Question about Sub-Zero Bottom Freezer Refrigerator
Subzero 650: Ice Service light on
My Ice Service light is also on in my Subzero 650 also. Its no longer making ice. What can I do?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 102 Answers
Turn the unit off for a few minutes then back on. If you have a real problem that needs to be serviced the service and ice light will star flashing again relativly soon
Posted on Aug 05, 2009
Sub zero 650 slow ice maker
Hi Maureen,
Your sub-zero 650 should produce about 8 cubes every 2 hours. It sounds like the heater beneath the ice maker may be wearing out. Ice makers use a heating mechanism to warm the cubes in the mold and force them to easily eject. If the heater is failing in the back slot, it could cause the ice cube to get stuck. If this is the case, you usually need to replace the part or the entire ice maker.
It is also possible the mechanism isn't properly aligned. You could try adjusting it.
You can find two manual on FixYa here: http://www.fixya.com/support/p24667-sub_zero_650_o_bottom_freezer
Otherwise, I suggest contacting their customer service or a technician: http://www.subzero-wolf.com/contact-and-support/index.aspx
Best of Luck!
Dec 09, 2013 | Refrigerators
Icemaker on subzero 650 slow
check for water flow at water valve or replace water valve
Dec 09, 2013 | Sub-Zero 650 / O Bottom Freezer...
Flashing ice light service
Along with the service light, are you getting any fault codes with it (like EC and a number)? Under normal conditions, this would mean the the unit as a whole is running too much and needs to be cleaned. If cleaned and this is still an issue, you may need a certified person to look for cooling issue that only the computer is seeing. This can happen in a unit the is about 10-15 years old, normally in the fridge section. Do you have a ice ball or frost on the the back wall of the fridge section around the meat slide shelf? this would b a tell - tell sign of a cooling issue. If in doubt, call SubZero dIrectly at 800-888-7820 ask for a certified dealer to take care of you. Not every service company can work on the SubZero unit. (You want certified!)
I hope this helps.
Oct 10, 2013 | Sub-Zero 650 / O Bottom Freezer...
How do you get an icemaker in a subzero 650 refrigerator to stop making ice when the bin is full?
There should be a metal bar that flips when it hits the ice at a certain level. It should stop automatically. There is a problem with the sensor.
Oct 08, 2012 | Sub-Zero 650 / O Bottom Freezer...
My model 650 subzero ice maker won't make ice after cleaning out freezer drawer
make sure your ice tray in in the righ position. really important. the tray have to press the ice maker switch. or bad ice maker or bad water valve. also make sure to press the ice maker key. in the display. ONLY IN NEW MODELS
Mar 26, 2010 | Sub-Zero 650 / O Bottom Freezer...
My subzero 650 ice maker drips water w/o making ice. Makes a mess with ice build up. I had to turn off water lined to stop the ice maker from dripping. Turning off the ice maker switch did not stop the ice...
Good day,
No, a new water valve should solve that problem. The diaphram in the valve is not completely closing.
Very common problem.
Thank you for using FixYa
Dec 24, 2009 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero Bottom Freezer Refrigerator Logo
1,671 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
