Question about Char-Broil Grilling
My char-broil 463268706 is not getting over 300 degrees, usually only around 200 degrees. how do i get it hotter. maybe even 400 degrees? (its set up as propane)
Kwiles I do not have solution for your problem but do you still have that grill? I have the same one but it is converted to natural gas now I need to convert it back to the propane gas but I have lost the orifices which I removed to convert to natural gas. Can you please help me and unscrew one of your orifices take some measurements and pictures and send it to me? my email krislizak at gmx dot com. Please help me I need those dimensions.
Thank You
Posted on Jul 12, 2010
What are the operating pressures on an Armstrong Concept 10 scua24 A/C
Didn't help ya huh Wayne?? We are in the temperature control businesses, temperature is what's important, not pressure. The hotter something is the more pressure it has. On a satisfied home, I will say 75 degrees, your evaporator coil should be around 40 degrees. 40 degrees with r22 is about 65 psi. 40 degrees with 410 is about 125 psi. Head pressure, your condenser temperature, will vary depending on the time of day. The hotter the temperature, the higher the pressure. R22, 200-225-240...R410a, 300-325-350. Keep in mind, the hotter the house, the higher the pressure. Hope this helps!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jul 08, 2017 | Heating & Cooling
How do I know what heat to set my hair straightener to? I am worried I will damage my hair.
Buying an iron with variable heat settings is really important as it gives you control.
If you have hair that is fragile, fine or color treated, you should set the heat below 200 degrees otherwise you are risking burning or damaging your hair.
If you have curly, coarser type hair, you can set the heat higher - around 200-300 degrees.
But never go above 400 degrees no matter what you hair type is like.
Feb 20, 2013 | Health & Beauty
The flame does not spread evenly to all the burners and it will not heat beyond 200 degrees
Fuel starvation is the likely cause. Pressure regulator is bad, or an orifice is clogged.
Feb 18, 2011 | Char-Broil Designer 463261106 Grill
The burners are not putting off good heat/flame. the temperature is oonly getting to around 300 degrees. what can be wrong?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
You problem could be or probably is with the regulator...not enough gas pressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Aug 30, 2010 | Char-Broil Performance 463463006
Hello I have a Char-Broil grill model# 463268706. It is set-up right now for natural gas. But I need to convert it back to propane gas. Does anybody have or know what is the thread size on the orifice?...
You not only have to have the correct thread size, you also have to have the correct orifice size. The size of the orifice varies from grill to grill which is why "universal kits" don't work on all grills. You will have to contact the manufacturer and get the correct orifice size, or get the orifices from the manufacturer. If you need help, let me know.
Jul 12, 2010 | Char-Broil Grilling
My oven burns everything.
Use a 'oven thermometer' in the oven and determine the 'actual temperature' in the oven. Your knob setting is off (not calibrated) and the oven is hotter than the control knob setting.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 16, 2009 | Ovens
Need help smoking briskett on Char Broil Grill with smoker box
wood chips in the fire box. very low heat. around 200 degree.
maek sure the wood chip is wet and produce smoke. you need to monitor this through out the process.
briskette in the grill side without any heat. depends on the sixe and the thnikness of the meat, you need approximately 12-20 hours before meat become tender.
here are few web site you can get some information
http://www.smoker-cooking.com/howtosmokeabrisket.html
http://bbq.about.com/cs/brisket/a/aa111503a.htm
http://www.wyntk.us/food/smoking-brisket.shtml
http://www.bbq-fyi.com/how-to-smoke-brisket.html
May 29, 2009 | Char-Broil CharBroil 4637318 Grill
Char Broil commercial grill won't heat pass 300 degrees
I had a similar problem and thought the propane kept running out....come to find out it was a defective regulator. $21 at the local ACE store as running to LOWES and trying to get a point across to a 17 yr old summer help college kid for a intermittent problem seemed more challenging then it was worth. Would barely light the burners and would not get over 200 degrees. Ripped it apart...blew through all the orfices including the regulator put it all back together and would work for a while then fail again. Good luck!
May 30, 2008 | Char-Broil Commercial Stainless Steel...
Grilling Logo
285 people viewed this question
Top Char-Broil Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Jim Thurston
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
