Question about LG LD65EL Dehumidifier
LG dehumidifier won't drain through hose anymore.
    Scholar:
  • 70 Answers
Make sure hose is flat with no high or low spots. Blow or **** out hose and pour somr bleach water through hose.
Posted on Jun 30, 2009
  • 4 Answers
Had the same problem. Make sure you tighten the house a little with pliers. Also, make sure the dehumidifier is up a lot higher than where you're draining it into. Mine drains into a utility sink. But I have the dehumidifier propped up onto a dresser. I cut a small piece of hose to run into the sink. Seems to be working now.
It will take 5 min or so to establish a water flow, so be patient after you hook everything up. Good luck.
Posted on Jul 24, 2009
SOURCE: LG Dehumidifier overflows when attachment tube/hose attached
  • After 1 year of wondering why the LG instruction manual said no more than shove the white hose connector piece into the rear of the unit until secure, and relying on 'hit or miss' that the drain hose would actually work, (rather than filling up the bucket), I have finally found the solution. Ironically, it came while I was on my knees getting serial number from behind the bucket before they would try to help me by phone. There I saw it! The black interior drain piece inside the unit (top right when you remove the bucket) that the white house connector must be secured over. (Nothing in the manual ever told me to look for this.) As for securing the unit in the back--under the big vertical flap (which must point up and remain outside the unit), there is a smaller flap or triangular piece. They say that should be inside the unit, which it doesn't seem to go, because it is parallel to the large vertical flap), but if you push hard enough it does click onto the unit, while allowing the large while flap to remain outside (with the arrow pointing up), making the entire piece secure. Check once more to see if the white hose connector piece is secured over the interior drain piece (a black plastic elbow piece, on the top inside right where you remove the bucket, as I've said), and you'll be good to go! LG should be ashamed of their manual writing on this and the time I wasted getting my two units to work. However, at least these units are not fatally flawed as I was beginning to think.
Posted on Aug 16, 2008
SOURCE: Drain problem
I have the same problem and after talking (mostly waiting) with Fedders repair, I have been told how to solve the problem. Plug up the drain hole on the right side (the one not connected to the drain hose). The drain hole extends down about 5mm, outside measures 10mm and interior measures 7mm. They do come with a drain hold cover. Not a replaceable part with a number. Off to the hardware store.
Posted on Jul 18, 2007
SOURCE: My direct drain doesn't work anymore
I fixed the same problem, finally. At first it was sufficient to clean the outside hose (it was filled with a **** builtup). Then it stopped working again. I decided to open the unit and see how easy it is to clean the inside drain hose. It is very easy. Once you unscrew the back panel (8 screws total if i remember correctly) you can access the back and you see the drain hose that connects to the drain outlet. To remove it and clean it, you will have to unfasten the big capacitor (3 screws). Then, remove the hose and clean it (mine was full of that same **** stuff). Reinstall - you will need a tie wrap to connect the hose at the top, as it is from the factory. Very easy operation and now the dehumidifier is draining again.
Posted on Nov 22, 2007
8upaxeman
SOURCE: I purchased a LG Dehumidifier
Remove the drain bucket. on the top there are two pieces that can be removed just by taking them out. they are just laying in there. 1 is the brush the other is the "drain tube insert" it is a plastic tube and has a threaded fitting on one end. take your garden hose with a female connector on one end just like you were going to install on your spicket outside of your house and connect it to the threaded end of the "drain tube insert" make sure you knockout the round plastic drain plug cover hole located in the back of the unit (it is behind where your power cord was stored) it has three tabs to break. remove drain bucket. take the drain tube with hose attatched and insert it into the drain plug hole in the back and attach it onto the drain outlet (the drain outlet is inside the drain bucket side at the top it looks like an elbow fitting) push the tube so that the flap with the arrow is flush with the back. once you get the "drain tube insert" almost all the way flush with the back -->if you look inside the drain bucket side you will see where it fits over the drain outlet
Posted on Jul 29, 2008
SOURCE: Water from LG 30 pt dehumidifier drains into
(assumming you are not an idiot, like the other solver suggested) you may very well have it connected to the right spot, many of these units, are not balanced well, (or are balnaced all to well, depending on how you look at it) The imbalance, basically makes the water drip to the front, instead of the back. Try to put something under just the front of the machine, to tilt it back, ever so slightly. Good luck
Posted on Jun 26, 2009
Kenmore 407 50 pint dehumidifier won't drain through hose
Did you punch out (or cut) the plug that the hose connects to? If not, its blocking the water from draining to the hose.
Also, make sure the unit is higher than the drain and that the hose is not kinked or clogged.
Please rate 4 stars if this is helpful. Thanks and good luck!
Oct 13, 2012 | Kenmore 90701 70 Pint Dehumidifier With...
Is it possible to buy a tube that will allow me to drain my dehumidifier (Whirlpool Accudry AD25BBL6) into my ejector pump that I use with my air conditioning unit?
A standard Garden Hose will work. However, the hose can not be any longer than 5 feet and must always slope downward. As, there is no pump in the dehumidifier. It relies entirely on gravity to drain thru a hose. So, unless your condensation pump is within 5 feet of the dehumidifier, it won't work.
Hope this helped you. Please let e know.
Jun 28, 2011 | Whirlpool AD25BBK Dehumidifier
I have an LHD6594EBL dehumidifier that won't run and it keeps saying the bucket is full but the bucket is empty, we have a hose attached and don't use the bucket,
Sue, if you haven't noticed any water draining from the hose recently, it may be that the hose connection and tubing of the unit are clogged and the drained water pressure is causing the unit to show "Bucket Full." Also, if the bucket is not properly in place, whether you use the drain hose or not, it will cause the unit to stop functioning. You know how to correct that, so I won't go into detail on that issue.
To unclog the drain, you will need an 18" long, plastic Zip Tie or something similar (NO wire coat hangers though) that will fit into the hose connection. TURN THE UNIT OFF AND UNPLUG IT. Then carefully insert the Zip Tie and continue to push it in until you reach the bend in the tubing. You will have to carefully work it past this bend, until it either bottoms out or you run out of usable Zip Tie. Now, while rotating it, slowly pull it out and be prepared for some water to follow.
Hope this helped you troubleshoot and solve the problem.
Jun 01, 2011 | LG LHD659EBL Dehumidifier
How is the external tube for draining outside connected to the dehumidifier. Does the tube insert into the right angle nipple, then the threded end conected to a drain hose?
No. The tube inserts straight into the drain hole. Follow the 4 sets below.
1. Connect a garden hose to the threaded drain hose connector.
2. Remove the drain-hole cover.
3. Push hose connector tightly into the drain-hole on Rear Grille.
4. Press the hose down and make sure the "Arrow" on the tab is pointing upward.
NOTE:
The hose attachment will accept a standard garden hose fitting. Do not over tighten the hose when
connecting it to the hose connector, use a rubber washer and tighten by hand firmly without stripping the plastic threads. Be sure the hose lays flat and has no kinks, as it will not drain properly.
Apr 12, 2011 | LG DH404E Dehumidifier
I attached a hose to the drain hose connector. When I insert it into the drain hole it is blocked by the back of the dehumidifier. What iw the correct way to insert? Can you send a better diagram?
The drain hose connector MUST be attached to the unit, before attaching the garden hose.
First, the connector is attached to the unit. Second, the hose is hand tightened to the connector.
If you haven't been doing it in this order, that's the problem.
Mar 13, 2011 | LG LHD459EL Dehumidifier
Can a hose be attached to the LG 45 dehumidifier to allow to drain as it fills?
Yes a hose can be connected to this unit.
1. Remove the drain-hole cover from the back of the unit.
2. Connect a garden hose to the threaded hose connector.
3. Push the hose connector tightly to the drain-hole on the back of the unit
This is explained on the manual on page 12. Hope this helps
Jul 29, 2010 | LG DH404E Dehumidifier
Where to hook up drain hose
On the bucket there should be a cap. If you remove it your hose can attach to it. Run the hose top a drain. If possible, raise the dehumidifier so the water drains properly. From time to time, pour a little bit of bleach into the hose to keep mold away.
Sep 29, 2009 | LG LHD65EBL Dehumidifier
LG dehumidifier
I Have an LG Dehumidifier and water has leaked out to the basement floor, it has a hose that drains into the floor
Sep 12, 2008 | LG LHD65EBL Dehumidifier
LG Dehumidfier
When you install the drain tube, be sure that it is placed into the drain hole in the dehumidifier. You then will be able to "latch" the tube at the hose end by lowering onto the outer hole opening. This maintains a tight connection and the water will drain properly.
Jun 17, 2008 | LG LD65EL Dehumidifier
Drain problem
Apr 03, 2007 | Maytag M7DH65B2A Dehumidifier
LG LD65EL Dehumidifier Logo
2,550 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Craig Butler
Craig Butler
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
