Question about Kohler K-10270-4A-G Forte Centerset Lavatory Faucet with Traditional Lever...
Replacing the ceramic valve in the handle, how do you remove it?
Kohler Forte lavatory sink. K-10271-4 Replacing the ceramic valve in the handle (GP77005-RP). I can not remove it from the faucet. Is it a counter clockwise screw or do you pull it out? I have tried desperately to unscrew it, but it is totally stuck. I have used CLR, vinegar and oil to no avail. If anybody could give me help on this, I would greatly appreciate it.
If you try too hard to turn the valve to loosen it, it bends the copper piping that is attached.
  • 297 Answers
It has a screw down cap on top of the valve.counterclock wise.then pull straight up on valve. if you twist the supply line while doing this disconnect the line first then work on valve.
Posted on Jul 15, 2009
How do I replace a cartridge for kohler bancroft sink faucet?
kohler bancroft is the sink manufacturer, not the faucet mfgr. do you have a clue what faucet mfgr it might be?
Jan 14, 2018 | Kohler K-10577-4-SN Bancroft Widespread...
How do I get the handle off so I can tighten it up to eliminate wobble
look for a small hole in the bottom of the faucet handle,, it holds a allen type or a slotted screw for retaining the handle,, ( more than likely on a moen or Kohler its going to be a allen head,) ,, remove that and your handle should come off
Sep 16, 2011 | KOHLER Forte Widespread Lavatory Faucet...
Lav center set faucet handle removal model K10271
The handle may be secured with a set screw in the body of the handle that must be loosened before the handle will lift off the valve - the set screw will require an appropriately-sized hex (or "allen") wrench. If you cannot find a set screw on the handle, then the handle is friction fit - in which case no tools are required, just a bit of force to lift the handle off.
Hope this helps. Post a reply if you need further assistance.
DIYpro
May 17, 2011 | Kohler K-10270-4A-G Forte Centerset...
How to remove button on handle model 10271 leaks when hot or cold water is on centerset lavatory faucet
I've used both the corner of a credit card and also a very small flat head screw driver. Be careful not to scratch the finish.
Mar 07, 2011 | Kohler Home
Leaking from handle, how does the handle come off?
There is a small set screw on the handle it may be covered with a small cover that needs to be removed to reveal the set screw.
Mar 04, 2011 | Kohler K-10270-4-BV Forte Two Handle...
Our cold water handle has to be removed and cleaned every month or so in order for the fawcett to move freely. The hot water handle seems to be fine. It's a Kohler forte and is around 3 years old. Thank...
This is due to impurities in the water. The hot water heater separates alot of the crud in the water and the cold water goes right to the sink. adding a filter to your system will prevent the buildup.
Thank you Joe
Feb 15, 2011 | Kohler Forte Two Handle Centerset Lavatory...
I have a 2 handle bath faucet and am trying to remove valve. Can't turn nut either way. Any recomendations to help loosen nut? Which way does the nut turn? The brass nut and stem are pretty green. Been...
righty tighty, lefty loosey. if its too tight for wrench youll need a deep socket wrench that will fit it.my hats off to you. kohler makes a good faucet,if stem is shot you can find new ones at lowes.seat is also replaceble
Jan 26, 2011 | Kohler Forte Two Handle Centerset Lavatory...
My faucet is running a steady stream of water. I am not very handy. How do I fix this? Do I have to take the faucet apart on from under the sink and then try to fix something that way, or can I take off...
Replace the valve cartridge. Instructions are here. http://411plumb.com/kohler-forte-faucet-troubleshooting-repair-guide You can take the cartridge to a plumbing supply store to be sure you get the right replacement. If you replace both, be sure to put the new hot and cold cartridges in the correct places.
Hardware stores carry many cartridges. You can check there first if it is more convenient.
Jan 16, 2011 | Kohler Forte Two Handle Centerset Lavatory...
Water leaks around the hot water handle when I turn on the water.
what valve do you have. most likely you will need to replace the cartridges
Jul 28, 2010 | Kohler Forte Two Handle Centerset Lavatory...
Cannot remove Kohler ceramic valve
is this a single handle faucet. If not the part goes in under the handle
Nov 02, 2017 | Kohler Model 10433: Fort® Single-control...
Kohler K-10270-4A-G Forte Centerset Lavatory Faucet with Traditional Lever... Logo
1,716 people viewed this question
Top Kohler Plumbing Experts
Mike
Paul Carew
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
