pump and any screen location.
Best bet may be calling a reputable appliance shop for better instructions. Last thing you need is to break something through force.
my washing machine is blinking f1 when i start a load.. i have to hit reset and start over about...
(More)
MY WASHING MACHINE IS BLINKING F1 WHEN I START A LOAD.. I HAVE TO HIT RESET AND START OVER ABOUT THREE TIMES BEFORE IT WILL START THE LOAD OF CLOTHES .. HELP WHAT IS THE PROBLEM
i have whirlpool cabrio was you can hear the machine adgating is this normal when i first got the...
(More)
i have whirlpool cabrio was you can hear the machine adgating is this normal when i first got the machine it was very quite
a F code happens at 30 min mark of cycle,it could occur several times. i sometimes move the clothes...
(More)
a F code happens at 30 min mark of cycle,it could occur several times. i sometimes move the clothes around when it is paused it fixes the problem, but other times the f code reappears again and again, not sure if its an unbalanced or overloaded load1
