You need to evacuate mositure with a vacuum pump and then add a can of r134a with oil in the can. Then add more cans without oil. Up to the amount on the decal under the hood.
The low side charge port is behind the passenger fender well. Remove tire and the 7 fasteners holding the plastic fender liner in.
If u need freon buy a freon charge hose,look at compresor and find the large ac lines conected to comprsor,follow the large ac line/hose,untill u get to the service port,,,this is the low side ,conect here///but u need to put oil in /is there oil in compressor/if not u need to relly put oil in compresor pag46/start car and begin charging(no oil it will lock up and be distroyed) high blower selected and max air/recerulation settings sould not hold more than 2 cans/may be a little over dont over charge
STEPS TO CHARGING YOUR CARS COOLING SYSTEM:
STEP 1) Look under the hood of you car on the left side of your cars engine. There should be two stainless steel lines coming from a stainless steel cylinder to your cars compressor. The two lines have plastic dust caps on them sometimes they are blue or black. Usally the black has the larger diameter tubing that runs between the evaporator and the compressor. This will be the port that you hook the refrigerant hose up to.
STEP 2) Start your cars engine after you have secured the hose hook up to the air conditioner line port. Once the cars engine is running, turn your cars AC on to Max cool. Shake the can of coolant well. The gauge on the can of coolant should read in the blue but if it is in the green your air conditioners pressure will be between 0-25 pounds per square inch. This means you will have to add refrigerant to the compressor.
If your cars air conditioner pressure is in the blue. The system has the proper amount of refrigerant and you do not need to add. If the gauge reads in the yellow you may want to seek professional help because refrigerant is not what is wrong with the unit and is probably something more technical and most likely something that you do not want to attempt to do on your own. The red on the gauge means do not add any refrigerant at all and to seek professional help.
STEP 3) If the pressure of your air conditioning system is in the green it means it is safe to add the refrigerant. You should wait for your air conditioning compressor to switch on before squeezing the trigger to add the coolant. When the compressor switches off then release the trigger and repeat until your pressure gauge on the coolant can says that the coolant is in the proper range. If the needle on the gauge is in the top part of the blue you have successfully charged your cars air conditioning unit.
STEP 4) Release the attachment from the tubing port and replace the dust cap back in it's proper place and you are done. The cars air should be cool and your compressor should cut off and on less often. If problems persist you should consult a mechanic or someone that has experience with air conditioning systems.
