Question about GE Washing Machines
End of drain hose is too short
I bought a GE top load washer. My problem is the drain hose. I need some kind of extension on the end that goes into the drain pipe. The end of the drain hose doesn't go deep enough into the drain pipe...water sprays out when the washer drains. I have seen many hose extensions online, but I need the end of the hose longer. Any ideas would be helpful.
Thanks
  • 10 more comments
  • lmitch4 Jun 30, 2009
    Sound like it will work...I'll give it a shot .
    Thanks
    I'm having trouble with the hose that drains the washer. It dosen't go deep enough into the stand pipe.
    It's a GE top loader. Don't have the model info on hand.
    I have a GE top load washer. When it is draining water sprays out of the stand pipe. The stand pipe is not clogged. Either I need some kind of extension on the end of the hose so it goes into the drain pipe deeper. Or I need to add to my stand pipe??? If so how?
    Sorry...I don't understand.
    The drain hose pops out of the stand pipe when draining.
  • lmitch4 Jul 01, 2009
    HI ...how to I check the drain control lever? This is a brand new GE top load washer.
    The drain pipe is higher than the washer. Do you think I need to make the drain pipe higher? That is what Home Depot is suggesting. If the frain hose from the washer goes down deeper into the pipe , it may still spray out because the washer pump is so strong.
    How high is the standpipe supposed to be?
    OK...I bought a new washer. It seems from what I've heard the water discharge pumps are more powerful now. So, when my washer drains the watershoots out of the drain hose at a fast pace...it fills up the standpipe and sprays water all over the floor. What to do??
    That sound like a good solution but the drain has been cleaned recently.
  • lmitch4 Jul 02, 2009
    Thank you so much for your help. I'm sure one of these solutions will work. Thanks again!
  • 15,935 Answers
This is not a drain hose issue - the problem lies in your drain pipe or trap.
Have the line snaked out to remove lint buildup.
Your drain line (by code) must be a minimum of 1.2" pipe, and have a pitch of 4:1 (4 feet of pipe to 1" of slope)
If the drain is Galvanized pipe - there is a good chance it has sediment buildup and is not draining quick enough.
The reason the hose is short after the radius bend is that there must be an air gap to prevent siphoning back into your washer.
Have the line cleared and I'm sure it will work fine.
Thanks for using FixYa!!
Posted on Jul 01, 2009
  • blueextc3221
    blueextc3221 Jul 01, 2009
    The U-hook on your drain hose should just hang in the drain pipe--the diameter
    of the drain hose hook should be less than the diameter of the drain stand pipe.
    Typically, drain hose diameters are around 1" o.d. and standard drain stand pipe
    diameters are 2" o.d. The hook of the drain hose is simply placed into the drain
    pipe and secured with either duct tape or a tie wrap. You can see that this
    creates a natural air break which you should not try to obstruct. If your drain
    meets these criteria and you're getting the suds-back condition, then we need to
    consider a couple of other things
    The problem with the new washing
    machines, is that they dump 20-22 gallons of water in 4-5 seconds. This
    amount is far more than the garden hose test will submit the drain to. Here are
    a number of solutions, I hope that one of these will help you.
    #1 As mentioned above, you can restrict the
    flow of the drain pipe. I recommend a 3/4" x 6" brass nipple, or a 1/2" x 6"
    brass nipple, depending on your specific situation. The brass nipple will not
    corrode like a galvanized nipple.
    #2
    There is also a rubber cap that you attach to the drain pipe that fits around
    the drain hose tightly.
    #3 Some
    situations might require that you have to raise your drain pipe. It is
    recommended that it be at least 36". This allows for gravity to assist the
    drain.
    #4 Some situations will require
    that the drain pipe be increase in diameter. Older plumbing applications were
    installed using 1 1/2" piping. With the newer washing
    machine discharge volume, the 1 1/2" pipes will not support the discharge.
    Your drain line will need to be changed to 2". This option will be one of the
    more costly fixes, depending on the amount of line that needs to be changed.
    #5 Some plumbing installations installed
    without a p-trap will need to be changed. The p-trap keeps sewer gas from coming
    back into the house. It
    also allows for a smooth transition into the drain line. Any restrictions in the
    drain line (i.e. ells, tees,) will cause the soap in the gray water to foam up
    which will cause the drain line to slowly back up
    :D
    President:
  • 1,952 Answers
Hose line just 1 or2 meter lenth then over lenth not nececsary so drain is in conviniant
Posted on Jun 30, 2009
  • 67 Answers
You can order the extensions on ebay for a low price i just look it up it seems like it would work to you washer
    Genius:
  • 1,847 Answers
Yes you are correct on this, the drain pipe is higher than the washer and need to make the drain pipe higher.
Thanks
Kinldy rate the answer
Kevin
    President:
  • 942 Answers
Hi can you do this step,
  • Check the drain hose, it should be at least as high as the top of the wash tub, about 38 inches.
  • The drain hose must sit loosely in the house drain. Do not seal the air gap around the drain hose or a siphon will occur.
  • Check the drain control lever
  • Test the drain control coils
  • Check the cam bar
Good luck!!!
Regards
PCmania
  • Neciforo Llanto Jul 01, 2009
    Hi, So you need to buy a coupling to connect the extension hose to the drain hose, and just connect an extension hose which is level to your washer so that the water can not sprays,
    Good luck!!!
    Regards
    PCmania
    Hi
    During drain and spin only
    A
    washer that leaks only during the spin cycle often has a leak in the
    main drain hose. Inspect the entire hose and correct any problem you
    find. Alternatively, the steel or plastic outer tubs can rust, split,
    or be punctured. This may be most visible during large loads and high
    water levels. If this happens, you may have to replace the entire outer
    tub--but that may not be an economical repair to make. Consult a
    qualified appliance repair technician for further details.
    All the time
    If the washer leaks all the time, check these:
    • Hot
      and cold water fill hoses - Check the hot and cold water hoses from the
      household plumbing. If either hose is leaking, tighten it or replace
      it, as appropriate.
    • Main tub seal - The main tub seal
      is located between the transmission and the outer tub. It's the primary
      water seal in the outer tub for the transmission-shaft entry point. If
      this seal leaks, you can see the leak by opening up the machine's main
      access panel while the machine is full of water with a small amount of
      detergent in it. The leak appears at the underside of the outer tub, at
      or near the center. This seal is difficult to replace. You probably
      should call a qualified appliance repair technician.
    • Pump
      - If the pump leaks, you can probably spot the leak when the tub is
      full of water. The pump has two or more black rubber or plastic hoses
      attached to it and usually has a drive belt that spins the pump. If the
      pump is leaking, you need to replace it.
    • Outer tub -
      Over time, the steel or plastic outer tubs can rust, split, or be
      punctured. If this happens, you may have to replace the entire outer
    Goodluck!!
    PCmania
  • 64 Answers
If you are looking for the cheapest way out, try wrapping duct tape around the end about 5 or 6 times and then see if it fits in to the pipe. If it's still loose keep wrapping the tape around until you have a nice snug fit. Good luck.
    Sergeant:
    Novelist:
  • 198 Answers
This maybe a good article for you.
http://www.askmehelpdesk.com/plumbing/washing-machine-discharge-hose-length-4320.html
Quote:
Re: Washing Machine Discharge Hose Length Good morning Alex, Your question is: I would like to move my washing machine from its current position, directly in front of our utility tubs. The new location will require a discharge hose close to 15' long. (The washer inlet hoses will be about as long, too.)
Is there any problem with this? (No) Where can I get this length of this kind of hose? (Any hardware store, ask for reinforced diswasher discharge hose. ) Can I shape it? (It needs to go around three 90-degree horizontal turns.) ( yes, the pump discharges with great pressure)
Should I run it along the floor, then up near the tub, or should I run it up first, the across to the tub? (To advoid water draining back into the washer after the pump shuts down you must loop the hose up over the flood rim of the washer and maintain that elevation, giving it just a little slope so that it drains completly. If you wish to drop and run it around the floor you will have to install a check valve in the discharge line. Be advised that if you do this you will have standing water left in the hose untill the next washing.)
Should I try to reuse the hose I have by cutting it and inserting connectors and more hose (with hose clamps), or not? ( By inserting connectors you choke down on the volume a little. While I don't think this will bother any I would still like the hose to be one piece.) If you have more questions, feel free to click on back. Regards, Tom
    President:
  • 2,923 Answers
Kindly check the link below and check the available hoses and see which hose you need:
http://images.google.com.ph/imgres?imgurl=http://images.bizrate.com/resize%3Fsq%3D60%26uid%3D899473730&imgrefurl=http://www.bizrate.com/washers_dryers/products__keyword--ge%2Bwashing%2Bmachine%2Bdrain%2Bhose.html&usg=__IDDkVDk-wvkwRp_kbjBbI4sHsZM=&h=60&w=60&sz=2&hl=tl&start=12&sig2=f--f42yrSNrGUfS3UbAzIw&um=1&tbnid=gbm_83ARHh9RRM:&tbnh=60&tbnw=60&prev=/images%3Fq%3DGE%2Btop%2Bload%2Bwasher%2Bdrain%2Bhose%2Bextension%26hl%3Dtl%26client%3Dfirefox-a%26channel%3Ds%26rls%3Dorg.mozilla:en-US:official%26sa%3DN%26um%3D1&ei=GIxKSueyHM-6lAfUrK0J
Hope this helps and have a great day!
  • 583 Answers
This problem occurs in many machines
A/washer rubber fill hose can for sure burst. Shut the water taps off when you are away on vacation and in between laundry days. If you want to help remove this trouble maker, install stainless steel hoses. They can be expensive, but will be much cheaper than mopping up the basement or laundry room.Built in dishwashers should have the hot water line made either from copper or a similar substance. Often a rubber or plastic hose is installed because they are cheap to purchase. These rubber and plastic fill lines often burst. This could damage your house cabinets and your insurance may not help if the dishwasher has not been installed properly. A stainless steel fill hose line is available for the hot water feed.
click the link directly
http://www.applianceaid.com/stainless-steel.html
  • 749 Answers
What is the make/model
  • 294 Answers
Boss its a pretty simple job. let me take it slow.
Washing machines don't come with extension hoses.
They have two hoses with coloured ends - red and blue and a third hose -normally connected permanently to the machine, which is usually plain grey - this is the dirty water outlet and should be placed into a drain tube. The machine's instructions will explain this for you - often with pictures.
The red (hot) and blue (cold) hoses screw into the back of the machine using the right-angled connectors. make sure that they're tight but do not use pliers (the plastic fittings and threads damage easily.)
The other end of the hoses ( the 'straight' connectors) are screwed to the small hot and cold taps which are provided in your utility area (or often under the sink). You can recognise them because they often have small red/blue handles on top.
If you don't have these little water feed taps then you must get a plumber to install them. It shouldn't take him more than a couple of hours of paid labour time because they're not a difficult job.
If the feed-water hoses are not long enough then you buy longer ones from a decent hardware shop. You should be able to get 2.5 metre ones if you search.(also Ebay.,price..$2-$7)
If you need to use extra hoses as extensions then you should ask for a (usually brass) "back-to-back" or "male-to-male" BSP coupler. You can get these from B&Q or Wikes or a good plumbers shop. If in doubt take one of the hoses with you to check the thread. The cost a couple of quid each.
i could be surprise i did not solve u issue...cos this is wat i do for living.. Good Luck enjoy....... I guess this Old man deserve a drink frm U. >>>>cheers!!!
GE Washer won't drain
check the end of the hose and see if thier's no water flow when it's draining..maybe ur waterpump not working properly or the're lint blocking the waterpump
Mar 11, 2014 | GE WPGT9350C Top Load Washer
Ge top load won't spin but it will drain
yes,most likely the lid switch,but have seen in rare cases the pressure switch hose from the tub to the pressure can be partially plugged up with soap residue and not letting the units pressure switch start the spin cycle,remove the hose on one end and make sure the tub side isnt blocked by blowing into the end of the hose,then remove the other end of the hose and blow into the hose and make sure the pressure switch clicks as in changing positions
Apr 19, 2013 | GE WHRE5550K Top Load Washer
How to replace drain hose
Losen clamp on the end that goes to washer and put new one on
Dec 27, 2011 | GE WDSR2080D Top Load Washer
Ge # wbb4500e1ww stops during fill, wash,spin and rinse cycle intermitenly there is no regular pattern we can follow. We are lost as to what to do
Check your hose end. On your hoses there are screens at the end that goes on the washer, and that screen could be plug enough to intermitent.
Dec 07, 2009 | GE WBB4500EWW Top Load Washer
GE Drain Hose
Hi, Does this washer have to pump the water up into a drain? If it is possible, it would be better for the machine if you can bring the drin pipe closer to the washer. I know it is not always a possibilty. The longer the drain hose, the harder it is on the washer and sometimes the cloths don't spin out as dry as they will with a short drain hose.
Vic
Jun 20, 2009 | GE Profile WPRE6100G Top Load Washer
Washing machine drain hose too short
add extension with hose clamps will be fine
May 26, 2009 | Washing Machines
My GE WCSE4160B2WW top load washer is leaking.
Check the easy stuff first, fill hoses tight?- drain hose cracked? Failing those checks, cut a piece of cardboard slightly smaller than the size of your washer. Slip the cardboard under the washer and run a short load. Look carefully at the water mark on the cardboard. The mark on the cardboard the water leak will leave, will help you tell from which side or front to back the leak is common from. This will help point you in the correct direction to look for the trouble maker
thanks.
Nov 05, 2008 | GE WWSE5240D Top Load Washer
Front load ge washer does not finish cycle
This model does not have a drain filter. There are filter screens inside the inlet valve where the hoses attach onto the machine. Take hoses off and look inside where the water goes into machine to see screens. Also, take the other end off hoses to make sure there are not screened hose washers in either end of the hose which may need to be cleaned or replaced.
Oct 18, 2008 | GE WSXH208A Front Load Washer
GE FRONT LOAD WASHER
Plugged drain hose (which you can easily remove and clean) or slow running household drains.
The drain hose is the approx.2' diameter black hose on the back of the washer that is clamped to the washer and the other end goes into a standpipe or a wall drain. Be sure to turn off your washer and unplug it and have some old towels handy and maybe a bucket!
If there is nothing in the drain pipe, then I would suspect a plug somewhere else in your house that is preventing draining.
Thank you for using Fix Ya and for rating this solution.
May 21, 2008 | GE WPXH214A Front Load Washer
GE washer - Excessive shaking in between phases
how old is the washer? depending on the age and the model the problem could be different things
Jun 23, 2007 | GE WBSE3120B Top Load Washer
Washing Machines Logo
1,142 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
