Question about Yamaha RX-V2700 Receiver
RX-V1070 tuner fault
Have good connection to tuner,getting nothing but static
any fuses need checking or any other ideas?
  • 2,071 Answers
This only a cold solder symptom in tuner section .Just reworks all solder joints components parts in tuner section.
Good luck:
Regards:
Dont forget to rate.
Posted on Jun 30, 2009
Tx rx
the problem you now have is probably going to cost you more money to fix than the radio is worth. Could be a quick simple fix or you could be at it for hours trying to fix it. you will need a scope, frequency counter,watt meter, modulation meter, signal generator, volt meter,distortion meter,and a service manual from
www.cbtricks.com
Jun 18, 2013 | Galaxy Radios DX-33HML 40-Channels Base CB...
Speaker screech
For a starting point make sure that you are properly matched with you speakers for an 8 ohm system. Verify what your amp can handle and then make sure the speakers fit within that zone. A good amp can handle down to 2 ohms without a problem. Most like to operate at about 4 ohms at the lowest. If that is all good and you still have problems I will check back.
Sep 04, 2012 | Yamaha Audio Players & Recorders
I am trying to turn on my sirius radio (it has been working for 1 year) and all of a sudden it says 'check sr tuner'. Everything seems to be plugged in right yet it still won't turn on. Any ideas?
Page 62: If "CHECK SR TUNER" or "ANTENNA ERROR" appears in
the front panel display, the connection of the SiriusConnect
tuner or antenna is incorrect. In such cases, check the
connection of the SiriusConnect tuner and the antenna (see
page 115).
• If "NOT SUPPORTED" appears in the front panel display, this
unit does not support the connected SiriusConnect tuner.
Or the SR Tuner is fluky. Refer to its manual and start over with IT as the product, not the Yamaha.
Jul 13, 2010 | Yamaha RX-V663 Receiver
Yamaha RX-V757: Tuner not working
Is it set for XM / Sirius? If so, you need their special antennae unit; or are you talking AM & FM?
Jan 12, 2010 | Yamaha RX-V757 Receiver
Unable to connect to the network on a SSC21web monitor
is this poe cam? cable footage over 300 ft needs cat5 extender if fiber check media converter to see if single or multimode also check media converter for tx/rx or using cat5 b crossover cable connect directly to laptop type in ip in command bar enter
Oct 12, 2009 | Samsung Weather Resistant Security Camera...
NO Signal KV32fv26 Sony Trinitron
I think your problem is in tuner stage.
1. Check 32V dc available on BT connection on tuner.
2.If 32V available on BT,connect dc meter and put the unit on auto search and check the BT pin on tuner.The BT voltage will decrease and increase while it tunes.
3.If nothing stored after programming replace tuner.
Good luck
Dals123
Oct 14, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Hisense TC2919H Picture and Tuning fualt
I think you should be looking at the tuner itself or on the tuner board for a fault. First check for dry solder joints and if this is not the problem the electrolytic caps next to the tuner may be at fault. Good luck.
Oct 04, 2008 | Hisense Televison & Video
Proscan PS50700
Appreciate the direct "Ask Me".
Technically, when a TV signal is said to be snowy, it indicates that the incoming RF signal is weak; on the other hand, when a TV signal has static, this refers to electrical noise that goes with the TV signal.
Having said that, then to your concern:
  • for snowy signal, it is the cable providers problem. They have to change where your incoming cable is tapped from, check/replace the feedin cable itself or worst case scenario, replace the line amp/distribution amplifier feeding your cable input;
  • for static noise, what is required is to check possible sources which could include (but not be limited to) electronic ballasts of florescent lamps, electric fans, hair dryers, shavers, wireless phones, computers and others.
Additionally, you may want to check if you have any RF producing devices attached to the TV such as VCRs, DVDs, game consoles. You can try unplugging them when not in use.
Worst case scenario is the tuner block of the TV is getting weak (unlikely but possibly). You can try rewiring the cable to feed first into a VCR, connect the VCR to any of the free Video IN, and select channels through the VCR. If significant improvement, then you have just confirmed an internal fault with the TV tuner, if problem persists, then the static/noise/low RF is caused by something else.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 31, 2008 | Samsung TXE2745 TV
Volume light blinking, no sound.
Plug in some headphones as they are usually always active and see if you get any sound and volume control of them.
if not the switches may be stuck .
or the output fuses blown.
it gets sticky to work inside one of these without electronics experience and you can do more damage.
The fuses are about all you are allowed to fix.
Jan 05, 2008 | Yamaha RX-V992
Yamaha RX-V2700 Receiver Logo
186 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
