Hitachi Ultravision 46UX50B Flickering/Dead Display
I have an older Hitachi Ultravision 46UX50B that no longer displays an image with any consistency. The picture will sort of do a quick flicker, then go out. No backlighting, just a dead screen. When you stomp the floor, it comes back on, but not all the time. Do I have some bad solders? Loose wires? Help please.
  • 668 Answers
It is possible that you have some loose connections, but I have seen the relays in the power supply get to be intermitent and will not stay closed. Tapping lightly on the relays will usually tell whether or not they are bad.
Posted on Jun 30, 2009
Need advice on hitachi ultravision 60SX12B flyback?
If you wish to get some details; check the site linked here. Pull up older posts.
Jul 16, 2016 | Hitachi Televison & Video
Where is the convergence circuit on a Hitachi 60sx12B
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
How can i fix my hitachi ultravision it has green and double vision on top of screen
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
May 23, 2014 | Hitachi UltraVision CineForm 55VG825 55"...
Upper sise of screen flickering problem
Technology b> A laptop's display assembly consists of an LCD panel, an inverter board and a backlight lamp. The inverter board supplies power to the lamp which lights up the LCD screen as it generates images. Light from the lamp is then uniformly distributed over the panel to create images. b> Cause b> Flickering is commonly caused by a damaged or malfunctioning inverter. Because a faulty inverter is not able to supply adequate power to the backlight lamp, the screen goes dim each time the backlight loses power. In some cases, flickering may also be caused by a faulty connection between the inverter and backlight lamp. Diagnosis b> Resolving a laptop screen's flickering problem entails correctly diagnosing the problem and replacing the faulty component. You may diagnose the problem by hooking up the laptop to an external display unit, such as a projector. If the external display has the same display problem as the laptop's LCD screen, it is indicative of a motherboard or video card problem. If the external unit displays bright, crisp images, the problem is probably caused by the backlight or inverter. b> Solution b> You may repair a laptop screen's flickering problem by replacing the inverter board or backlight. Order parts from a trusted supplier and replace the component by referring to your product documentation.
http://www.tech-faq.com/how-to-repair-a-laptop-screen.html http://www.laptop-repair.info/laptop_screen_repair.html b> Hope this helps.
Jan 21, 2013 | Lenovo IdeaPad S300 59359327 Silver Gray...
I'm not getting any red in my picture on my hitachi rear projection ultravision tv
A model number would help here but if it is older and uses 3 picture tubes carefully with the back off and set on does the red one come up and produce a red image?
Dec 12, 2012 | Hitachi Televison & Video
I have to replace the protective screen on my 46 inch Ultravision Model # 46UX24B Serial # V6H002493 which is cracked. Can I get a replacement from you? If so tell me what to do, and what the cost...
Call your local TV Shops and ask do they have Good use one for sell,or look on EBay under Electronics TV/Parts . Encompass Parts 1-800-638-3328 and Go to this website Shopjimmy.com
Nov 05, 2010 | Hitachi 46UX50B 46" Rear Projection...
Sound, no picture, no display, just a black screen
its a Hitachi DLP
it has a lamp that illuminates the screen
it has most likely failed in your owners manuel it should be more specific and you can order a lamp and replace it your self
and you can order a lamp off of line or call hitachi
Oct 26, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Many thin black horizontal lines on my Hitachi Ultravision 50" TV
Good Day, LDS also;
You may have a poor seated cable connector. Unplug TV from A/C, remove back look for a large black connector. It connects between the Main Digital Module and the Drive PWB. Re-insert both ends several times to make better contact, use contact cleaner if have but not always needed. Good Luck, big IRISH.
Jul 21, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
61 Hitachi Ultra Vision has double image
you will need to replace both convergence ICs they are STK392-110 you will also need six resistors (2) 2.2 ohm 1watt
(2) 1.5 ohm 1watt, (1) 3.3 ohm 1watt and (1) 1.8 ohm 1watt.
You can get replacemnet ICs and resistors at te following link with free instalation instructions. Here is the link.
http://servicemanuals.vstore.ca/
Jul 17, 2008 | Hitachi 61SDX01B 61" Rear Projection...
I would like to order an owners manual and remote
I have found a couple of sites where you can download the owners manual for a fee of $9.99 but I have been unable to find a site where it is free. Hitachi web site does have several owner manuals but do not have the one for this tv. My owners manual is a photo copy of the original manual. I got mine by calling Hitachi (1-800-448-2244) shortly after purchasing the TV, it was a display model and did not come with one. I have just bought my second remote, first one when I got the owners manual and second one just a couple of weeks ago through sears parts. Once I get a scanner hooked up I will try to upload my manual to this site.
If you would like the service manual, go to http://www.schematicsforfree.com/archive/?path=Video%2FProducts and scroll down to 01-21-08 29842400 pdf.gif Hitachi 46Ux50B.pdf
this is the "service" manual for Hitachi models 46UX50B/51K, 50UX52B/53K, 60UX54B/55K, 50SBX70B, 60SBX72B, 70SBX74B. These are the same model numbers listed on the owners manual.
I hope this helps someone out. Shera
Oct 12, 2007 | Televison & Video
Televison & Video Logo
126 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
