I used the wrong adapter by mistake now my laptop wont come on, i'm sure i fried something , the only thing it does, is the power lightly faintly clicks very rapid. Nothing else.
    Novelist:
  • 166 Answers
Yes you are correct. Due to wrong adaptor the power supply known as SMPS gets fried and causes mother-board damage too. So you need to repair your laptop's mother-board components and power supply too.
If this solution was helpful to you then please rate 100% (or FIXYA) for this solution, otherwise don't rate at all. It was my pleasure helping you.
With regards,
Shyny Saxena
Posted on Jun 30, 2009
Laptop wont power up
when you know for sure the adapter is charging ..and the battery is good..but no power seam to be present ..than the motherboard is gone .... or some contact is issued somewhere on the primary entry of the power..cause if any power would go through the motherboard..than at least the power led would be on ..or the fan should be heard .If there isn't any ..than it is something wrong with the motherboard or with some fuses on the main power source way ..but its a long guess...more than probably it is the motherboard..to blame ..
Nov 22, 2011 | Toshiba Satellite Pro L300 Notebook
I plugged in a laptop using a universal laptop and it fried it
Connecting a power adapter with the wrong voltage or current can be deadly for most electronics, and especially "sensitive" ones, such as laptops... If I were you, I wouldn't take the risk - and change the whole system board!
Good luck,
Pelu.
Jun 03, 2010 | HP Pavilion dv9700t Notebook PC
TravelMate 240 will not start - it begins to power-up, faintly beeps three or four times, then turns itself off - all with a blank screen!
Try these troubleshooting tips and see if it helps....
Laptop is dead. How to troubleshoot the problem.
In this post I’ll explain how to troubleshoot a dead laptop and find the problem. The following troubleshooting tips are not model and brand specific, they should work for most laptops.
Let’s take a look at two different scenarios.
Example 1. The laptop is absolutely dead.
When you plug in the power adapter and press on the power button, there is no signs of life at all. The laptop will not make usual noises, LEDs will not light up, the fan will not spin, the screen is blank and black, etc… In short, the laptop is dead.
What you can do in this case?
1. Make sure the wall outlet is working and the laptop DC adapter is getting power from the outlet. Try another wall outlet.
2. Test the laptop DC power adapter, make sure the voltage output is correct. You can test the DC power adapter with a voltmeter.
3. Let’s say the DC adapter is fine and the adapter outputs correct voltage. In this case unplug the power adapter from the laptop, remove the battery, wait for 1-2 minutes, plug in the adapter and try turning on the laptop again.
OK, you tested the adapter and it’s bad. If you decide to replace the original DC adapter with a generic one, you’ll have to follow this rule:
The voltage output on your new adapter has to be exactly the same as on the original adapter. The amperage on the new adapter could be the same or higher.
If nothing helps and the laptop is still dead, apparently the motherboard is fried or there is a problem with the DC power jack. It’s possible the DC power jack is broken and the motherboard is not getting any power from the adapter. In this case you’ll have to disassemble the laptop and replace the power jack.
Example 2. When you plug the DC power adapter and press on the power button, the laptop starts making normal noises, the LEDs work properly but noting appears on the screen. The laptop will not start.
First of all, take a closer look at the LCD screen. Look at the screen under bright light. It’s possible that the image is still on the screen but it’s very faint.
If there is no image on the laptop LCD screen, test the laptop with an external monitor. Connect an external monitor to the VGA port on your laptop and turn the laptop on. You can toggle video output between the internal LCD screen and external monitor by pressing Fn and F4 keys simultaneously on HP laptops, Fn and F5 keys on Toshiba laptops, Fn and F7 keys on IBM laptops. Other laptops may use different key combinations.
Let’s say the external monitor works fine but the internal LCD screen has no image at all. If that’s the case, your problem could be related to the LCD screen or the video cable. Also, make sure the video cable makes good connection with the motherboard and the LCD screen. Try reconnecting, reseating the cable.
In my case, both internal and external monitors were absolutely dead. Neither of them had image. That means the problem is not related to the LCD screen or the video cable. From my experience I know that this problem could be related to the laptop memory.
Try reseating the memory module, maybe it’s not making good connection with the memory slot. Try cleaning contacts on the memory module with pen eraser. Try moving the memory module into another slot. Try replacing the memory module with another known good module, it’s possible that your original module is dead.
If you have two memory modules installed you can try removing them one by one, it’s possible that one of the modules is bad. Try installing different memory modules into different memory slots.
In my case reseating, swapping the memory module didn’t help. I was pretty confident that my problem is not memory related and I moved on.
Try removing battery, hard drive and DVD drive and turning on the laptop without these components.
Also, try turning on the laptop with an external monitor when the video cable is unplugged from the motherboard. If the laptop start with video on the external monitor, apparently there is something wrong with the laptop display panel.
Finally, disassemble the laptop and removed the motherboard.
1. Motherboard. Like on most laptops, in my case the video card is integrated into the motherboard
2. CPU with heatsink and cooling fan.
3. Known good memory module.
4. The power button board witch you need to turn on the system.
5. Working DC power adapter.
Still cannot get any video on the external monitor. The system turns on, the cooling fan starts spinning but there is no video.
At this point I’m 95% sure that the motherboard is dead. CPU failures are not very common, so it must be bad motherboard.
Oct 11, 2009 | Acer TravelMate 240 Notebook
How Do I Fix My Sansa E250 I charged It One Day On MY Ipod Wall Charger And It Started Smoking Now It Work Wont Work And I Need A New Sansa Charger
you probably fried the entire thing. Using the wrong power cord is a big no no as the voltage and amplitude must match or you could easily overload or slug down the product. Sorry but the best advice is learn from the mistake and use the thing for parts as that would void manufacturers warranty.
Jul 16, 2009 | SanDisk Sansa e250 MP3 Player
My toshiba laptop will not turn on...
This could be a few things. It could be a bad power cord not charging the battery or the machine. But it could also be various other things. The cheapest and easiest thing to try is a new power adapter.
May 26, 2009 | Toshiba Satellite A60 Notebook
Plugged in with printer cord
if you plugged in the wrong power adapter you could have very well fried it. Each device such as a LAPTOP or a Printer used different volts, or amps, etc they are not interchangeable even it it fits!
Sorry but if its fried its dead..
Apr 20, 2009 | Compaq Presario Notebook
Notebook not powering on
if its not the battery, try replacing the memory
Aug 28, 2008 | Gateway Solo 1450 Notebook
Laptop won't charge and fried jack and power adapter
go to www.pcrepairhelp.net
have not used them, but plan to send them a dv1000 with similar issues next week.
good luck.
Jul 13, 2008 | HP Pavilion dv1000 Notebook
When i Power up my Laptop it wont boot!
Ooooh! That was not a smart thing to do.You may have shorted something out.
Try this:
Make sure it is unplugged.
Remove the battery.
Remove the hard drive again.
Hold down the power button for at least 60 seconds.
Replace the hard drive. Make sure it is seated properly.
Try booting.
If the power light comes on but the laptop will not boot you may have fried your hard drive.
Apr 05, 2008 | Compaq Evo N1000C Notebook
No power to Compaq Presario
There were several recalls on Compaq's ac adapters and batteries that caused fire to units...
Check this out
http://www.consumeraffairs.com/recalls04/2006/hp_batteries.html
I would also check with compaq about your problem. They were replacing and repairing the units free of charge due to the defects. I would check with them
Hope this helps you
Oct 21, 2007 | HP Compaq Presario R4010US (PX352UA) PC...
Computers & Internet Logo
339 people viewed this question
David Payne
David Payne
