Question about Weber Genesis E-310 Gas Grill
Weber propane grill does not get very hot
Low heat output
SOURCE: My weber Baby Q grill has a low flame.
Agree with rjmbridge. I called the Weber support people and was told that there is a built in safety feature on the regulator that will cause the flame to burn at a low setting if the gas within the extension tube to the large tank and regulator is not allowed enough time to equalize. They suggested turning on the gas from the tank very slowly, allow about 2 minutes with the temperature control knob turned off, then turn the temp knob on and light. This worked for me.
Posted on Aug 09, 2008
SOURCE: heating
When you turn on the main propane value (on the propane tank) do it real slow and easy. What might be happening is that the regulator on the unit is sensing too much propane at one time and is shutting down the flow. If this happens, you only get a small flame. You need to shut it down, wait about a beer, then try again REAL SLOW AND EASY.
Remember, slow and easy; as soon as you hear some gas going though, stop and see if it works. You can open the valve further if needed but take it slow.
This is how I made my Weber Q work after about 6 months. Now, it's great. I have to wrestle with it but at least it works now.
Posted on Apr 29, 2009
SOURCE: Weber grill
Can you tell if the gas is flowing? Its either dirty or perhaps your regulator got damaged.  I'd check that out.  Above all else, though, be careful!
Posted on May 19, 2008
SOURCE: low flame
Adjust the screw hidden under a sticker on the adjustment knob. That will increase the flow.
Posted on May 05, 2009
  • 15 Answers
SOURCE: New Tank won't light Weber Grill
Try checking the regulator, this is the round metal piece connected to the gas line. If this is not level flat the valve inside will not let propane flow through.
Posted on Apr 16, 2010
How to reduce the heat on a weber side burner
You could try sticking something like stainless steel wire through every other hole (or all of them) in your burner to partially clog the gas output. Depending on the configuration of your burner, you could thread it through both sides and twist-tie it down underneath.
Nov 01, 2015 | Weber Summit S-670 Gas Grill
Need to convert our Q300 propane grill to natural gas. Do you sell conversion kits?
Unfortunately, Weber grills are not convertible from one gas type to another. There are no conversion kits available for your model or any Weber model gas grill.
To confirm this, go to the following link and on page 2 under Warnings, last paragraph, left hand column, you can confirm this, if you like.
http://help.weber.com/manuals/pdf_files_2011/Gas/Weber%20Q/Q300320_OwnersGuide_41060_021011.pdf
The only advantage to converting it to Natural Gas is not having to refill the grill tank. The downside, is that you will loose the heating capability that Propane has. It burns cleaner and hotter than Natural gas, in an outdoor environment.
Hope this helped you. Happy Grilling!!
Jul 13, 2011 | Weber Q300 Grill
Does not heat up right
Disconnect tank - remove cooking grates and flavorizer bars - use a soft metal brush and lightly brush the burner tube (where the flame comes out) and make sure they are not clogged up. While you have the grates and bars out you should clean them as well with hot soapy water and a brush. Put all pieces back in when done cleaning and re-connect the propane tank. Open propane tank valve 1/3 of a turn and light grill. After it ignites, open valve further. Usually a good cleaning will take care of it. If not, it may be the gas regulator. Weber has great customer service and will be more than glad to help you with just a phone call. On your grill there should be a label showing your model and serial number. It is very helpful if you have this info if you call Weber (but not totally necessary). Weber contact number is 1-800-446-1071
Apr 24, 2011 | Weber Genesis Silver B Grill
My weber genesis silver starts up, but doesn't get hot enough to cook the food. Seems like not enough flame out of either front or back burners. I tried Outting in a full propane tank, but that didn't...
Try these steps in order.
  1. Turn off the gas at the propane tank
  2. Disconnect the gas line from the tank
  3. Open the grill lid
  4. Turn all control valves to high
  5. Wait for about a minute
  6. Turn all control valves to off
  7. Reconnect the gas line to the tank
  8. SLOWLY turn on the gas at the tank
  9. Light the grill normally
  10. Your grill should now heat normally
Sep 06, 2010 | Weber Genesis Silver B Grill
New webber will not start
Ok, let's tackle the obvious things first. New grill with new tank... so was the tank filled? Did they purge it before they filled it? Did you turn the tank valve on very slowly? Were all the grill knobs turned to off when you turned on the gas tank? Try closing the propane tank valve, disconnecting it and reconnecting it. Then very slowly turn it on and light one burner at a time at turn to low heat. Then light additional burners the same way and adjust flame as needed after all are lit. Hope this helps! Douglas
Jun 06, 2010 | Weber Summit S-470 Propane Grill
Poor Propane Gas FLow
check the lines for a blockage check orffices are clean and the burners
May 15, 2010 | Weber Genesis Silver B Grill
My weber gas grill will not heat up past 300F
Hi John,
I just experienced the same exact problem ! I just bought a brand new Weber E-310 a 3 burner grill.
After I seasoned it up with cooking oil,I turned all the burners to high, opened the tank and clicked electrnic button several times , the grill was on then I went inside, I came out about an half-hour later and it was saying around 275 degrees..
I looked into my manual and there is a gas limit control valve that shuts down gas flow, when it thinks there is too much gas flow.
Sloution;
Turn the propane gas knob to off
Turn the gas grill knobs to Off.
Click the igniter several times to clear out any gas.
Then unscrew the regulator from the tank,( I then blew into the tank hole and regulator),
Screw back on the regulator to the propane tank.
I then clicked igniter again couple of times.
Now open your propane tank.
Then turn on front burner while clicking igniter, this will lite 1st burner.
Then turn 2nd burner on low then to high.
And if you have 3rd burner or more, turn low then to high!
John I did this and my grill went to 600 plus in a few minutes!!
The problem was turning the gas grill knobs on first then opening the tank then lighting...
You have to open propane tank with knobs off, THEN AS SOON AS YOU TURN ON 1ST KNOB, YOU MUST IGNITE ...
Mar 21, 2009 | Thermos Stainless Steel Gas Grill
Weber Silver B - 3 burner BBQ
Check your instruction manual, you have probably set off the safety valve in your propane tank. It is set to trigger if there is an open connection, such as turning on the jets when the tank is turned off. You may have to re-connect the tank...careful of course, make sure it's valve is off.
Aug 21, 2008 | Weber Q Grill
Low and Slow heating to temperature
have you recently changed propane tanks or refilled the propane tank?
What cycle are you using to turn it off and on?
Jun 23, 2008 | Weber Genesis Silver B Grill
Full propane tank - won't heat above 275 - Weber Silver A barbeque
How old of a grill is your Weber Silver A?
Did the tank come with your grill?
Fireplace-girl
Apr 26, 2008 | Weber Genesis Silver A Grill
Weber Genesis E-310 Gas Grill Logo
879 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Are you a Weber Grilling Expert? Answer questions, earn points and help others
