Question about Black & Decker String Trimmer Cordless 12" 18V
Aux Handle Yeah, I have the same problem. My handle broke and I can't find a replacement. I hate planned obselence.
3 Suggested Answers
boscia
  • 163 Answers
SOURCE: Need New Auxillary Handle - Only Place that lists one says it is "obsolete' - no replacement
try www.jackssmallengines.com
Posted on Nov 29, 2008
  • 127 Answers
SOURCE: Handle Nowhere to be found
where are you located?
Posted on Aug 22, 2009
Back door won,t open on my 02 avalanche
door handle broke depends on what door handle it is.if door cant be open on out side out side door handle broke.if cant open door on inside inside door handle broke.door handle clip that connects to latch rod broken.when you try open door handle not engage to latch rod.door not going open.have to replace door handle with new clip holds latch rod in place.
Jan 09, 2013 | 2002 Chevrolet Avalanche
Driver side exterior door handle broke. just one arm broke off the handle, so its still half on but i can't open my door from the out side. can i use the back door handle to replace the front one? also...
This iis very coomon, the part of the handle that broke is the part that releases the latch, you will need to replace the handle, the inside door panel needs to be removed to replace the handle, some of these are revited on and you will need to drill out revits from the outside and disconnect the linkage from the inside, hope this is helpful.
Dec 25, 2010 | 1996 Pontiac Bonneville SE CA Value
Handle broke and had to call in the duct tape. hate to trash the vac just for this reason (although i'd take almost any excuse to buy an oreck). is there any way to get a new "ergonomic handle"??? thanks
This site will probably help you:
http://www.fixya.com/websearch.aspx?cx=partner-pub-8183356113384228%3A3nccpq-il5y&ie=UTF-8&cof=FORID%3A11&q=ergonomic+vacuum+handle&sa=Search#1392
Jim
Nov 30, 2009 | Euro-Pro NV31 Infinity Vacuum
How to install a pontiac G6 driver door handle. The handle broke off. I opened the door panel and retrieve the broken piece. Got a new door handle, but it seems impossible to install it without taking...
Yeah, you have to remove the lock. Use an impact drill with the right phillips head to remove the screws. if you try to take them out with a screw driver, you will strip them. Remember...impact drill.
Nov 30, 2009 | 2006 Pontiac G6
My Eureka Optima vacuum handle broke right at the metal tube.
I have exactly the same problem. I plan to drill a hole in the handle through plastic and metal, and then pass a metal pin to hold them together. I don't rotate the handle much, so the loss of handle spin functionality will not be a major issue for me.
Aug 05, 2009 | Eureka 431A Optima Bagless Upright Vacuum
Broken inside door handle-1996 Chevy Silverado Extended Cab
On almost all GM's there will be a screw in the recess that the handle sits in. After removing this screw, gently wiggle this cup out of it's hole and there should be a metal rod attached to the back of it with a small clip. Unclip this and it's out - installation is the reverse. Just don't lose the clip or let the linkage rod fall down inside or you will have to remove the door panel. It shouldn't take five minutes to replace and most parts stores now carry GM door handle assemblies. Good Luck!
Jan 11, 2009 | 1999 Chevrolet Silverado 1500
Black & Decker String Trimmer Cordless 12" 18V Logo
43 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
