Question about Canon PIXMA MP620 All-In-One InkJet Printer
Printer not working wireless (printer offline)
I am trying to print something wireless and it worked just fine yesterday, but now when I am trying to do it, my printer just says that it is offline! How am I supposed to put it back online? (or something like that!)
Phoned Canon with the same problem. Everytime I installed the printer it would work until I rebooted. Canon advised that all I had to do was right click on the MP620 printer in printer control panel, then make sure that "Use Printer Offline"is not selected. Worked for me. Goodluck
Posted on Jun 30, 2009
  • troydk Jun 30, 2009
    Would love to hear if this helped any.
    Novelist:
    Champion:
  • 256 Answers
To solve this problem you must check the toner or ink cartridge. Most of this arises as you have not checked the toner and the ink cartridge. The toner and the ink cartridge are designed to have a certain capacity. If the printer toner and cartridges are empty it will cause to turn your wireless printer offline. Incorrect installation of your printer can also make your printer turn offline.
Posted on Jun 29, 2011
Canon PIXMA MP495 InkJet Printer - Offline issues
For Vista wireless setup: Open your Control Panel. Choose Printers. In the Printers box it lists your printers. Hover over the wireless printer icon, right click, choose Run as Administrator, then choose Use Printer online. This should change the status of the printer to Ready (from Offline). Be sure you've chosen this printer as your default printer. Might have to do this on a regular basis.
Nov 22, 2011 | Canon PIXMA MP495 InkJet Printer
How to turn off wireless of samsung color laser printer clx-3185FW
The manual doesn't specifically state this but it appears that if the printer is connected to a wired LAN connection the wireless function will be disabled if the printer is set up in infrastructure mode. When I tried this the 'wireless' light turned off and I wasn't able to find the printer's WiFi SSID using a nearby netbook. If your goal, like mine, was to disable the printer's WiFi from transmitting to reduce extra WiFi noise then this seems to work. One of the wireless troubleshooting tips in the manual states to disconnect the wired connection before attempting to set up a wireless connection so it appears the two can't be used simultaneously. It seems odd that there's no specific "off" setting for wireless though. The printer will provide a WiFi connection when also connected to a wired LAN port if it is set up as part of an ad-hoc wireless network so make sure you set it to 'infrastructure' mode to disable WiFi.
Feb 11, 2011 | Samsung CLP-315W Laser Color Printer
I have a HP 6500 wireless --- Can not print --- It says offline. It worked yesterday
Those hp wireless printers can be a pain. the simplist thing I can suggest is to turn the printer off. Turn back on and reboot the computer and the printer software on the computer should say your back online again. If not more drastic action is needed.
Nov 17, 2009 | HP Office Equipment & Supplies
Offline wireless printer
Please make sure that printer is turn on, before doing ensure you do power cycle of printer.
Add printer on Standard TCP/IP port.
Sep 13, 2009 | Brother MFC 490cw Color Inkjet...
HP Photosmart C6180 All-in-one Offline mode
Go to www.hp.com. let the PRINTERS section auto-detect your printer and download the drivers automatically.
Jun 27, 2009 | HP Photosmart C6180 All-In-One InkJet...
Printer not responding
I had the same problem after I accidentally pulled the power cord out of the printer - it turned out to be the firewall on my PC, when the printer reconnected to the wireless network it got a new IP address and the firewall was blocking incoming messages from it.
Jun 13, 2009 | Canon PIXMA MP620 All-In-One InkJet...
HP Officejet 4315 All-in-One went offline
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
Mar 31, 2009 | HP Officejet 4315 All-in-One Printer
I can not print
You could try to use static ip to remove possible problems with dns retrieving:
  • Set the machine to static ip (Menu -> Network -> WLAN -> Boot Method -> Static).
  • Check the ip number on the machine (Menu -> Network -> WLAN -> IP address)
  • On your PC, go to Control Panel -> Printers
  • Right-click printer, choose Properties
  • Choose Ports and click "Add Port"
  • Double-click on Standard TCP/IP, follow the guide and type in your IP number earlier retrieved.
  • Save settings, press OK and the problem could be solved (if it was due to dns problems).
Also, if it works, you can change the network settings for scanner driver to go to ip address too instead of dns, even if it isn't a problem right now, it could later be.
Mar 02, 2009 | Brother MFC 6490CW InkJet Printer
Printer lists work offline
brenna130,
Try not to interrupt the infrared port so that the connection of both laptop and printer will not be offline
Jul 04, 2008 | HP Photosmart C6180 All-In-One InkJet...
Canon PIXMA MP620 All-In-One InkJet Printer Logo
9,085 people viewed this question
old marine
old marine
