Question about i-mate PDA2k Pocket PC
Imate ring tones
I've dowlaodaed an mp3 piece of music on my i-mate PDA2k and I want to make it my ringtone but I cant. How do I do it or is it not possible?
  • 3 Answers
Re: imate ring tones
Yes it's possible but not as an mp3 file. I have found that you have to convert the mp3 to a wav file. I do this using Fission on my Mac but I'm sure there's a pc equivalent. When you send the wav file to the pda2k it will say it doesn't recognise the file. You need to 'send it anyway'.
When you have it on your phone - there is an option under settings to 'add ringtone'. Once you have done this, the tone/song you are adding will be available for use AS a ringtone.
The pda2k will play mp3 just fine with windows media player but cannot use these as a ringtone unless you convert them.
Hope it's of some help.
Posted on May 10, 2009
0 characters
3 Points
PDA2k Pocket PC: how do i install antivirous in my imate pda2k?...
download this file.copy to your device and run!
May 06, 2010 | i-mate PDA2k Pocket PC
My imate pda2k cd was losted how can i use my imate pda2k with my
In the CD, you find:
  1. User Manual
  2. Microsoft Active Sync
  3. Other such stuff
All such stuff can be acquired again from the imate website:
Go there,
Select your phone from the support> Device support section and find everything you want.
Please Rate...
Sep 05, 2009 | i-mate PDA2k Pocket PC
How can I add a ringtone of my choice to a i-mate PDAL? It just has customised ringtones & I am not able to play an added rigtone on the device.
Just press and hold on the ringtone or mp3 which you want with the stick and then select set as ring tone
May 17, 2009 | i-mate PDAL Pocket PC
Imate --jama
check the option of "discoverable to other" option in ur blue tooth option then u'll be able receive data and ring tone...copy ur tones to mydevice\windows\rings..then u'll b able to set ringtones...also may b ur mp3 tunes will not work..if not then u have to conver it to .wav or .arm..
Feb 27, 2009 | i-mate JAM Pocket PC
Imate- jama
just go to connections-beam- & click on recieve all incomming beams. thats it
I have an I-mate pda2k and have found that if I convert the mp3 to a wav file (using Fission on the mac) I can assign any of these as a ring tone. There is an option in settings to 'add ringtones' and this is where you set the wavs to be used. They do not have the ability to apply an mp3 as a ringtone, however they WILL play your mp3s with windows media player.
Not a solution but a part explanation lol
Hope it helps someone.
Dec 12, 2008 | PDAs
Setting personal music as ringtone
open your music files select your music to be used as ring tone. hit menu. then use as ringtone
Dec 07, 2008 | HTC G1
Companion CD of imate pda2k
the CDis with me. if you want it I can make a copy and send it to you.
Jul 02, 2008 | i-mate PDA2k Pocket PC
I-mate smartphone
you cant set regular songs (mp3) as ring tones. only ring tone files (m4a,wav) as ring tones. they are shortened versions. try Http://
for some good ring tones that are totally free
Jun 16, 2008 | i-mate Smartflip Smartphone
Imate PDA2k
Contact the imate customer service, they should be able to help you. Or you could look on the site for the english OS.
Jul 24, 2007 | i-mate PDA2k Pocket PC
i-mate PDA2k Pocket PC Logo
258 people viewed this question
Top i-mate PDAs Experts
Martin Murray
bharat patel
Are you an i-mate PDA Expert? Answer questions, earn points and help others
