Router will not receive an ip address. have to
Router will not receive an ip address. have to plug network cable directly into cable modem.
    Genius:
  • 1,269 Answers
You need to hard reset the router first by pressing the reset button at the back of it for 30 sec. Then do a power cycle. Unplug the power to the router first then the modem. Make sure the modem is plugged in to the Internet/WAN port and your PC to port 1 of the router. After 1 min power on the modem first then wait for the lights to go solid, then power on the router. If you still you don't have internet, you need to perform MAC Address Cloning. Open the router's Setup Page and look for MAC Address Clone feature, enable it and save. Perform a power cycle again. That should do it.
Posted on Jun 30, 2009
I plug my ethernet cable to my router/modem. But it doesn't work. I cannot listen to any radio.
Somewhere in the setup or settings for the network on your receiver make sure DHCP is turned on. DHCP (Dynamic Host Control Protocol) allows it to get a IP address and subnet from the router so it functions on the network. Likewise DHCP must be enabled on the router as well otherwise the downstream device (your receiver) won't be able to get an IP address.
Oct 14, 2013 | Yamaha RX-N600 Receiver
Release ip address. I want to be seen on the internet with a different IP address. When I plug the cable modem directly into my computer I can release and renew and get a new IP with the network card, this...
The easiest way to release and renew your IP with a router that doesn't have that feature is to unplug the modem (not the router) for a few minutes - overnight while your sleeping to be sure.
May 23, 2011 | U.S. Robotics MAXg USR5461 Router
The globe light is blinking. We can connect to Belkin but page not found comes up. The message that comes up says IP address does not match. We have 3 laptops, and none of them are allowing us to have...
  • Connect your computer directly to your cable or DSL modem. If you see a log-in screen for your Internet Service Provider, make a note of the user name and password.
  • Unplug your router and your cable or DSL modem.
  • Plug your modem to your Belkin router's "WAN" port. Connect your computer to one of your Belkin router's numbered ports.
  • Turn on in your modem and wait 10 seconds. Plug in your router and restart your computer.
  • Select "Start," then "Control Panel" and then "Network Connections." Right-click "Local Area Connection" to bring up your network connection properties.
  • Click "Internet Protocol (TCP/IP)," then "Obtain an IP Address Automatically" and then "Obtain DNS Server Addresses Automatically."
  • Open your web browser. If you are prompted for a user name and password, enter the information you recorded in Step 1
  • Dec 29, 2010 | Belkin F5D8236-4 Router
    Hi, Our modem seems to work fine when plugged directly into a computer (we get internet okay), but if we plug it into anything else it won't get internet. We've tried two different routers and a Wii and...
    Without further information, my best guess is that your modem has the same IP address as the common IP address for routers and probably the Wii. Most wireless routers have the address 192.168.1.1
    Try connecting a computer using a hard line (a network cable) to your router and type in this address, it will most likely come up. If it does change it's static address to 192.168.1.12 (actually any number behind the last period above 1 and under 255.). Also set its gateway to 192.168.1.1 to access your modem. (Also in the router settings which are found by typing the address mentioned above, 192.168.1.1) Be sure to note this new address if you want to access your router without resetting it and using a hard line again. The Wii should automatically pick up signal from the wireless router. If for some reason you want to switch between the Wii and a Router by way of hardline, you must contact the maker of your cable modem (or cable company) and find out what the IP address is in order to access it's settings (the same way; by typing it's IP address into a browsers address bar.) By setting the modem to have a different IP there would be no conflict with the other products which (rightly) have the IP address of 192.168.1.1 as a default.
    Hope this helps!
    Dec 08, 2010 | Zoom 5241 Modem
    I have a Belkin N-Router and I was wondering how to connect it to my modem because the cable it has connects only to where the modem's ethernet cable is located when i just run my modem, and there is only...
    plug the one ethernet cable from the modem into the router wan port . The modem will have an ip address note this and then change the ip address to one higher than the modem for the router's ip address and change the ip address in the router to make the gateway ip address the modem ip address.
    Disable the DHCP server in the Router iIf the modem has an active DHCP server in the router.
    Plug the rest of your network into the other router ethernet ports.
    Feb 24, 2018 | Toshiba DOCSIS Cable PCX2500...
    I'm unable to get wireless connection to the internet after i replaced a new modem. Directy connection from modem to laptop is fine. Both my laptop and PC are able to detect the wireless network but are...
    disconnect all the connections from the router. connect only the computer to the port 1 on the router. check the lights on the router. Reset the router for 30 seconds . unplug the power to the router. plug it back in. wait for 1 minute.now check the IP address on the computer. Win XP = click start ==> run ==> type cmd in run box and click ok. you will see the command prompt. in the black window type ipconfig and hit enter. now you will get the IP address and the Default gateway. Default gateway will be the number of your router. This will open the roputer set up. not check the settings on the router. If you connect the modem to the router, it works. now reconfigure the router as per ISP. Click Here for more info about how to set up router
    Nov 18, 2009 | Linksys EtherFast Cable/DSL Router
    Same old question, but I cannot get a connection between my Netgear wireless router WGR614 to my cable modem.I follow the set up via the router's wizard. But no luck. Even unplugged the modem for 15 mins...
    Can you pls confirm if you have cable or PPPoE connection. Also, please connect the modem directly to the computer and let me know the results:
    A. Click on Start—Programs—Accessories—Command Prompt.
    B. In Command Prompt window, type in 'ipconfig' and hit 'Enter'. Note down the IP Address, Subnet mask & Default Gateway here.
    Once I have this information, it will be quite easy to configure the router.
    Oct 09, 2009 | NetGear WGR614 Router
    Cable Network Routing with Zyxel 600
    You have to set different ip address. To clear this up this how I got my setup. I have verizon internet. I use a westell 6100g modem, I have the local ip address set for 192.168.1.1 and I got a linksys wireless router and the ip address set for 192.168.9.1. Then I plug my modem into the wan port and it works. What am I doing is setting a static ip address from my modem to the router and using the router to distribute my address through the network. If you have any printers on the network you need to change that numter to 192.168.9.x number. If you don't have two different numbers set the router will take over.
    Aug 09, 2009 | Zyxel Prestige 841 (91-004-226010) Modem
    Distributing the internet either by wireless or by Ethernet cable
    Sounds to me that the router is not recieving the signal from the Modem. Some Modems require you use a 'cross-over cable' to plug in a router like that (from modem to WAN on D-link). Make sure the IP address of the D-Link is on the same subnet as the Modem, i.e. the cable modem is preset with an ip address scheme (proabably 192.168.0.1 or something) and your router should have the same 192.168.0.x address depending on what the modem is).
    Another thing you can try would be to "bridge" the modem to the router.
    Look here, http://www.computing.net/answers/networking/dsl-modemrouter-in-bridge-mode/28151.html
    Also if you need troubleshooting walkthrough Im available http://www.hoosierpcrepair.com
    Jun 22, 2009 | D-Link DI 514 Wireless Router (DI-514)
    How to install a linksys router
    • Plug the power cord into the wall & into the router
    • Plug your computer's network cable into port number 1 on the router
    • Plug your cable modem's/xDSL network cable into the WAN port on the router
    • Make certain your computer is set to get it's IP address automatically (it already is if your computer has been directly plugged into a cable modem or dsl connection)
    • Re-Boot your computer and try the Internet
    credit to :http://www.asksomeone.net/router.html
    Sep 20, 2008 | Computers & Internet
    Computers & Internet Logo
    75 people viewed this question
    David Payne
    David Payne
