Question about Holux GR 213 Sirf Star III GPS Receiver
Can't install driver for Vista for a GR-213 - Holux GR 213 Sirf Star III GPS Receiver
  • 25 Answers
I'm not sure if this will help. I have had more than a few problems with Vista not installing drivers. One solution is when the installition cd in loaded in the drive, right click on the cd icon in Computer. Choose open, search for the setup.exe file and double click on it. After and If it installs, you may have to right click on the shortcut icon to and under the compatibality tab, check the box for run in compatilibity mode for XP.
Posted on Jun 30, 2009
Need a gps driver for gm1-86 sirf star
hi, i have just bought the gps. so i have the drivers, ive upload them to 2shared. http://www.2shared.com/file/-L-t-rNF/USB_GPS_Driver.html on the bottom off the page you are able to download it. Best regards, Jeff
Jun 13, 2010 | Holux GR 213 Sirf Star III GPS Receiver
Wer can i get sm bus cotroller driver for toshiba satellite pro l300-213 (vista os)
Try using a software called driver genius, it'll help you find and download you the drivers you need
Nov 06, 2009 | Toshiba Satellite Pro L300 Notebook
Vista driver for GR-D70 camcorder
not to be flippant, but ditch Vista and install XP - camcorder support in Vista, in my experience of it, is terrible.
Jun 16, 2009 | JVC GR-D73E Mini DV Digital Camcorder
PROBLEM DRIVERS
Go to the Holux support website at:
http://www.holux.com/JCore/en/support/downloadCenter.jsp
NOTE: All quote marks are added by me for emphasis only.
Under the "Select products Catagory" dropdown choose "GPS Receiver/Data Logger".
Under the "Select products series" dropdown choose "Mouse Type GPS Receiver" and
click on Submit. A new page opens showing various receivers. Scroll down to the GR-213u
GPS Receiver and see the one called "GR-213u Driver Program-Vista Driver". It is of a type
of file compression called "rar" which may require a unzip program. I use a free program,
"Secure Zip for Windows". Click on the little yellow box at the far right of the "GR-213u
Driver Program-Vista Driver" line. It will be labeled "9618869.rar". Save the file.
It should be found by clicking on the Vista START and then your user name & should be in
the "Downloads" folder as "9618869.rar".
Creat a new folder for the actual unzipped file by clicking on the the Vista START Icon
& then "Documents". Click on the "Organize" tab & then on the dropdown "New Folder".
Name the new folder "Holux Vista Drvr" & then open it.
Now back at the "Downloads" folder open (Unzip) the "9618869.rar" file. Copy the new
folder "GR-213u Driver Program-Vista Driver" to the "Holux Vista Drvr" folder you created
in "Documents", so that you can later delete all those files that may have built up in
"Downloads"folder from doing lots of downloading.
Open the "GR-213u Driver Program-Vista Driver" folder & see the setup file
"PL2303_Prolific_Vista_3301.exe". The size should be about 2724 KB. Open it to start the
driver install. Now you are almost done.
After Vista has done its driver install, go to "Control Panel" & open "Device Manager".
Now plug in your Holux GR-213 & the "Device Manager" should now show a new entry
called "Ports (COM & LPT). Click on the little + sign to expand it & you should see
"Prolific USB-to-Serial Comm Port (COM#)". The # represents your Comm Port number
used by the Holux. Right click on "Prolific USB-to-Serial Comm Port (COM#)" & click on
the dropdown "Properties". Click on the tab "Port Settings"at the top of the "Properties"
window. Change the value in "Bits per second" from 9600 to 4800 & click OK.
Hopefully you have installed the Holux Utility "GPS Viewer" with a shortcut on the
desktop. Open the "GPS Viewer" & click on "Scan". A new window "GPS Scanning" opens
showing GPS found at the same Comm Port # that shows in the "Device Manager". Click on
OK & the scan window closes now showing the same Comm Port#. Click on "Open GPS" &
then on "Cold Start or Warm Start" & all the satellites found should show up. You can close
the "GPS Viewer" & all the other open windows. If all went as described any software you
used with Win XP using GPS should work OK now with Vista.
Now run your software (MS S&T or whatever) & make sure its GPS Settings show the same
Comm Port# as in "GPS Viewer" & baud rate of 4800.
Jan 17, 2009 | Holux GR 213 Sirf Star III GPS Receiver
I NEED A JVC DRIVER MODEL GR-D850AA
I found a Fix for vista with my GR-D850 jvc the Startech.com (3 port IEEE-1394 firewire PCI Card) works on vista when installed the pci card I was able to down lowed to windows movie maker with no problems.
I hope this helps
Aug 27, 2008 | JVC GR-D850 Mini DV Camcorder
Driver for GR-D70 for OS Vista
I can't find the drivers for JVC GR-D70 for windows vista .pls help me
Jun 07, 2008 | JVC Cybercam GR-D70 Mini DV Digital...
Jvc gr-d20u software install
New driver may not be compatible to vista.. go back to jvc and see if they have a vista driver for U'r equipment.
May 21, 2008 | Computers & Internet
Vista 64 bit ( forgot to mention in previous message )
Hi! I had the same problem. I just find a working driver for my IEEE1394 here: http://www.unibrain.com/download/download.asp Download this: ubCore™ 5.20 for Windows Windows XP/Vista 64 bit After I installed it, my Vista can see my camcorder, but JVC drivers still missing. I wrote a mail for JVC and I'm waiting for the reply. This is all I can help at the moment. Loosh-T
Jul 09, 2007 | JVC GR-D50 Mini DV Digital Camcorder
Holux GR 213 Sirf Star III GPS Receiver Logo
780 people viewed this question
Top Holux GPS Experts
Oloyede Monsuru
Are you a Holux GPS Expert? Answer questions, earn points and help others
