Iam experiencing problems with a panasonic data projector getting interferance across displayed image but does not happen with a laptop but alawys with a desktop even if we try swapping it or running the pc through a UPS.
  • guspower Jun 30, 2009
    The Desktop PC is a new one with updated software and should if anything be better than the laptop.The problem seems a lot worse if the stage spotlights are dimmed on and off.At times this can even cause total loss of the video image.I have tried running the data projector from the same switchboard as the stage control desk and where pc is located this has made some differance but not perfect.The video image runs through a 5 BNC cable which should be quite good and is also on a booster due to +-70 meter run.
    I have tried VGA/RGB Cables with no real results and then went to the beldon 5 BNC which is better than them.I do have a Cat 5 cable over to there and was going to try running it over the with a scaler on both ends one to recieve and other to transmit.Somhow though I really feel that this will be just another time waster as this will also pick up the interferance.I am thinking it to be a problem with the power in the building being a problem.Calling all help ,Thanks
  • 615 Answers
Dear friend
1.Remove the UPS connect the PC to directly because UPS may cause magnetic effect on Projector...then try projector... if not solves your problem
2.Check Your PC for VGA drivers are correctly installed or not.go to device manager check VGA drivers are installed if it is not install proper VGA driver for *********** board then try again.
3.If You are using PCI express or AGP card then check the display settings >>> Advanced VGA properties check Image balance settings..
I think it helps
Posted on Jun 30, 2009
You mention using a booster, but it seems there is still some attenuation or interference along the way of the cable run. Can you try connecting the desktop to the projector using a normal, shorter cable and see if the shorter distance makes a difference?
Thanks.
    Novelist:
  • 166 Answers
Actually such intereference is simply due to the serial data transmission error in the respective port of desktop PC. It is because, most of the data projector drivers and software are made for advanced laptops only but they are not properly compatible with Desktop systems. In that case, such intereference problem is very inherent. We recommend you to upgrade your desktop with all latest configurations & OS also.
It was my pleasure helping you.
With Regards,
Shyny Saxena
Projector Image Cut Off, Native Resolution Not Recognized by PC
after you connect the laptop and the image shifts to the right, press auto adjust on the remote and the image will get OK.
If not try resetting the projector settings to factory [not the lamp settings]
this should solve the problem
if not change the main board
Jan 15, 2013 | Panasonic PT-AE900U Multimedia Projector
Panasonic PT-AX200U projector. input display flashes on and off.
It could be your source and not the projector. If it is a laptop then hit function four and change how it shares display. Over all I need more info as to how it is plugged in and what you are trying to view from.
Jan 08, 2013 | Panasonic PT-AX200U Projector
HOW TO CONNECT PANASONIC PT-LB75 DATA PROJECTOR TO HP LAPTOP
Hi!
-Connect the VGA Cable of the Projector to the VGA out connector of the laptop.
-Power on the Projector and Laptop
-You should get the display from the projector.
(If not Press FN+ the key marked for external display switching) If you have Windows 7 on you laptop, you can use WIN KEY+P to switch the display.
Hope it helps! Good Luck!
Thanks for using Fixya!
CreativeTECH
May 31, 2011 | Panasonic Computers & Internet
First time using infocus 1x projector with this laptop - installed drivers but there is no start up screen on the projector and will not display laptop image.
You have to tell the computer you hooked up an additional external monitor. Lower left on the keyboard you will see a "FN" key. Across the top, your F keys...look for an icon that looks like a monitor. Usually F5, F7 or F8. Hold down the FN key and select the F5 etc key which is the command to display the image through the external port. Doing this once displays image through the projector and laptop. Twice displays image to projector only and three times returns to display only on laptop again.
Jun 19, 2010 | InFocus LP640 Projector Multimedia...
TravelMate 3270-6569 (LX.TH706.051) PC Notebook: My acer travelmate 3270 is connected to a sony dat...
Try holding down the Function key (Fn), then pressing F5. Wait a few seconds. On most laptop, each press of the F5 key will toggle between laptop display only, projector only and Dual (same image on both - my favorite).
You'll probably see a little Monitor-shaped icon on the F5 key. It's possible it's another function key - on Dells it's usually F8.
Aug 02, 2017 | Acer TravelMate 3270-6569 Notebook
Laptop screen image is truncated on data projector display (Dell)
Had the same problem, tried a Factory Reset from the menu and it seems to have worked. Don't know what caused in in the first place
Nov 11, 2009 | Dell Office Equipment & Supplies
LCD projector not displaying image of the laptop
On that Dell, you have to tell the laptop to display the image on an external unit--look on either F4 or F8--you will find a small TV screen symbol. You have to press and hold "alt" and press the key. The options are, 1-show image on just the laptop, 2-show the image on the laptop *and* something else, (like a projector), or 3-show an image on JUST an external display. NOTE: Sometimes, you have to turn on the projector FIRST, then immediately turn on the laptop so they boot together--just one of those strange things...(remember, **for example** first press of "alt" F4 will get you laptop and projector, second press of "alt F4 will get you JUST the projector, third press of the keys will bring you back to just the laptop)---Rick
Sep 07, 2009 | Panasonic PT LC75U Multimedia Projector
Need to see display on both laptop and projector
On most laptops pressing the Fn key plus the F5 key (in your model laptop) several times will cause the video to switch to different options
In the various laptops I've used with data projectors it is the same.
If you plug in the data projector and power it up then the laptop then the Windows image will be on the data projector (provided the laptop's screen resolution matches the data projector).
To toggle between the data projector only, the LCD screen, then LCD screen plus data projector, and or back through this sequence, just press the Fn key and the F5 key to get the displays you want .
May 20, 2009 | Toshiba Tecra M10 Notebook
I con't connect with lcd projector, xp windows
The video output will automatically switch to the data projector first when you power up the data projector first and then boot up the laptop.
When you power up the laptop first you can toggle the Windows image between the LCD screen and the video port/data projector by pressing the Fn key plus the F4 key. Pressing these keys each time will switch the display from LCD screen to video port only, to both LCD screen and video port, and back to LCD screen only.
May 14, 2009 | HP Compaq Presario V6000T Notebook
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
