Question about Friedrich QuietMaster Electric SS10J10AR Air Conditioner
A/c quit and fan on control side quit at same time
    Scholar:
  • 70 Answers
Check breaker and outlet. Switch or stat may be bad. You will need a meter or something to plug into outlet if it 120vac.
Posted on Jun 30, 2009
My Frigidaire refrigerator quit cooling in the fridge side. Freezer side works OK
Sounds like a defrost problem. Is there frost build up on inside back wall of freezer? If heater is good, the control or the defrost thermostat may be bad. Is fan in freezer and fan at compressor running?
Nov 01, 2017 | Frigidaire Refrigerators
Why would my climate control fan quit operating?
It may be a fuse, you would have to check your fuse box. I would check the fan itself. Whether an old fan or a new fan , ware does occur sometimes fast sometime it takes years. Check fan buy moving fan shaft up and down ,side to side. if it moves fan bushings are bad. Sometimes you can repair if your capable, but most times you just replace the fan. GOOD LUCK FRIEND.
Sep 15, 2014 | Cars & Trucks
Ref has quit running/cooling. Lights inside are on, the lights on the temp controlls are off. Any isea?
I ran into this problem last year on the same or similar model.
if there is no cooling or fans or compressor running ,but lights are on in both compartments,and no control numbers are on the electronic control mounted to the left of the compressor is the cause of the
problem. It is expensive but rebuilts are available on Ebay .Ive
used national rebuilder parts many times,with excelent results.
Apr 30, 2014 | KitchenAid Superba Architect KSCS25INSS...
1995 chev tahoe...AC quit working. fan would
There is a resistor panel that controls the fan speeds behind the glove box on the dash. You remove the glove box and you will see the airbox. Sitting down in the left top, with 2 screws holding it in, will be the resistor panel. It consists of 4 springs and a resistor. All out of veiw, inside the airbox. Remove the 2 screws and unplug the plug. Pull out the old resistor and replace with the new one. It only cost around $15-20 bucks at the local auto part store. This will get your fan blowing. If your fan is blowing but the air is not cold, I would suggest to check and see if the compressor clutch is working properly. If not, try giving it a light tap while running. If it is working, you may want to recharge your freon.
Jul 05, 2010 | 1995 Chevrolet Tahoe
Whirlpool quit working - can hear short buzzing and fan
you might want to try a 3in1 starter kit for the compressor,you can get it from your local appliance parts store,it has instuctions on it,it is easy to do-mike
Feb 05, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer is warm at top and cold on the bottom.
Sounds as tho your evap fan is not running. Open door to freezer and should hear a fan running smoothly. If not most of the time the problems is with the main control board on back of refrigerator.
Jan 27, 2010 | GE Profile PSW26P Stainless Steel Side by...
Evap fan stops running/low cooling, Unplug Frig Evap fan runs
Is there anything obstructing the fan area, ice build up ? It is normal for your freezer to get warm if evap fan is not working, it is essential for it to work :) A defrost cycle should kick on a timer or as needed (adaptive) and there should not be excessive frost buildup that it blocks your evap fan. I would have suggested you unplug your refrigerator for about 10 minutes and see if that resets your control board - if not, then you will need service - either replacing motor assembly or a faulty control board.
Aug 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer side not cooling
Check the condensor fan in the freezer and the thermostat that controls the fan.
Apr 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fan control relay
Quite often you'll find resistor on firewall, of passenger side under hood. 1-1/2"x3" block attached to firewall. In area of where heater hoses enter.
Mar 09, 2009 | 1990 Plymouth Sundance
Rinnai C85 doesn't quit running. It's been running for 1 hr. straight. Only stopped after I turn the switch off and back on again. I wasn't using any water during this time.
there is no water leaking any where on the hot side any where> Is the burner runnig or is it just the fan? if it is the fan the circuit board could have a defect if it is the burner the control is what is bad
Feb 20, 2009 | Rinnai Digital Remote Water Heater Control...
Friedrich QuietMaster Electric SS10J10AR Air Conditioner Logo
102 people viewed this question
Top Friedrich Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Tim Whalen
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
