Question about Dometic NDR 1292 Refrigerator
Same problem freezer is ice cold and the fridge is warm.
I defrosted for a day and restarted but the same problem exists? All american sport 385rlts 40' toy hauler 2006 model.
Thanks
  • streetcoupe Jun 30, 2009
    This is a freezer top/fridge bottom model and there is no control knob that I'm aware of. Dometic RM2652/RM2852.
    Thanks
  • 1,056 Answers
Make sure that the knob that controls the opening of the vent so the cold air in the freezer get to the refrigerator is operating. If it does, I don't see any reason why the refrigerator should not work.
Posted on Jun 30, 2009
  • Ronado Panaligan
    Ronado Panaligan Jun 30, 2009
    I will look into it again and try to help you. I will be back shortly.
Neff K3965 side-by-side American: Freezer works but Fridge doesn't any more, 3 days after defrost
Can you remove the freezer rear panel again and take some photos of the frost pattern so I may see what is stopping the cold airflow to the fresh food section?I'm here on Fixya if you have questions
Contact Me Here
Appliance 911 Sea Breeze
Nov 23, 2015 | Neff Refrigerators
Lamona fridge/freezer HJA6855. Freezers ok, but fridge isn't cold. One part of the fridge iced up, whilst the rest is warm. Light still working. Milk lasts 2 days! Please help. Thanks
  • Have you tried manually defrosting or checking the evaporator to see if it is frozen over? Just checking the ice pattern on the evaporator is important. Sounds to me your are having problems with the defrost components like the=> HJA6855 Defrost Heater
  • or the Defrost Timer? I am here should you have questions, Thanks John Tripp Appliance 911
Jul 12, 2015 | Refrigerators
Why does my refrigerator turns off restart a couple days later ?
Could be the back of the freezer is not defrosting and is packed up with ice. The cold air then can't circulate to the fridge part as the fan is frozen solid in ice. Had this happen due to a faulty transducer that tells the defrost system the freezer is iced up and to go into defrost mode. Also it could be the fan that blows cold air down into the fridge from the freezer compartment.
Aug 24, 2014 | Haier HNDE03VS (32 cu ft) Compact...
Kenmore classic bottom freezer refrigeration warm but freezer is cold
I would guess you have just caused a build up of ice to block the air way, which normally takes cold air into the fridge. manually defrost (unplug and wait until the ice goes away) then restart and it should be fine
Nov 11, 2013 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Fridge warm, freezer has frost on back panel & is defrosting, fans work, just changed defrost thermostat, no air is moving from freezer side to fridge side, drain pan under fridge is dry
this fan needs to run when the compressor runs,check fan blade for being jammed by ice if you have this much ice on back wall as ice will stall motor,if no fan there will be no cool air to refrige compartment also the defrost drain tray will fill with water then freeze over which in turn floods the freezer floor and refrige compartments cause it cannot drain to the pan in the bottom
May 11, 2012 | Kenmore Side by Side Refrigerator
GE 17.2 freezer on top fridge on bottom. Freezer is cold, but fridge is warm. Help!
Is there any frost buildup on the rear panel inside the freezer? If so you have a defrost problem of a bad defrost heater, defrost thermostat, or defrost timer/ control board. If no frost then you probably have a clogged defrost drain. Remove the rear panel to access drain hole.
Nov 09, 2011 | GE 17.2 Cu. Ft. Top-Freezer Refrigerator
Hi freezer on american style fridge freezer is
there is a defrost mode that melts any frost or ice on the evaporator coils and drains it into a pan under the fridge. if that drain is blocked, the water will pool inside. also check the door seals. if warm moist air leaks in, it'll condense on the cold interior and pool as well.
Nov 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Oklahoma Freezer cold fridge warm fan gets Ice build up !
You should not have to manually defrost. Your auto defrost system is not working. Check the timer usuall in the frig compartment near the thermostat ( a small hole, use a screwdrive flat tip 1/4" to rotate the timer till it clicks starting the defrost cycle) check freezer in 10-15 min should be defrosted if not you will need to check the heater and thermostat located behind the rear or bottom panel of the freezer.
The defrost timer could be under the box in the front behind kick panel or in the rear by the compressor.
Sep 22, 2009 | Haier HTE18WAA Top Freezer Refrigerator
Warm fridge cold freezer
Hi,advance thermostat setting, to get colder , it's possible you got defrost problem, is there excessive ice building inside back of freezer? to determine if you have a defrost problem, unplug ref. for about an hour,let it defrost, let all ice melt away, it's better to remove your produce, keep doors open to speed up defrosting, after defrosting and cleaning plug back your ref, and let it work for another hour, and check result, if it's o/k, put back your produce, let me know, during hot summer months, regular use (opening) of ref, could cause excessive ice build-up evap. if after defrosting and cleaning ref. work good for 3 to 4 days, but start doing the same thing, let me know, it means you got a defrost problem. also check your thermostat, but first defrost and clean it, that could just be your problem. good luck.
Aug 13, 2009 | Refrigerators
Freezer defrost LG american style
Defrost the unit for two days with the doors open...I know you're going to lose your contents. You may have ice on the coils internally. Next make sure you've cleaned the external coils under the unit. Leaving liquids open inside the unit or setting it colder than required will both cause issues like the ones you've got. Also, be sure all air vents inside the unit are unblocked and the door closes tightly all around.
Mar 09, 2008 | Refrigerators
Dometic NDR 1292 Refrigerator Logo
454 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
