Question about Kenmore 3.5 cu. ft. Front Load Electric Washer
The front load washer does not drain completely from the door gasket area. Not the inside of the machine. I have to use a turkey baster to remove excess water. Cannot close the door after washing or there will be a mold buildup on the rubber gasket.
  • 15,935 Answers
It appears your bellow gasket has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
How to Replace rubber seal on front load washer
The rubber seal on your washer and similar front loading washers is a relatively easy repair. The seal is held onto the front washer panel and the fixed inside washer drum with separate spring-loaded rings that are reusable. So, don't throw them away! You need to remove the front ring from the front panel before you can remove the front panel. With the ring removed the gasket should be pushed into the washer; noting any drain holes, so that you can reinstall the new gasket in the same orientation. Once the outer ring is removed and the front panel is out of the way, you will have access to the ring holding the gasket to the drum. After the inside ring is removed, the gasket should pull off the fixed washer drum. You are now ready to install the new replacement gasket.
The amount of disassembly of the front of the washer is your option if it interferes with the installation. The door is usually heavy and it is useful to remove it from the front panel. Usually, a couple screws holds it in place. Removal of the front panel may also involve removal of the top of the washer and moving the control panel out of the way so that you can access the screws holding the front panel onto the frame of the washer. The locking latch may have to be temporarily removed but can be left in place if you simply push the front panel out of the way to have access to the inside gasket ring. It is useful to take pictures of each stage of the disassembly process to make sure your reinstall everything as it was.
Installation of the gasket starts with reattaching it to the fixed washer drum flange and then replacing the spring-loaded ring to hold it in place. Make sure the gasket orientation matches the original position. After the gasket is attached to the drum, you can now reinstall the front panel. If you unscrewed the latch mechanism when you took off the panel, now is the time to reinstall it as it can be manually held in place behind the gasket. The door can usually remain off the front panel until installation of the gasket onto the front panel is complete. Now bring the gasket forward and reinstall it on the flange of the front panel; secure it in place with the spring-loaded ring. Your gasket is now reinstalled. Simply reinstall the door and your repair is complete.
Tools needed include a blade screwdriver to help pry the rings off the gasket seal and one or two specialty screwdrivers (usually Torx or Philips) to remove the front panel.
Aug 05, 2014 | Frigidaire Washing Machines
MY WASHER IS NOT DRAINING PROPERLY.
remove the access panel below the door and clean out the drain pump and hoses under there,also just inside the door at the door boot there is a drain hose and it can plug up also,clean out both areas
Dec 22, 2010 | GE WCVH6260F Front Load Washer
The loading door gasket-- the big rubber liner doesn't drain
Some front loaders have a door boot drain hole, most do not and it is normal for some water to accumulate at bottom of boot. To help with mold and mildew use a washing machine cleaning solution, follow directions. Also a bleach solution of 2 parts water 1 part bleach sprayed on area helps. If mildew is really bad, nothing will completly remove it. Make sure you use only a high efficiency detergent.
Feb 03, 2010 | Washing Machines
I have a kenmore front load washer model number 4174104200 and water is leaking onto floor.
Can you describe WHERE the leak may be coming from? If the leak is coming from the front area of the washer, it may be the door bellow (rubber gasket), or the drain pump. You will need to open the door and pull back the folds in the rubber gasket and inspect for cracks or tears in the rubber. To inspect the pump, you need to remove the bottom panel under the door and look for any leaks inside the unit. The drain pump is in the front, directly under the wash tub. Also check all hose connections. If the washer is leaking from the rear area, check the fill hoses and drain hoses for cracks or holes. Make sure all hose connections are tight. The fill valve is another possiblity too. You will need to remove the top panel to view the valve to ensure it is not dripping. Please verify your symptoms and let me know. I hope this helps.
May 01, 2009 | Washing Machines
My washing machine is leaking from the bottom it is ruining my floor do I need to replace the machine or do you think it is a simple task to fix
If this is the same leak I just fixed, it is worth fixing ($12 dollar part from repairclinic.com), but takes some skill at taking it apart and putting it back together.
My leak was from a black rubber hose that connect the drum to the filter area and recirculating and drain pumps. The repair can be done from the front of the machine.
1. Drain the machine - pry the panel at the front left lower corner to get access to a stoppered tube. drain as much water from here as possible.
2. Remove screw visible inside this area and remove the white molded plastic - also remove the screw behind that plastic.
3. Open the washer door and remove the spring loaded wire around the door gasket. Carefully pull the door gasket away from the panel push inside and then reclose the door.
4. Remove the detergent drawer and the two screws visible behind it.
5. Pull the top of the electronics panel away from the machine and lift up - place on top of machine or hook it out of the way
6 Remove the 4 screws that are visible holding the front panel to the machine. Left the entire front panel up about 2 inches and swing to the right (there is a wire connecting the door to the machine on the right)
7. You can now see inside the machine and hopefully see where your leak is comming from. The black rubber hose connecting the drum to the drain area is where my leak developed because this is designed to flex as the machine tumbles and spins but ultimately wears out. It is connected with two clams that can be removed with pliers and a third hose clamp that diconnects with a phillips head screw driver.
Apr 26, 2009 | LG WM-2277HW Front Load Washer
On an LG 2277 washer. I try to start a load. I get error message: "de"- door not closed. It looks to me that there must a switch to sense if the door is closed. Where is this switch located and how do you...
The switch is behind the front panel - to remove it, unplug the machine and:
1. Open the panel where the drain filter is (lower left side of the front panel)
The wire connecting the panel to the machine on the right leads to the switch and door lock mechanism
Apr 25, 2009 | LG WM-2277HW Front Load Washer
LG WM2487 Leak Front Left
Not sure if this machine is similar to the WM2277, but here is the procedure for that - my leak was in the "baffels" hose that connects the drum to the drain pump:
Jan 16, 2009 | LG WM-2277HW Front Load Washer
Washer Tub Gasket
remove gasket from cabinet - just held onto cabinet by a simple clamp and fold gasket inside drum. this will give you enough room to access the retainer. you may find it easier to remove the top as well
Sep 09, 2008 | Whirlpool GHW9400 Front Load Washer
Washing Machines Logo
140 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
