My Toshiba Satellite A135-S4677\r\will not power up
My Toshiba Satellite A135-S4677 will not power up on charge. The blue light will come on with the battery plug into the system. When I remove the battery the blue light will not come on. This system will try to start up the battery as you here the fan and flash on the disk light. What do you think is the problem. I know it should work with power adapter but it doesn't.
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    do you get any video at all with a charged up battery or an ac adapter hooked up.
I have a satellite A135-S4677 laptop and I cant get the microphone to work!!!! please help....
Goto Start-> Settings-> Control Panel click on sound and audio devices.Click on advanced button under device volume.
On the popup control click on options properties and click on recording if you cannot access that select the drop down above and click on input and then click on ok. Un mute the mic and if you have a recording volume slider , set it to the level you want. Now test by speaking into your mic and set recording volume.
Jan 15, 2011 | Toshiba Satellite A135-S4527 Notebook
I have a toshiba satellite A135-S4677 it doesnt start at all i have it plug in and no light from the laptop just the light from the power cord please help
the adaptor may be out it may not be supplying power to the laptop power supply circuit
or
the power unit circuit in the notebook may be out
or
the motherboard may be down...
only tech shop can fix it...
Jan 21, 2010 | Toshiba Satellite A135-S4527 Notebook
Microphone issue with "Toshiba Satellite A135 4656" with XP
Most of the drivers can be found here:
http://il.computers.toshiba-europe.c...jsp?service=IL
Select: Notebook
Select: Satellite Promag-glass_10x10.gif
Select: Satellite Pro A Series
Select: Satillite Pro A200 (PSAE1)
Select: PSAE1
Select: Windows XP
Select : Search
This model has the same Chipset Drivers as the A135-S4677
You will need XP SP2 (NOT SP3)
The LINK will show you alot of drivers, but follow this order by make and version #
Chipset Utility: INTEL 7.1.0.1014
Display Driver: Intel 6.14.10.4833
LAN Driver: Realtek 5.664.205.2007
Wireless Driver : Atheros 5.2.0.125
Sound: Realtek 5.10.0.5464 (Next page)
Modem: You will have to select you region
Sep 26, 2009 | Toshiba Satellite A135-S2276 Notebook
Toshiba satellite A135-s4677 default passcodes
Hello, There is 3 things you can do.
1st the most easy thing to do if you have nothing important on it then do a complete system restore. by selecting the relevent key f10 f11. OR you could try pressing F8 before wndows starts to boot then from the new menu select recovery option from that menu the follow the on screen options
2nd if it can be done as an option in the restore menu then do a partial restore to a previous point that might remove the password.
3rd use another computer to download a password removal tool this uses the startup boot via a bootable dvd/cd it then uses its built in program to access the Microsoft password system then to either remove or change the password.
However if it is the bios you will need to short the cmos by taking it apart removing the battery or using the jumper to clear it. this WILL void any warranty though.
Sep 25, 2009 | Toshiba Satellite A135-S4527 Notebook
A135 Series on XP Microphone Wont Detect Sound
your laptop might have the microphone listed but it might just be a port to plug one in.thats the way mine is.
Aug 09, 2009 | Toshiba Satellite A135-S4527 Notebook
Replace cd/dvd for a135-s4677
simply get the cd/dvd rom.that simple
Jul 03, 2009 | Toshiba Satellite A135 Notebook
Toshiba satellite a130/a135 series. I connect to
check the power cord to the laptop in the back wiggle it. check the lights. if they come on and go off with you giggling the power cord. the ac input socket may be broken. you may have to wedge it in one spot to get the two lights to come on let it sit there a while 20 min to charge battery some then turn on laptop.
Jun 23, 2009 | Toshiba Satellite A135-S2276 Notebook
TOSHIBA LAPTOP SATELLITE A135-S4527 WON'T POWER UP
Not charging . . . And probably the power pin ... where the AC cord connects to thecomputer. That particular component is very fragile. The part torepair it runs between $ 5-$15 but the labor to repair it will costanywhere from $ 100-$250. It can be repaired by you if you are verycareful taking the system apart. Just pay attention to every detail ofyour dis-assembly. I also recommend you get one of these to stop the problem from happening a 2nd time.
Dec 14, 2008 | Toshiba Satellite A135-S4527 Notebook
Toshiba Satellite A135-S4666
try to eject whatever is in the DVD (you will see a tiny hole near the eject button, straighten a paper clip and push it in the hole) then try again
regards
Nov 24, 2008 | Toshiba Satellite A135 Notebook
No power
with my satellite, i had to charge it before it was operational.
if its charged, look on the front panel, is the battery light red, or blue.
red means its dead.
blue means its fully charged
Jul 01, 2008 | Toshiba Satellite A135-S4527 Notebook
Computers & Internet Logo
554 people viewed this question
David Payne
David Payne
